Question about Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman dual fuel - troubleshooting steps
Stove won't light...what steps beyond following the directions should I work through other than throwing it into the fire?
  • Anonymous Feb 28, 2009
    Stove will not light. Just air seems to be coming out.
Got my solution by talking to a fellow at REI. He showed me how to take the Coleman apart and check for problems.
Posted on Jan 05, 2009
How do i light 533
can you tell me more about your model?
Mar 14, 2014 | Coleman Camping, Backpacking & Hiking
I got out my old camping stove a colemans dual fuel I used to put in petrol but I cant remember how to use and I am giving all my camping things away, what does the dual fuel mean. I would love to get it...
The old Coleman Camp Stoves used White Gasoline or petrol. However, that is no longer approved and has been banned as a safety issue for some years now. With that said, you have a real antique and if it's in decent condition, is worth some money to collectors of old camping equipment. You may want to rethink giving it away (because, it can't be used as a camp stove any longer) and sell it to an antique dealer or collector.
I hope this helped you and thanks for choosing FixYa.
Aug 22, 2011 | Coleman Grilling
I have use Coleman fuel in my stove..is that ok? Also can't get it started
The Optimus Nova is a multi-fuel stove. Coleman fuel will work in the Nova. Coleman fuel, generically called "white gas", is a chemically pure form of gasoline, same as what you put in your car but with less impurities.
The nozzles all liquid fuel stoves can clog from time to time. Follow the instructions in the manual for cleaning. If you don't have a manual you can find it at:
http://www.optimusstoves.com/seen/optimus-products/products/katadynshopconnect/optimus-outdoor-kocher/
Hope this helps.
Mar 29, 2011 | Optimus Nova Stove
VALVE WHEEL LEAKS
Here is Coleman's repar part website.
You may want to replace the valve if it is leaking.
http://www.coleman.com/coleman/parts/product_category2.asp?category_id=210
Jul 21, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman 424 Dual Fuel -- High, yellow flame
Are you pumping the tank up all the way? I have the same problem if I have too little pressure in the tank. The instructions say pump 35 times. Try pumping 50 or 60 times- that seems to help.
Also, you can't light this one like an old 425. My old stove you could turn the gas on and then take a match neat the burner. For this stove, hold the match near the burner with the gas off and quickly turn it on.
These are two things that seemed to help me with the same problem.
Jul 11, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman propane stove problem
The connector for attaching the regulator to a disposable propane cylinder has a sintered bronze filter in the tip of the brass probe tube that is prone to clogging, or the bronze pellets get mashed down over time, restricting gas flow, and this will cause a portable grill or camp stove to perform poorly. The filter is so fine that it takes very good eyesight and bright light to see that it isn't solid metal, or use of a strong magnifying lens. The best solution is to buy a new Coleman regulator assembly. If you are unable to get a new regulator assembly and have the skills and the tools, you can try drilling a very small hole on the side of the probe tube with a #60 drill bit, just below the bronze filter, but near enough the end of the tube so that the hole will be past the plastic seal when the disposable cylinder is fully screwed into place. You should avoid drilling directly into the end of the probe tube, as the end of it is used to depress the Schrader valve in the disposable cylinder to allow gas to flow. A #60 wire gauge drill bit is only 0.040 inch (1.016 mm) in diameter, but makes a hole large enough to supply sufficient gas to a portable grill or a dual-burner camp stove. If you choose to perform this work, the probe should be unscrewed from the regulator body and the Schrader valve core in the probe tube should be removed before drilling. Be sure to clean all brass and bronze particles out of the probe tube before re-installing the Schrader valve core and the screwing the probe into the regulator. Use a removable-grade thread locking compound to secure the probe in the regulator body and don't over-tighten it, so as not to crush the rubber gasket. Allow the thread locking compound to cure for several hours before attempting to use the regulator. Keep in mind that this modification increases the likelihood of dirt getting into the needle valves and jets of your stove or grill, which can cause maintenance problems in the future.1_28_2013_4_49_27_pm.jpg
Aug 19, 2008 | Coleman Gas Grill Stove
I have an older (20 yrs) coleman cook top camping stove that does not work. It runs on coleman fuel. What are somethings i can try to fix it
Here is Coleman's web support. I also need some work on my stove.
http://www.coleman.com/coleman/manuals/manuals_resp.asp?category_id=1100
Jul 07, 2008 | Kitchen Ranges
Thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Coleman 2 Burner Dual Fuel 424-700G Grill Logo
1,055 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Treefrog15
Treefrog15
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
