Our thermofax will turn on but won't feed stencil paper threw and bulb won't turn on and its used to make tattoo stencil
Cogz
  • 1326 Answers
SOURCE: thermofax machine repair
Not really sure what you are asking? Is it a thermofax that is making noise that you use to make transparency with. Or is it transparency making? I never worked on a transparency maker in 20 years of office machine repair... What is it? Is a old machine? If it is that old it may be time to replace it....
Posted on Mar 31, 2009
SOURCE: I need to know how to convert a 15 amp thermofax
Any luck on this? I'm in the same boat.
Posted on May 28, 2011
matandacosma
  • 66 Answers
SOURCE: The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Posted on Jul 13, 2011
SOURCE: green light for paper feed
paper start sensor is not functioning properly. clean it or replace it.
Posted on Jul 15, 2011
matandacosma
  • 66 Answers
SOURCE: Sharp AR-205 misfeeds at transport area from both
it means the drum is not moving check it, insert it properly. or therre is a broken gear somewhere or the motor that makes the drum to rotate is not working properly. The registration sensor not working or not postioned properly.
Posted on Aug 02, 2011
How come my tattoo power supply won't turn on
Bad fuse in the power supply you may need to replace that
Oct 01, 2013 | Computers & Internet
Fabric won't move threw machine, feed dogs are working.
Try adjusting the pressure on the presser foot, or make sure your feed dog are in up position and moving forward
Jan 06, 2013 | Sewing Machines
Fabric won't feed threw machine
it sounds like the feed dogs are not working, can you see them in the
needle plate area? you should be able to see them and feel them
with your finger. what is the name and model of the sewing machine?
Nov 28, 2012 | Singer Featherweight 132Q Mechanical...
Gestetner 6123 paper jaming feeding section copy printer
nrg 6123 copy printer after make stencil line on copy soulition
Jun 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
MY TATTOO MACHINE IS GETTING HOT
too much voltage, too much amperage, your springs may be too heavy, and the return on your armarture/contact spring should be bent just a little to help it assist forward motion in the direction of the coils. play around with the armarture height and bend your springs while trial and erroring (*******, i know it's not a word) at low voltage like 5.5-7.5 volts. if it hits hard, sounds consistent and doesn't kick back or stick you won't overheat. A better power supply may just be the ticket though. spend at least $80 bucks on one. anything cheaper will feed too much power, inconsistent power or will not feature short circuit protection so the moment a coil stick happens your PS blows. stay away from digital power supplies (the little dinky box ones that look like late 90's GPS beacons) and only run your machines momentarily while tuning, when it's tuned you should know it immediately within the first few strokes based on the sound. You should already know all of this if you are tattooing, but I wont give you heat because I know some scratchers that do better work than Kat Von D and Tomas Tomas, just saying. If you are scratching please for the love of sweet baaaaby Jesus, ONLY USE DISPOSABLES and NEVER go without BARRIER PROTECTION aka, wrap it up. - Professional tattoo artist; Brian @ Foxy Tattoos, Raleigh, NC
Mar 12, 2012 | ART Cast Iron Coil Tattoo Machine Liner &...
My Canon Pixma MP495 series says paper jam but there is no jam!
Hi. In the paper path is a plastic flag sensor . That detect theif there is paper or not . Maybe there is something activating it may it can be a small piece of paper or a foreign object. That sensor is located in the back side of the rollers
Feb 26, 2018 | Canon PIXMA MP495 InkJet Printer
Thermofax machine repair
Mar 30, 2009 | Office Equipment & Supplies
I have a 3m thermofax 45cg every paper run through is completely
I am a major seller of these machines in ebay. The machine may need a new potentiometer. Build a carrier. Put two pieces of transparency plastic sheets together with a piece of tape and use this to carry your stencils. This will reduce the heat of the lamp. Rouben (rouben@ektalc.com).
Mar 23, 2009 | Office Equipment & Supplies
Can you use thermal transfer paper
The paper will probably come out black after being heated by the fuser. 350 degrees.
Jun 07, 2008 | Brother IntelliFAX 885MC Plain Paper...
46 people viewed this question
k24674
jasbo
jasbo
