Question about Sanyo Televison & Video
Pop sound and now no power
Hoping it is just a fuse.
    Top Expert:
  • Sanyo Master
  • 14,553 Answers
Fuses themselves rarely make a sound---lately seeing a lot of this sort of thing----you can look for something damaged but most of the time it is in a place where it cannot be seen---voltage tests would be needed here to see what is working and what is not.
Posted on Nov 01, 2012
Fuse rx 570 pioneer stereo
Sounds like you have a much bigger problem than just a fuse. Popping sound and burning smell means something much more serious.
Jun 18, 2013 | Audio Players & Recorders
I have an 81 gs 750 i went to fire it up a few days ago was cranking over about to fire up then something popped electronically now my whole ignition system is dead no lights on the cluster no power...
Hello David, the "pop" hopefully was the main inline power supply fuse. If you were jumping starting with a car battery, it could be more serious if the fuse did not blow fast enough. Follow the positive cable off the battery. You should find an inline fuse, somewhere in the heavy gauge wire. Usually 25-30amp. If you have a 12vdc test light, it will help to locate. I hope this information is helpful.
Oct 08, 2011 | 1981 Suzuki GS 750 L
I have a 2004 Mitsubishi Endeavor I heard a loud pop above the glove box and the stereo turns on but there is no sound
Power amp IC problem.
The loud pop came from the audio power amp in the stereo unit. It was cause by a shorted wire going to the speakers.
Check first the amplifier fuse if it still okay, located at the stereo harness, you have to remove the stereo unit to check on it. If that fuse is still okay, the problem is much worst you have to bring the stereo to any electronic tech shop to have them replace the audio IC( Integrated Circuit ), soldering is needed to replace it.
Hope Fixya helps you out!
Aug 28, 2011 | 2004 Mitsubishi Endeavor
The remote or power switch will not turn the TV on, does it have a reset switch
Most likelly you have had a power surge through your house and it blew the fuse inside the tv. If you take the back panel off the fuse will be by the power cord becarefull and pop out the old fuse if its burnt or the metal wire is missing on the inside then you just need to replace the fuse with the same amps and voltage as the old fuse. If you read the motherboard where the fuse goes it will tell you what type of fuse it calls for.And when tvs work fine one dau and then the next wont even make a sound when hitting the power button 9 out of 10 times the fuse is the issue. GOOD LUCK too you and HOPE this helps!!! Good day!!
Jan 02, 2011 | Televison & Video
When i started to plug my battery in my amp made
you have blown the actual filters that make the sound. a amp is basically a filter with the same filters on both channels on each side of the inside of the amp - channel 1 and channel 2, that pop was in the heat sinks of the amp usually. if you have replaced the fuse in this amp and you get no on light, the internal amp is in need of repair
Oct 24, 2009 | Rockford Fosgate Punch 401S Car Audio...
LG 50PC1DRA POPS AND SHUTS OFF
Your right its a power supply issue and what your hearing is capcitor pop or maybe even a fuse, Well if you know about eletronics sure the new psu is going to be $150 bucks
hope this helps
Jul 18, 2009 | LG 50PC1DRA 50 in. Plasma Television
Tv plays sound but no picture or any signs of backlight
This sound is a capcitor pop and this could be in the power supply unit itself. The glass could be a fuse that took the brunt from the capcitor pop.
1. Unplug the unit and do not plug it in.
2. if its under warrenty take it in please!
3. if its not under warrenty and you know eletronics verify what cap popped and replace that and the fuse.
4. if you do not know about eletronics this work would cost you around $150 for the wrok done.
Good luck I hope this information helps you!!
Jul 17, 2009 | Vizio L32 32 in. LCD HDTV
Trunk won't pop with keyless remote or button on dash
Check antenna fuse with 12V test light. and seperately chech the #22 fuse 20A for the trunk release, Sounds like 2 diff problems. Hope this helps.
Apr 07, 2009 | 1998 Cadillac Eldorado
Bass pops
Hi There, Have you checked the 3 fuses that clip onto the main amp board? You can access them by undoing the two screws that are on the top and the bottom of the sub. They have flat large heads and you will need a hex key to unscrew them. If it is one of the fuses that has gone it will either be discoloured as in burnt or you will see the metal inside has split. Simply replace these with a new fuse and hey presto you should have eradicated the popping. If you need any parts for the sub or fuses then www.LondonSpeakerShop.com will be able to supply them (that is if you're in the UK). Hope this helps. Grant (from www.LondonSpeakerHire.com)
Feb 01, 2009 | Mackie SWA1501 Subwoofer
No power
Probably blown fuse on the power board. If you hear a "pop" sound, you have blown couple of fuse along with some other components. When a small fuse blows you cannot hear any sound. Camera needs a new power board and repair cost may run from $175-275 depending on damaged parts.
Mar 16, 2007 | Sony Handycam DCR-TRV230 Digital Camcorder
Televison & Video Logo
19 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
