Question about LG Televison & Video
I can only see a picture on one side of the screen then there is interference on full screen then picture reapears
    Top Expert:
  • LG Master
  • 14,553 Answers
Most likely a bad board (set uses two boards --one to drive screen on either side----could also be a bad connection there or inside the display panel itself.
Posted on Nov 01, 2012
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
Picture ratio
Programs that are recorded in 16:9 format appear full screen on a 16:9 TV. A program recorded in a standard 4:3 format will either be stretched to fit the screen or have side bars to fill the screen area. In the case of HD channels, the black side bars are part of the picture which is being broadcasted.
Apr 22, 2010 | LG 32LG30 32 in. LCD HDTV
I cant keep the picture at full screen fom channel to channel
The reason for this is that the incoming signal is not always the same. Stations broadcast in different formats from 480i to 1080. If the bars top and bottom or side to side bother you then you'll have to stretch the picture (try different modes) to keep the picture screen full.
Dec 24, 2009 | Dynex DX-LCD37 TV
Screen savers
Go to Control Panel choose Display Properties go to Desktop tab there is a selection from Position: center, stretch, tile choose the stretch then apply and ok, your picture will displayed in full screen in your desktop
Nov 09, 2009 | Computers & Internet
Bands of color on picture on rca tv. they are blue and green on left side of screen.
i believe that your problem is magnetic interference. there is a wire that runs around your tv inside and it stops the magnetic interference from disturbing your colors. have someone that is qualified to go inside your tv and see if that wire is unplugged from your power supply. if it is they should simply plug it back in and it should solve your problem. otherwise write me back for more info.
Nov 06, 2009 | RCA Televison & Video
Lost channel info for channel 5 on my DVR Digifusion FVRT 145 since end of sept. Most other listings are still being downloaded
First I emtied all listings by retuning with arial unplugged . then did full channel search with ariel reconnected . Left unit on standby overnight all channel listings reapeared.
Oct 05, 2009 | Digi Televison & Video
LE40R74BD VOLUME OK BUT BLANK SCREEN
sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swolled on top and are easy to solder in cost about $1 EACH
Jul 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
No picture on RCA.
prob bad connection crt filiment  socket could be loose on crt.
Dec 01, 2008 | Televison & Video
22" Acer flat screen monitor
this sounds like an electrical fault or failing component, within the Monitor.
Check the cabling, to ensure it,s not damaged-broken-kinked et,c. by carefully moving the cable gently side to side and up and down.
If it puts itself right for a second or two. you can assume its a broken internal wire, within the lead.
Or a dry soldered joint-Connection.
Mike @ compurepair.
Sep 16, 2008 | Acer AL2216WBD LCD Monitor
Televison & Video Logo
15 people viewed this question
Computer Repairing
Computer Repairing
