Question about Sony Televison & Video
Television takes 10 minutes for picture to come on
I have a Sony Trinitron KV-29XL5 television about 10 yaers old. Lately the indicator light on the front panel has started flashing continuously and after turning on at takes about ten minutes before the picture comes on the screen. The sound is instant. Is this likely to be an expensive repair? Is it worth repairing
    Top Expert:
  • Sony Master
  • 75,571 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there
Posted on Nov 01, 2012
SOURCE: sony trinitron
change the trc
Posted on Aug 11, 2007
SOURCE: Sony Trinitron KV-27FS13
set in shut down. Hasve power supply problem. Need a TECH.
Posted on Feb 12, 2008
welcomejee
  • 10594 Answers
SOURCE: Problem withmy T.V. ( Sony Trinitron Model KV-27FS13
do u wanna repair it urself?
Posted on Jul 30, 2008
tvtek
  • 1284 Answers
SOURCE: Sony Trinitron TV now taking around 5 minutes for
If the timer light flashes while waiting for the picture and once the picture appears if it looks like the colors are out of balance and the edges of the picture are out of focus then yes time to let it go. The issue at that point will be the picture tube itself is very weak and would need to be replaced. In most cases the CRT's are no longer available. Please take a few moments to rate my response. Thank you..
Posted on Nov 17, 2009
Testimonial: "Thanks for your advice"
caroldon
  • 17130 Answers
SOURCE: Sony Trinitron Colour TV, Model KV-29LS3OU The red
Sure this is tough one as the model is old. But when the red light flashes the set is powering up and the line output transformer is bringing up the voltage to the CRT stages. The time delay is the decay of the voltage to the circuits mainly due to aging of the components--maybe capacitors- or a possible section of the video-Y board having a series of DRY soldering.
Now you can attempt to see to these issue to evaluate.
First of all one you are confirmed that only when the set warms up the picture starts to come in, then we can simulate the fault by using a hair dryer to warm the suspected parts, mainly try on the section of the Y amp IC and the LOT section.
Checck for a faulty 22mfd or 10mfd with 25o volts capacitor on the LOT secondary to the CRT to be faulty, replace.
This can cause delay and poor picture quality.
Also if the contrast section of the Y amp is faulty you may get this faded situation of picture and colour.
Next use a good soldering iron to touch up the soldering of the
Y/C amp. This can be having poor joints and can be a possible suspect too.
The final part can be the picture tube itself but the fading would have very gradual and with a particular tint in domination.
I hope the tips can get you to work and find a solution.
The Tv is a good one and if the set works it can still give more hours of use.
Posted on Aug 31, 2010
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Timer delay light flashes wont turn on
Depending on how old the set is, if over ten yaers old not worth fixing because sony had a bad picture tube for that model and it would start dawning to much current and wipe out the high voltage section,. and if you repair it , about six months later it has a good chance of going out again, I wouldbuy a new set.
Oct 24, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 10 yr old Sony FD Trinitron WEGA 32" Flat
Hello jorge and welcome to FixYa. With your particular model of television six blinks mean a Horizontal Drive Failure has occurred. If you have any television repair experience you could try checking the jungle for loose or possibly bad soldering. In some case the jungle IC was found to be defective on this model as well. You should also inspect the horizontal drive transformer windings if at all possible. If you are unable to repair this yourself I would personally say to you no it is not worth the cost to repair it as purchasing a new television would probaly be a more prudent decision. I hope you found this helpful and thank you for visiting FixYa.
Apr 23, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have wega KV-HR36 red light flashing 10 times
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 11, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Help with sony trinitron problem
Are you serious? You have used that television... in particular that CRT well beyond its predictable lifetime.  Congratulations.  Those are early symptoms of CRT failure.  Your screen may turn green very soon also.  It will occur any moment now.  It is not cost-effective to repair.  Welcome to the next generation.  You will be amazed and delighted with LCD, plasma or DLP technology. existencebeyondperception@msn.com
Oct 10, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sep 03, 2006 | Sony KV-27FS13 27" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
