Question about GE Washing Machines
GE Washer Model-WWSE5240G0WW Flood Hose Fell Off.
The Flood Hose fell off. I cant find the gasket It connects to. I need an install guide with illustrations so that I might reconnect the hose.
    Top Expert:
  • GE Master
  • 9,472 Answers
Take a look at this diagram. The flood hose is 853.
Posted on Nov 01, 2012
Testimonial: "Hello! The diagram was perfect. Thank you so much!!"
Bgillespie
  • 89 Answers
SOURCE: cracked discharge hose on GE washer
Are you sure thats the model number? Im having trouble finding it on my end???
Posted on Dec 17, 2007
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
Maytag317
  • 1136 Answers
SOURCE: GE Drain Hose
Hi, Does this washer have to pump the water up into a drain? If it is possible, it would be better for the machine if you can bring the drin pipe closer to the washer. I know it is not always a possibilty. The longer the drain hose, the harder it is on the washer and sometimes the cloths don't spin out as dry as they will with a short drain hose.
Vic
Posted on Jun 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: How do I hook up washer drain pipe?
You'll need to seek the advice of a home repair or appliance repair - as your description of your connectors is vague.
They likely have the appropriate adapters.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Jahn27
  • 1554 Answers
SOURCE: I washed my carpet and
The pump assembly where the drain hose connects to is where the filter located and can only be accessed with the removal of the front panel. Disconnect power and remove the screws securing the top panel to the rear of the machine then pull the panel back and up.
Pull the dispenser drawer out then remove the two screws from the recess of the drawer.
Disconnect the control panel assembly harness and remove the screw on the right side of the console inside the cabinet then pull the console out.
Remove the four screws from the top of the front panel and the screws from the filter cover as shown.
Put a flat screwdriver or putty knife into the both sides of the filter cover and pull it out then remove the screw behind it.
Open the door and remove the spring clamp assembly that holds the door gasket to the lip of the front panel then peel the gasket off.
Tilt the front panel and disconnect the door switch harness then lift and remove the front panel.
The pump assembly can now be accessed.
Please make sure you accept this post if you find it helpful and informative. Failure to do so will automatically give credit to the first solution no matter how unhelpful or non-informative it is. Accepting a solution will not stop you from communicating with the expert should you need further help regarding the problem stated herein.
Posted on Oct 08, 2010
I have a DWD-F1222 front loader washing machine. The drain filter has come away from the machine. How do I reconnect it? If I use the machine now, will it flood everywhere
Lesley, there is likely a spring clamp that held the hose on. Either it's still on the part the hose attached to, or it came off with the hose and fell away. Either way, you will need to locate this clamp and secure it around the hose when it's back in position. This may require taking the panel off so you are able to see inside better.
Jan 02, 2015 | Washing Machines
My GE washer leaks from Hose Flood during agitation - how do I fix it?
It should be connected right next to the drain hose.
Jul 04, 2014 | GE Washing Machines
Handle broken
I need to replace handle which fell off. Whenre do I find handle> Do not have model #
Nov 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge wjrr4170 no spin
Remove the front panel, then look at the motor to see what codes the motor is flashing. There should be a green light on the motor that will be flashing. Post back your findings.
Nov 13, 2012 | GE WJRR4170E Top Load Washer
Right side suspension strut broke off, drum fell down and gasket popped off. Have new strut, but whats best way to install
get your self a blanket and a mop
disconnect everything hoses drains plugs
lay out the blanket
put the machine on the blanket
take off the back 16 screws i believe
tip it on ints side to a 45 degree angle good side is the pivot side
now you can easily manipulate the bad strut.
bevery careful its a very heavy machine once tipped have a spotter
Oct 06, 2009 | GE WSXH208A Front Load Washer
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Whirlpool Gas Dryer idler pulley assembly (# 691366)
pull the belt thru the ider not around it if you cant get it..post your email i will send you the guide on it along with your model number
Aug 05, 2008 | Dryers
Washing Machines Logo
539 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
