Question about Toshiba 50AX60 50" Rear Projection Television
I have a 2001 Toshiba 50A60 TV Can I use an HD cable box with it?
I recall when i bought it that it had very high resolution, but there was hardly any HD programming at that time
  • bobnjanice Jan 04, 2009
    I'll switch out the current cable box for an HD one and check it out. Thank you.
  • 20 Answers
The specs I found show that it has 800 lines of resolution. It also has component video inputs. In theory, it should be able to display HDTV at 720p if you have a receiver with component video output.
Posted on Jan 04, 2009
I have a 50A60 toshiba 50 in rear projection tv I have a green screen no pic but I have sound
Is there a cable or Satellite box hooked up for signal?
How and where is signal connected to the TV?
Dec 13, 2012 | Toshiba 50A60 50" Rear Projection...
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I have Toshiba Theaterview 50A60 projection TV ( built April, 2001 ) with a broken front screen. Anyone know where to find one??
http://www.partstore.com/ give them a call. If they don't have it, the can tell you where to get it or maybe order it special for you. Good luck!
Oct 09, 2010 | Toshiba 50A60 50" Rear Projection...
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba 50A60 Projection TV - Black Screen
There is no bulb in that model TV. There are 3 crt type tubes. You'll have to have a TV shop determine the cause. It could be many things like no high voltage present, cathode voltage missing. If the tubes are finished, the cost to replace them is quite high. It is a complicated repair since the tubes have to be properly aimed and converged. The repair cost in this worst case scenario would be greater than buying a flat screen TV with the same screen size.
May 17, 2009 | Toshiba 50A60 50" Rear Projection...
Toshiba Regza "blink"
It's your TV switching resolutions, nothing you can do about it. Sorry.
Jul 28, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
HD-A3 Movies Don't Play Video, but Menus are fine?
Might be a resolution issue, the menus are most likely in 480, while the video might be in a resolution not supported by your tv. Try changing the resolution and see what happens.
Jun 29, 2008 | Toshiba HD-A30 HD-DVD Player
Only get 480p
Hi.
Your friend is wrong you will get same resolution of 1080i whether you use component or Hdmi.
But you will need a high def input to tv in order to get this resolution EG high def cable box or satellite.
http://dysonmanuals.llc.nu/
Mar 24, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Is this TV High Definition
Your Toshiba 32HF73 is a high definition TV. So good ahead and get the HD cable box and enjoy the picture on the HD channels! Please give feedback if I answered your question, thanks.
Jan 16, 2008 | Toshiba 32HF73 32" TV
Toshiba 50AX60 50" Rear Projection Television Logo
130 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
