Question about Dell Computers & Internet
I ve tried removing the hard disk still not coming up even on a power supply, pls what's the way out?
  • Nick Oct 31, 2012
    We'll need more information first.Desktop/Laptop?Make and Model?
  • Dell Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry. They will air dry in a matter of minutes
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps
Posted on Nov 01, 2012
  • 11800 Answers
SOURCE: armada m700 working fine. oneday got message 1782
 disk controller failure - the chip from the laptop's motherboard that's controlling the disks is fried. Nothing you can do - all hd's will be unrecognized - that laptop is dead.
 Buy a new one.
Posted on Oct 30, 2009
Testimonial: "thanks for a direct understandable answer"
  • 68 Answers
SOURCE: My toshiba satellite a205 will
If it does the same thing w/ the battery removed and just on AC, it's a power regulator problem on the motherboard. If it works with the battery out, the battery is dead and you need a new one.
Posted on Jun 30, 2011
durtopian
  • 408 Answers
SOURCE: tried installing xp, ever since at boot up it says 'invalid system disk'...
You will probably have to get another XP disc and do it.The one for your desktop isn't valid for a fresh install on your laptop i don't believe.
Posted on Nov 23, 2011
emissionwiz
  • 80637 Answers
SOURCE: I Have A Gateway NV55c That Will Not Boot!
After much time and frustration you will end up reloading the operating system, the reason is it is corrupted, why this happens is not always the same, but the fresh copy of the operating system is the cure. You will need the recovery disks do this, you were either given them with the system or you were prompted to make them when the computer was new. If you don't have the recovery disk set then call the parts dept of the computer maker for ordering instructions, they run about $25
Posted on Feb 15, 2012
  • 76 Answers
SOURCE: compac s7300cl wont turn on
Ok it seems *********** board may be dead. However, you can take out the hard drive and place it in an external hard drive storage unit/box
and plug this into any computer, and WALAH! You have another
drive letter, which is your old hard externally. You may now get your pics. You can access them via any photo software; however, you need to make sure that you save them on another drive letter, and or folder. Not the external drive Letter it may be called D or E.
Posted on Sep 17, 2012
Desperate to get my Dead Desktop going again................
I always start with the power supply. Your power supply may not be producing all the power your motherboard is requesting, even though the light on the back is on. If you dont have a power supply tester, then you can try removing your power supply and trying a known working supply in it, making sure you have the right connectors on it for your motherboard..
I looked at a pic of your motherboard Asus A8n-vm and I dont see an orange (or any) button to push. Was that to reset your bios? If so, unplug the system from the wall, and carefully remove the battery from the motherboard. While it is out, push the power button on the front of the computer a few times. The computer wont start up, as you have it unplugged, its just to drain the motherboard of power to reset the bios. Then reinstall the battery, making sure it goes in the same as it came out (- is usually down and + is up). This should reset the bios info to the factory settings.But I still think it is a faulty power supply.
Feb 03, 2013 | HP Pavilion a1520n PC Desktop
NEW MacBookPro crashes! I just bought a new macbookPro and it has crashed on three different programs; won't download the manual from online (get the beach ball) and makes a sound when power-ing u
The two "whirring" noises that you hear on power up is normal. The beauty of having a new macbook is you can reinstall the software very easily and a fresh install should fix your problem. Put the disk that came with the machine into the disk drive and turn the computer off. Turn it back on and press and HOLD the "alt" button until you are given the option of booting from your hard drive or your disk. Choose the disk and when it boots up, FIRST go to disk utility and verify the hard drive. If it comes back with no problems, proceed with the fresh install of the system by following the prompts on the disk.
Jul 07, 2012 | Apple Computers & Internet
SimpleDrive 500GB 96300-41001-160 shows no activity
I think you bought a piece of junk especially if you cannot hear the hard drive spin when you connect the power supply.
I suggest you get a tech savy friend to check out this hard drive for you.
Apr 13, 2012 | SimpleTech SimpleDrive Hard Drive
I have a Acer Ferrari 4006wlmi, which I'm trying to figure out what's wrong with it. It does turn on but HD indicator just stays lit (no flickering as to say it's accessing), it was undergoing...
Please remove the laptop battery and disconnect the Ac power. Then press POWER ON button and hold for 1-2 minutes. Then power on with the AC adapter only. Then start the laptop. It will powered on. After that shutdown laptop and reinsert the laptopbattery.
Even it wont work, remove the battery, hard disk and ram. Just insert the RAM and try to check the display. then insert hard disk and check the working nature of laptop on AC power only..
Further any clues please provide the feedback..
Jun 29, 2011 | Acer Ferrari 4006WLMi Laptop Notebook
My computer has a virus . I 've been around
Please try to install the Kaspersky internet security 2012 by downloading trail version.
Better to install this in SAFE MODE with NETWORKING . By pressing F8, you can get the options like safe mode, etc...
Otherwise, please remove the harddisk and attach to another pc or laptop externally and SCAN this hard disk completely with Kaspersky internet security 2012. Before you attach this virus hardisk to another system., please install the good system with Kaspersky internet security 2012..
Hope this helps to you..
Jun 29, 2011 | Acer Computers & Internet
My pc and Imac can't detect my hitachi Neso N2501s.1 external hard disk, the light on the hard disk is on and the fan is running but they can't detect i've even try it on other pc but no...
there something wrong with hitachi neso cord, the one you used to connect from hitachi neso to your pc or imac, try to purchase new cord.
Jun 22, 2011 | Computers & Internet
Sony vaio blank screen
pls consider changing ur RAM issue will be resolved most likely ok let me know , there is strong chance ur RAM is faulty, if power comes but unable to start the system u see blank screen and no hard disk activity and light blinking then it is the RAM issue
pls rate me if i solved ur problem or explain ur problem in detail
Feb 27, 2009 | Sony VAIO VGN-FE880E/H Notebook
Computers & Internet Logo
16 people viewed this question
Alun Cox
