Question about Car Audio & Video
Hi I have a DB566USB. I got it installed professionally but was told never to go to the guys I went.. anyway, everything works fine.. except, once the stereo is on, none of the internal electrics work (ie: indicators on car (bmw 318i e46 1999 model) but externally, everything works fine - it's just the internals. If I remove the front, then push it back in without touching anything else, everything works again fine. I don't want to go back to the guys who did it... Any ideas? thanks.
  • 74 Answers
I'm sorry to say you should't have went to "them guys". they must've crossed wires somewhere. you should be able to take it back and have it repaired at their expense
Posted on Feb 18, 2009
Supercharger isnt working , why ??
What does the Service Manager at your local Mini-Cooper dealership recommend for trouble-shooting and repair?
May 19, 2014 | 2003 Mini Cooper
The speaker output doesn't work
Hi Marlena,
I had the same problem with the 2200ub, so I will post the solution for that. Hopefully its the same for you, if not sorry I couldn't help better.
I have a 2002 Suburban and was installing the Pioneer DEH-2200UB. The suburban had the factory stereo still and has onStar. So I had everything hooked up, purchased the harness which was perfect except for the blue and white wire on the stereo and a solid blue wire on the factory stereo end. I was confused by there being 2 plugs from the factory stereo and one for the 2200.
I finally went to Best Buy and talked to their tech and he told me that since I have onStar I need to cut the pink wire and wire it to the blue and white wire that goes into the new stereo. These guys were great they didn't hesitate to tell me how to do it and even gave me the extra wire and connectors I would need to do it. Best Buy is expensive but I will keep shopping there just because of their service from these kinds of people.
The pink wire is hooked into the amp which I believe is located under the drivers seat. As soon as I did this everything worked perfectly.
I am not sure if the onStar still works, but I don't plan on using it anyway so if that is important to you, you should probably have a pro do the install. Best Buy will install it for $50 (plus parts) but it could be more for dealing with things like this I really have no idea.
Hope this works for you.
Jan 27, 2011 | Pioneer DEH-P4000UB CD Player
I have a Waring food processor model FP51071 motor will not go on
since I did not get a response from fix it and could not find a local repair store from fix it I called Waring the manufacturer and was told the motor will not work as a safety precauition until the top is locked in once I did that it worked fine.
If you had responded to me in anyway except to sign up and pay for your service I would have signed up now I am just annoyed .
Nov 11, 2009 | Waring Food Processors
Dvd movies
Maybe you had the same problem as I did... the unit may have been dropped or mishandled during shipping or maybe during installation. If it is still under warranty, return it. If not, try this:
I took mine to a technician that went through the settings, found nothing wrong, except for the fact that it won't play video. What he did afterward was open the unit up and checked out inside. Apparently there was just some little plug that got loose and/or fell off inside. This probably happened during shipping or could have happened if someone dropped the unit I guess. Anyway he re-plugged the little plug inside and it worked fine. I'm still to pick it up and test it myself but this is what I was told today so just thought I'd share it with you guys. Maybe that's what you need to get done.
Please note that if your unit is under warranty (like mine WAS), this would pretty much void it.
Apr 22, 2009 | Pioneer AVH-P4000DVD Monitor
1998 dodge neon - headlights not working
Everything is working fine now without anything further being done. Maybe a 'short'. Anyway we will track of if & maybe make a few enquiries. Thanks
Mar 24, 2009 | 1998 Dodge Neon
Cadillac Escalade Electrical Problem, Heated Seats, Power Mirrors
Dumb question, are you sure you are using the driver one remote? Being a car dealer, some installers will power the unit to certain fuses and some times this can cause issues. He may have told you 30 but most of these guys really don;t know and they are taught once and never really know if it is a problem from car to car. It sounds like a power failure of some sort causing it to reprogram itself to original specs. I went to a NTB for a battery change and I too had some issues and to my luck the guy was a GM tech at one point. So he was able to give me a few tips. Now you may not have this luck but Maybe call a few local shops like this and ask them if the have any GM techs you can run and issue by. You would be suprised where some of these guys have come from. Especially with the layoffs and need to work, anywhere....
Hoepfully this helps.
Jen
Feb 03, 2009 | 2004 Cadillac Escalade
No Has Been Able To Solve This Office 2007 Pro Problem, Can You?
The problem is the feature you tried istalling might have corrupted the OS. What you can try doing is create new user account first , restart your computer into the new user computer and then try installing. If the same still doesnot work , then my friend the only solution would be to reinstall windows xp and then put office 2007.
Thanks
proton
Dec 13, 2008 | Microsoft Office Professional 2007 Full...
Pioneer p4000dvd
Now this is ONLY in the case that you have done the bypass or at least grounded the handbrake cable properly to get past the warning screen and nothing else works.
I took mine to a technician that went through the settings, found nothing wrong, except for the fact that it won't play video. What he did afterward was open the unit up and checked out inside. Apparently there was just some little plug that got loose and/or fell off inside. This probably happened during shipping or could have happened if someone dropped the unit I guess. Anyway he re-plugged the little plug inside and it worked fine. I'm still to pick it up and test it myself but this is what I was told today so just thought I'd share it with you guys. Maybe that's what you guys need to get done.
Dec 11, 2008 | Pioneer AVH-P4000DVD Monitor
MS Office 2007 Professional Plus Stops Installing
The procedure entry point initilize critical section and could not be located in the dyname line library KERNEL32.DILL
Dec 07, 2008 | Microsoft Office Professional 2007 Full...
I am trying to install a Lexmark 4300 on a Dell computer with Vista on it
This was posted earlier by an anonymous Fixya guest:
I HAVE FOUND A SOLUTION TO NOT BEING ABLE TO SCAN WITH ALL IN ONE CENTRE with VISTA!!!!!!!!!!!
hi guys, i have had the same problem, i have a p4350 all in one printer and when i updated to Vista i couldnt get my install cd to work...i downloaded the install file from lexmark website...cjr4300eng.exe and all worked except OCR and FAX...i emialed lexmark and they couldnt help.....but i tricked my computer and now everything works just fine.....this what you have to do......
Step 1 - uninstall all previous lexmark software
Step 2 - download the cjr4300eng.exe file from
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0&searchLang=en&os_group=Windows%20Vista&target=
Step 3 - extract the file to c:\drivers\printer\4300 but do install the software, just cancel
Step 4 - once you've extracted, copy the OCR and FAX folders from the original INSTALL CD to the same directory c:\drivers\printer\4300 along with all files from the ROOT directory (autorun.inf, cdicon.ico, hidclass.sys etc) on the CD EXCEPT "setup.exe"
Step 5 - open setup.exe and wait for install, it should notify you twice of installation so be patient.....and WOLA you're done
Hope this helps guys....
Jul 03, 2008 | Computers & Internet
Car Audio & Video Logo
105 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
