Question about Dishwashers
Ok so my dishwasher wasn't heating the water and wasnt completing a cycle and throwing up a code 3 ....I changed the element which heated the water first time but it has now gone back to not working
    Filmmaker:
    Uploaded 5 video answers.
  • 15 Answers
Seems it may be switch related. More info please. Thnx
Posted on Nov 15, 2012
  • 209 Answers
SOURCE: Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Posted on Sep 16, 2007
  • 185 Answers
SOURCE: How to replace heating elemant on Zanussi DE6850 Dishwasher
is your water heater set on 120 degres
Posted on Mar 31, 2008
SOURCE: Dishwasher Heating element not working
my wife shut the water off to the dishwasher and forgot to turn it back on and then used the dishwasher.
the heating element went on but there was nop water.
when we turned the water back on,the drying cycle does not work.i would think that the element needs to be changed or is there a relay on the computer board?
this is a two year old Jennair unit.
any suggestions?
Posted on Apr 29, 2008
SOURCE: Dishlex DX302SB Dishwasher water not
Who posted this comment I am really appreciative. I have had the same problem with my dishlex. I disassembled the plumbing and removed a chunk of plastic wrapping from inside the pump. Then I checked the heater with a multimeter. It measured fine.
The next day I read this post and have since removed the controller. I found the burnt solder joint mentioned. I have since cleaned up the mess, repaired the circuit board, re-soldered the effected component and the dishwasher is now working better than ever.
I have read elsewhere that this problem arises when the door is opened while the heater is on and the program hasn't been paused. I don't know if that is the exact cause but in my house we will be more careful about that from now on.
The damage to the circuit board was on the Normally Open terminal of the relay used to control the heater. The heater is marked as being about 2100 watts. The relay is marked as being able to switch 125Vac. Which is interesting because power here in Australia is 240Vac. At 240Vac the heater will draw a little under 10 amps when operating.
Anyway the circuit board trace is possibly a little narrow at the point where the burnt connection was and I can see why it would have burnt out. The other terminals on the relay were showing signs of becoming dry joints too. The repair was effected by completely removing the relay, cleaning all the joints, re-soldering the relay and laying a loop of tinned solid wire around the burnt terminal to replace the missing piece of circuit trace.
Anyone who has a little skill with a soldering iron could perform this repair. The worst that could happen is you could lift what is left of the circuit trace from the board. Since the controller is already broken you can have a go and probably save yourself the cost of a new controller.
Posted on Apr 08, 2009
SOURCE: My DX302 dishwasher wont heat the water, the
Yes I had the same problem with the DX302. One of the solder joints on the relay was cracked but hardly visable. Resoldered it and no problems.
How to do it:
Make sure you turn off the power at the wall and pull out the plug. To get to the circuit board remove the screws on the inside top of the door and pull out the front panel (where the buttons are). Press the little clips and the white box containing the circuit board comes free. Remove all the plugs and lever open the small clips holding the box shut. After you open the box pull the circuit board up and have a look at the contacts under the black little box (relay). Use a soldering iron and some flux cored solder and redo the joints. Put it all back together and turn on to see how it goes.
Worked for me.
All the best......
Posted on Aug 05, 2009
Have a whirlpool dishwasher model number 854241615810 The problem is that it doesn't complete a cycle and the start button flashes 3 times then a pause then 3 times . The water doesn't get hot eithe
The three flashes is the error code for a defective heating system. Usually this is a bad heating element that needs to be replaced, though it can also be a faulty control circuit or thermistor.
Oct 21, 2012 | Dishwashers
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
I have a Westinghouse SB915SJ*00 dishwasher. It runs right through a cycle but does not heat. Any suggestions? Thanks.
Hello
The majority of dishwashers are not connected to hot water from the mains but heat up the water internally using the heating element, located in the tub of the dishwasher, controlled by a thermostat. When the dishwasher has a fault with heating, the program will run but not complete and will show an error code on the display panel. Dishes won't be cleaned properly and the detergent won't dissolve.
If your dishwasher does bring in hot water externally from the mains to check the water is warm and there are no problems with the inlet. If the dishwasher heats internally then it is most likely a faulty heating element or thermostat. A fault like this will usually require a replacement part and a repair, but you can check the heating element with a voltmeter to ensure that it is the cause of the problem before calling out for a service engineer.
Sep 10, 2011 | Dishwashers
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
Frigidaire dishwasher not completing cycle.
hi,
Water-heating cycle
Timer
Water-heating cycle
Timer
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Jan 03, 2009 | Dishwashers
I have a Bosch SHV55M03GB dishwasher which does not heat the water. The programme cycle also sticks at the last minute. Any ideas, heater element or control panel? Thanks.
If cycle proceed normally after waiting for a while, then the control is probably OK. It stands by a while because it does not read correct temperature before proceeding.
If the appliance is connected to both hot and cold water, open more the hot water faucet.
If the water is not heating at all, check heating element for continuity, using a tester.
If water is heating regularly, but cycle is still slow, check thermic sensor.
Here are more suggestions from Repairclinic:
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
If you need replacement parts or exploded views you find them here.
Oct 10, 2008 | Dishwashers
Timer on dishwasher not working
ok start the washer after it fills and starts washing open the door again and turn the dial to drain shut the door see if it drains if it does then open the door and turn it to heated dry shut the door and get you a small glass of warm water let it sit in heated dry for about 3 minutes open the door and pour the water on the heating element and let me know if it sizzles
Mar 27, 2008 | Dishwashers
Dishwasher not completing cycles
Is the water being heated??? When the timer reaches the stage where it will not move forward any further, after 5 minutes or so, open the door & see if the water is heating up. The timer often waits for the water to reach the correct temperature. Temp is measured by the thermostat. If the element tests OK, then it could be the relay that switches the element. The relay is turned on & off by the timer. I would say that if the timer is OK & the element has the correct resistance, then it is is more likely to be the relay. Last resort would be the thermostat, but my money is on the relay.
Jul 31, 2007 | Frigidaire FDB641RA Built-in Dishwasher
Dishwashers Logo
197 people viewed this question
Top Dishwashers Experts
Owen Barnes
