Question about GE Kawasaki Ge2200 Ge2900 2200 2900 Service Manual
What kind of oil do I use in a kawaski ge2200 generator?
What type of oil should be used in this generator?
What type of oil is required for this generator
You have not specified the make and model of the genset. Usually the normal type oil used for petrol /diesel engines can be used typically the grade 40.
Please look up on the manual to be more specific.
Nov 21, 2011 | Electrical Supplies
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Correct oil for this generator
This all depends on what type of climate you live in. Most small engines that (do not) have an oil filter uses SAE 30 motor oil. This oil has a detergent in it that helps clean your engine.
Dec 01, 2010 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
I would like to know what type and how much oil do I use in my powermate generator with the Subaru 10hp engine. thanks you
Your small engines require ordinary 10W30 motor oil.
Don't turn machine on its side or upside down to drain oil, or oil will run into carburetor.
Use a plastic hose to remove old oil
Oct 22, 2010 | Coleman Powermate Premium Plus 6250W...
What type of oil do I use 1850 pm0401850
Oil Type. Use new good quality oil such as SC, SD, and
SE grades. The oil to be used depends upon the temperature
at which the engine is operated:
Summer: (temperatures of over 40 degrees F/10 degrees
C) SAE 30 or SAE 10W-30, SAE 10W-40
Winter: (temperatures of below 40 degrees F/10 degrees
C) SAE 20 or SAE 10W-30
Manual here:
http://www.powermate.com/pdfs/2007/11/12/pm0401850-52.pdf
Sep 12, 2010 | Coleman Powermate Powermate 5000W...
Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Apr 04, 2009 | Watts Onan Portable Generator - 4000 ,...
Can i use synthetic oil in my new onan 6500 portable generator
Johndeere 10w-30 in cooler weather and 5w30 in warmer weather. Any auto parts store has small engine oil. They may have a better idea when you go to purchase your oil for your particular climate.
Jan 08, 2009 | Watts Onan Portable Generator - 4000 ,...
Need oil type for generator & motor for 5000 power mate
Unless you're in very cold locations use SAE 5W30 regular motor oil.
Dec 03, 2008 | Coleman Electrical Supplies
Oil type and capacity
Use 10/30 weight oil fill till : " if it has a "dipstick" fill to middle of hash marks" if not, There in the hole for the oil filler cap their is a knotch cut out of the theads for that cap. fill to just below the top of that knotch . drain plug on bottom of crankcase
Sep 01, 2008 | Coleman Powermate Premium Plus 6250W...
GE Kawasaki Ge2200 Ge2900 2200 2900 Service Manual Logo
205 people viewed this question
Top GE Electrical Supplies Experts
Steve
Lawrence Oravetz
robert
Are you a GE Electrical Supply Expert? Answer questions, earn points and help others
