I have a magnavox big display clock radio- model mcr140/17 and can't get the radio to turn off. I have unplugged it, looked up the directions on a pdf file which told me to slide the knob to the o
Can't get the radio to turn off inspite of sliding the switch to the off position per the pdf file and unplugged it tiwce hoping to reset it. I need help to turn it off.
SOURCE: alarm clock/radio
Cut the power / batteries off and back on again to see if it will work, if not, go to www.easylifestyle.us to get a new one you need.
Posted on Jul 22, 2007
SOURCE: Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Posted on Apr 10, 2008
SOURCE: No directions for Emerson S.A.M.E. weather research radio
We are all set. We found the directions. Thank you!
Posted on Dec 12, 2008
  • 814 Answers
SOURCE: Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 15, 2009
yasoonhawk
  • 14 Answers
SOURCE: I have a very old Bose clock radio (model AWR1-1W)
Hey Pete! Did you take out the 9V battery as well and let power down to re-set? Benimur from JustAnswer suggested: Your described problem could either be a system glitch, hardware fault.
If it were a glitch, unplug the unit for an extended period of time to force the Bose to reset and revert to factory defaults. This would also require removal of the 9 volts battery. Should this be not corrective, then it would seem that the logic circuitry of the Bose radio is faulty. The logic circuitry includes the micro processor that handles all the controls and the displays. Unfortunately, not a user doable repair.
Posted on Nov 09, 2009
How do I change the time on a Timex T235 Alarm clock - can't find my book
To set the clock on the T235, make sure that the radio is off. If the radio is playing, press and hold the Power/Mode (the left-most button) until the display briefly shows Off and the time is displayed. Press and hold the Clock button (the center button), the display should start flashing. While the display is flashing, press the Tun + (Hour) button, next to the Power/Mode button, to advance the hour to the current hour. Then press the Tun - (Minute) button, between the Tun + and Clock buttons, to advance the time to the correct minutes. Then while the display is flashing, press Clock and hold to exit the time set mode. This will start the clock.
Timex has the manuals for many of their clock radios on the product page or their support page, https://timexaudio.com/support/ . For the T235, the direct link to the manual is https://timexaudio.com/media/uploads/product/files/T235_User_Manual.pdf . See page 6 to find the directions to set this model.
I hope this helps.
Nov 06, 2016 | Timex Audio Players & Recorders
Static after radio turned off
You are not alone. Memory cap will be bad on front display board(C137) 0.33F/5.5v. Replacing cap will not fix, micro damaged as well. Probably can't turn off except with remote and display brightness stuck as well. Board NLA.
Aug 15, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
LED on my Sony ICFC218 is dim
i found that if I repeatedly press snooze/date/sleep off (big button) it will change the dim setting 3 levels... dunno how many times but I press it like 20-30 times and it works
Dec 02, 2011 | Sony ICFC218 Clock Radio
I have the S1721 Travel Soother Radio Alarm Clock. It has stopped & a radio technician said it can't be fixed. It is THE best radio on the planet because it has a radio timer. I cannot find anything...
I came home and found a weird display showing 12 00 and ______f. Nothing worked, even when I unplugged it and took the batteries out. (I really, really like this clock radio so I wanted to find a solution).
I looked for a "reset" button and found one in the back inside the battery case (you have to remove the battery case cover). I took a pin and pressed it into the reset slot. I had to do this several times, turning it on/off and pressing several buttons and plugging, unplugging the clock/radio. It cycled through several times, then slowly the functions started to return, almost one function at a time. After several cycles of this, it turned itself back on and started working again!
Dec 01, 2010 | Sharper Image Travel Soother 20 Clock...
Bose wave radio won't turn on
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monpoly on repair of these units. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to provide a $200 allowance towards purchase of a new Wave. Before you spend the big bucks on theis trouble-prone product though, you might want to check out the new HD radios -- better sound and MUCH lower prices than Bose.
May 15, 2009 | Bose Wave Radio
Emerson Research Clock w/Projection Display Not Working
You will need to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio and remove the internal battery. Let the Clock/Radio set for at least 1 hour and then put the battery back in and plug in the Clock/Radio. The functions should return to normal. If not, replace the battery (CR2430) and leave the Clock/Radio unplug for a period of hours. Then put in the new battery and and plug in the Clock/Radio to see if the functions have returned to normal. If not you may have a more serious problem with the microprocessor. You can call the Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problem.
Mar 25, 2009 | Emerson Smartset Clock Radio
Display is blank, radio/clock won't turn on.
call the costumer service for that they are always really nice and helpful!
Feb 10, 2009 | RCA RP5430 Clock Radio
Clock radio display doesn't light up.
I just got a similar model at Big Lots a few months ago. A T439S. There some funky stuff they do with those displays it could be that the lamp is wearing out. 7 years is good life for them.
Sep 03, 2008 | Timex T110TT Clock Radio
Display keeps going on and off
Sorry it took so long to get back to you with a answer to your question. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
May 27, 2008 | Emerson Smartset Clock Radio
Nov 15, 2007 | Emerson Smartset Clock Radio
119 people viewed this question
 Grubhead
Grubhead
