Question about Pioneer SD-532HD5 53" Rear Projection Television
Possesed awesome tv
I have a sd-532hd5 53in it will stay on for 5 min. sometimes 5 hours sometimes all day. You can never tell. anyways please help it always makes the same clicking noise when it shuts off but that may be normal. Thanks
    Scholar:
  • 121 Answers
The clicking noise is probably just the relay. I gyess it makes the same noise if ou turn it off manually with the remote? Does your TV have a sleep timer function? Check to see if this is enabled. You might also check the batteries. If they are old, or the battery compartment is dirty (leaking barteries etc) you might get strange behaviour. My remote lives a life of it's own, changes channels etc if the batteries are weak.
Posted on May 18, 2007
Hi i bought a 3 years used samsung tv smart 3d 60 " and the tv turn off and turn on it self randomly sometimes it stays open 2 min , 5 min and sometimes dont even close for 5 , 6 hours straigth .. i was...
In most of the case, the problem is the main board, you may try the below procedure to fix the problem:
Re-Flow Soldering Procedure for Main Board
    1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
    2.Put the main board on a card board (like a pizza box board) in the oven;
    3.Heat it for 10 minutes (No more than 10 minutes);
    4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
    5.Install the board in the TV & try it out.
Aug 30, 2017 | Samsung Televison & Video
My 47in lcd tv lg turns off after about 2 hours of use then every 5 min if you turn it off and back on it will stay on for 5 min is it worth fixing?
hi yes it is worth fixing,could be capacitor fault try and find a tv tech in your area hope it helps
regards
shaun
Jan 08, 2014 | Televison & Video
Panasonic 60" LCD Projection TV Turns off every 1-2 hours
What is the model# of your TV?
Do you see any blinking (LED) lights on the front of the TV?
How many blinks?
Which LED light is blinking, Power, timer or lamp?
Nour Sabre
www.aaatvservice.com
Nov 15, 2011 | Panasonic Televison & Video
Mitsubihsi WS 55311 will not give codes when pressing the input/menu buttons on TV. Tv will shut down in about 5 mins the I canturn it back on. After I press the buttons on the TV it will stay on for a...
This is a V20 chassis and if it shuts down it should trigger an error; note if no error the power light should blink 1, 2 pause and repeat it several times---this is no error found.
I would unplug the set for a few minutes (this clears the error buffer) and turn on again and wait for failure; you must push menu and input and hold for at least 5 seconds and let both go.
IF no error code this is a model made around 2002 (date will be on back of set) and it must display some error code.
If you find none I can suggest looking for any signs of Glycol leaks inside the set. If you need to know what to look for let me know and I will tell you.
Again: All models after 2000 (and some before) have the error buffer.
Let me know if you have questions.
SD TECH
Nov 02, 2011 | Mitsubishi WS-55311 55" Rear Projection...
My mitsubishi 60 in turns off by its self some times 5 min after you turn it on sometimes 5 hours and sometimes 5 days. you can tell when its about to turn off by line that flash on the screen. then they...
Well if your tv is older like the one in the pic it sounds like the bulb is overheating, you may want to vacuum the dust out of the back and make sure it isn't got block of air flow in the back and also make sure it isn't up against a heat source
Feb 19, 2018 | Mitsubishi VS-60607 TV
Mitsubishi WD-62528 error code 45
go to the manufacture site they should tell you what the code means if not try techlore.com
Feb 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Our TV shuts off inertmittenly
Yoke connectors require resoldering. Find a shop that has done it before. Alignment is necessay after soldering
Jan 03, 2008 | Mitsubishi TS-50601 50 in. Rear Projection...
JVC AV-36950 TURNS OFF
Replace C953 1000mf / 35v in power supply....capacitor
top will appear slightly bulged or will check bad with
ESR meter...........................T.
Dec 02, 2007 | JVC AV-36950 TV
Pioneer SD-532HD5 53" Rear Projection Television Logo
118 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
