Question about Elmo Projectors Elmo TT-12 | Elmo TT12 Document Camera
My elmo won't zoom in or out. It appears to be frozen.
Was frozen now thawed w/ new fuel filter still won't start
Fuel pump may have ailed this time.. You need to have fuel pump checked.
Jan 31, 2013 | 2000 Ford Explorer Eddie Bauer
Won't charge
You have a Dead Kodak !!! needs to go to shop.
Sep 24, 2012 | Kodak EasyShare M532 Digital Camera
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
Need diagram to correctly insert cushions back into Sesame St Elmo flip open sofa after washing cover so that it will fold in & open out without gaps
I know this questions was posted a while ago, but I have been searching the internet for at least an hour and could not find an answer. Finally I saw a product picture that gave me the clue I needed. I have drawn a diagram to help those like myself who are visual learners, but please note that I am NOT an artist so my diagram is not the best. The biggest direction I can give is when you lay the 2 pices of foam that have the angles together, they need to make a triangle with the ground, or an upside down V. I hope this helps any frustrated parent/guardian in the future. I know I won't forget how to do it again! :)
Mar 31, 2012 | Sesame St. Sesame Street Elmo Flip Open...
Can i convert to a dvd i have a trv-35h elmo
You can very easily. You may use the S-VHS output on your Elmo ( a 4-pin DIN socket on the rear) going into the S-VHS input on your DVD player. You will need an S-VHS cord. Very cheap at Radio Shack or on Ebay. This gives the best quality. Our you can use the more familiar RCA composite video output (yellow socket) from the Elmo into the composite or auxiliary input on the DVD recorder.Be sure you have selected the proper input on your DVD recorder. Use a TV set as a monitor so you can see what you are recording.When I convert slides to DVD, I do a test run through the carousel to be sure the slides are all facing the right way, not upside down or backward.I set my Elmo timer on 5 seconds and let the carousel advance automatically. You may want to zoom in or color correct as you convert. In that case, pause your DVD recorder between slides, make your adjustments, then resume recording. This is called assembly editing. It works very smoothly and you get a better show,
Oct 28, 2011 | Elmo Projectors TRV-35H Slide Projector
I've bought a new samsung pl121 camera & taken a
Your camera is obviously defective. It may have been a return and resold to you. In any case, you should return it immediately....this problem will only get worse.
Aug 20, 2011 | Samsung Cameras
Zoom dial is broken teacher overturned it
don't have a solution but I have two Elmos tt-02s with the same problem
Feb 11, 2011 | Elmo Projectors Tt-02s Slide Projector
Elmo zoom dial fell off
I am Frank Kemmer, president of ShopVSC.com, one of the nation's largest Elmo document dealers. The TT02rx has a five year manufacturers' warranty. To get warranty service go to the link listed below:
http://www.elmousa.com/files/service1.pdf
Fill out the form and put it in a box along with your defective TT02rx. Ship both to the address listed on the warranty form. Elmo will typically repair or replace the unit within a matter of days and return it to you at their cost.
If you have any service issues feel free to contact me directly via our website:
http://www,shopvsc.com
Oct 26, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
ELMO Projector image not working
Hi schmidtkm
All the sympoms mentioned above is that of a faulty Mainboard that will have to be either repaired or replaced.
Trust me on this one , I work on Projectors every single day of my life.
May 12, 2008 | Elmo Projectors EV-2000AF Multimedia...
Frozen zoom lens
Sounds like there is a misalignment internally. This will probably need to be repaired at a shop.
Nov 02, 2007 | Nikon Telephoto 500mm f/8.0N Reflex Manual...
Elmo Projectors Elmo TT-12 | Elmo TT12 Document Camera Logo
62 people viewed this question
Top Elmo Projectors Video Cameras Experts
Are you an Elmo Projectors Video Camera Expert? Answer questions, earn points and help others
