Question about Dell Computers & Internet
Any time i switched ON my dell inspiron N4030 laptop, it comes ON as if it want to boot and would go OFF almost immediately, how do i solve the problem?
  • Dell Master
  • 27,725 Answers
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery.
For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter.
In most situations it's a bad battery.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if it does not start in safe mode it could well be a hardware problem
Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cycle
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
might be getting hot check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
or it might even be a virus until you have your laptop up and runing you wont be able to run your antivirus software.
another possible reason could be a memory dump running to many programs at the on time placing to much strain on the CPU central processing unit installing more ram will overcome this or uninstalling unecessary programs the other option.
If you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
Hope this helps
Posted on Nov 01, 2012
LaptopExpert
  • 458 Answers
SOURCE: dell inspiron b130
Might be a Heat issue... Look at the fan/s are they dirty??
also try reseating your RAM...
Posted on Jun 04, 2008
babes_ganda0
  • 381 Answers
SOURCE: When i boot my laptop, it is getting stuck most of the time.
their is to way to find a problem 1st remove hard disk (HDD) then try to boot the unit with out Hard Drive if this same the problem open the back case and find the memory then make a clean all pin connectors but use only a paper eraser to clean a memory..so good luck and have a nice day...^_^
Posted on Jul 10, 2009
  • 132 Answers
SOURCE: My Dell Inspiron laptop boot up freezes
RUN CHECK DISK AND IF IT STILL WONT BOOT RESTART AND BEFOR THE WINDOWS LOGO COMES ON PRESS F8 AND CHECK START IN SAFE MODE THEN RUN CHECK DISK
Posted on Nov 12, 2009
  • 67 Answers
SOURCE: Blue screen on Dell Inspiron 6000 Laptop
OUCH... Might need a new harddrive or motherboard. Does it even let you go into the bios? Maybe you can do a full reinstall to save you the dough.
Posted on Jan 06, 2010
parrotheadpc
  • 2600 Answers
SOURCE: I bought a Dell inspiron 400 laptop. I will boot
I would take the hard drive to a computer repair shop and let them scan the HDD and remove the infections. They can also repair the windows installation files so it will boot back up. Either way, you do not have to change out the memory unless you want to install more.
Posted on Jan 28, 2010
Dell inspiron n4030 keyboard not working
Shapsog,
You may need to turn off the Filter Keys option. Follow the steps below to turn them off.
Go to
1. Control Panel
2. Ease Of Access Center
3. Make the keyboard easier to use
4. Uncheck the "Turn on Filter Keys" option
You also may need to Check to be sure you don't have Sticky Keys enabled.
BY PRESSING THE SHIFT KEY FIVE TIMES
Without pressing other keys, press the SHIFT key five times to enable Sticky Keys. A window will be displayed asking you if you wish to turn on Sticky Keys Clicking Yes will enable Sticky Keys or click No.
If none of these steps work you may need to replace the keyboard or plug in an external USB keyboard.
Thank You,
Dell-Jesse L
Dell Social Media and Coimmunities
Oct 19, 2015 | Dell Inspiron N4030 14 Inch Notebook...
Forget my dell Inspiron N4030 Bios Password Service tag= H4Q4QP1
See this... http://www.tech-faq.com/reset-dell-bios-password.html
Jun 29, 2014 | Dell Inspiron N4030 2.13GHz 4GB 320GB...
My son put a password on my Dell inspiron n4030 and he forgot how can i factory reset it without a password
See link below for a possible solution. Please note: virtually any solution will require another computer to download software and create a bootable CD or DVD. Your initial boot screen should give you the key or keys to press to change the boot sequence and force a CD or DVD boot.
Offline Windows Password Registry Editor
Jun 08, 2014 | Dell Computers & Internet
Dell Inspiron N4030 asking me for BIOS password, i dont even rember making one.....I cant Boot to install a new version of Windows and I'm getting P-Offed!! Help please
You may have to find the reset disk or may have to do a clean instal in which case is not fun however
If there was no passowrd created by you always remember to go the easies route >>> My advice look @ the operation manual if no luck then at that point you will have to >>>>> ; )
Dell XP = Ctrl+F11Dell Vista = F8
EEEPC = Esc
Compaq = F11
HP Desktop Vista = F11
Emachine = F10
Acer = Alt+F10
Every manufacture has or uses different Function Key combinations to do a Factory Default Recovery. Also if it didn't come with disks there is normally a program in the menus to create your own set of recovery CDs. This must be done before you ever put anything on the recovery partition d: , if you used d: for anything you need to remove what you put there or the recovery will not function.
Nov 28, 2012 | Dell Inspiron N4030 2.13GHz 4GB 320GB...
Forgot Dell inspiron n4030 administrator password
You can read this 2 helpful posts:
How to Hack a Dell Laptop Password?
How to Reset Dell Password?
I have used Windows Password Key 8.0 to reset dell password, and found it really helpful. You can have a try.
Mar 12, 2012 | Dell Inspiron Computers & Internet
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
Computers & Internet Logo
186 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
