Question about Dell Computers & Internet
My laptop not responding after i change SATA to IDE using bios
My laptop not responding after i change my laptop SATA hard disk mode to IDE using bios, its is to resolve the blue screen problem on my laptop. Anybody know how to resolve this problem.
  • Dell Master
  • 27,725 Answers
Bluescreen can be caused by a number of things
Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cylce
Make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating
Could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU you might not have enough RAM random access memory
If you get your computer running to get a screen or even do it in safe mode
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select the safe mode option
You might have to many programs trying to or accessing the internet at the same time
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be running select end now and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
when purchasing any ram you should always ask if they can guarantee compatibility first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
hope this helps
Posted on Nov 01, 2012
  • joulMuzuha Nov 02, 2012
    okay thank you for your advice and knowledge for me. I will try as recommended by your
  • Brian Sullivan
    Brian Sullivan Nov 02, 2012
    i would be looking closely ar the ide they are the first to fail
  • 29 Answers
SOURCE: Downgrade to XP Toshiba L305
Seems like you need to check the MOBO vendor for updated drivers for your sata
Posted on Oct 14, 2008
SOURCE: disable sata in bios of compaq CQ40 laptops
i m not able to install windows xp on my compaq cq60 104tu laptop
when i boot the cd the exatrating process work properly and after extraction of all file when windows is startup a blue screen appears and
and message displayed in the screen check ur hard disk for vireuses
and installation stop
Posted on Apr 05, 2009
info2u
  • 596 Answers
SOURCE: ACER aspire 5738 will support XP os?
The 5738 will support XP as well as Vista. I am not sure why you had to make changes but what started your problems? Once I know this, I may be able to help you.
Thanks
C2Solutions
Posted on Aug 19, 2009
  • 509 Answers
SOURCE: How do I remove the Hard drive in a Toshiba L40-17M laptop
I have a Toshiba Satellite and it's IDE. The hard drive is behind a panel in the back and once you take the panel off it should just unplug. There should be a pull tab on it.
Posted on Jan 06, 2010
lock123
  • 6831 Answers
SOURCE: does the hp dv4000 laptop have an ide or a sata
Hello
The notebook you purchased uses a IDE Storage controller.
Kind regards
Andrea
Posted on May 31, 2010
How to change sata to ata in bios
If you want to install Windows XP or configure a RAID array, you may need to change the SATA type in BIOS. here I will introduce some method of SATA settings in BIOS. SATA HDD(hard disk) has been more porpular because of the hight transferring speed and simple installation. If you want to Install a Windows XP in SATA hard disk. we offen need a floppy disk to save the additional driver of SATA/RAID. but the floppy isn't too easy to find. So we can do another method, modify the SATA type to compatible IDE or ATA mode, etc.
Notes: If your computer has installed some operating systems. Changing SATA types may corrupt your systems or need to be repaired again. But when can I change the SATA type?
1. You are prepairing install a new operating systems, for commonly Windows XP. If Windows 7/Vista will be installed. you need nothing changed in BIOS unless the setting has been modified.
2. Or you want to install a RAID.
I will introduce how to install Windows XP at SATA HDD(hard disk) in the coming chapters, here we need to know how to change the SATA type in BIOS. At first we need to access BIOS, Here is my desktop BIOS, we can find the BIOS is from AWARD software.
201003290718324672.jpgIn my BIOS, the harddisk settings are in the line of integrated peripherals, different BIOS or different OEM menufactures may have different promise. you can try the Advanced BIOS features setting or Integrated peripherals, or system configuration, etc.
Locale to Integrated Peripherals and press enter, you may find the SATA configuration.
201004010308121905.jpgthe above screenshot is the SATA configuration position. There are two items about SATA controller, Onchip SATA controller and Onchip SATA Type, Notes: There may be one or more configurations about SATA, we only need to change the SATA Type. you should not close the SATA controller if you don't know what's will be happened.
Navagete to the Onchip SATA Type and press ENTER, we can find these selections: Native IDE, AHCI, RAID. If you want to install Windows XP, you may need to change to Native IDE(some called ATA) mode, when you finished installation, you can refresh your SATA drivers in Windows XP and change the SATA type to AHCI mode in BIOS again.
If you want to configure a raid array. set to RAID similarity. When finished settings, you should press enter to accept it, and save to CMOS before restart your computer. In my BIOS, I need to exit to the BIOS main menu at first and save it.
when the new status has been saved, you can press CTRL+ALT+DEL to restart your computer, some OEM PCs may need to click the EXIT or Save to CMOS and Exit, the computer will be restart automatically.
Another example screenshot is my DELL notebook BIOS. DELL BIOS is not the same as the desktop BIOS, we can find the SATA operation behind the System Configuration. there are only three selections (Disabled, ATA, AHCI). If you want to install Windows XP, here need to be changed as ATA mode.
201004010308185104.jpg Notes: If you want to install operating systems, you may need to change the boot orderto boot from your CD/DVD drive.
Oct 10, 2013 | Compaq Presario Notebook
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
When I turn on my computer the screen says " A disk read error occured" "Press Ctrl+Alt+Del to restart. I press that and then this screen comes up... Me having the happy fingers I changed...
Hi sharetta lan...
To change the ide mode back to sata mode you will have to enter the bios.
To enter the bios you will start the computer and as it is starting tapping the delete key,F2 or F10 key depending on your computer.
Once you are in the bios you can change the ide mode back to sata mode.
Please take time to rate me
Sep 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have replaced the hard drive on my HP G5000 laptop with a Samsung HM161GI drive. All tests OK on BIOS diagnostics, but Windows XP Setup says no hard disk is installed??
This happens because the hard disk is natively a SATA and XP doesn't have a generic SATA driver so from its point of view the disk is not there. You will need to go into the BIOS and set the SATA connection to use the legacy/IDE mode.
May 16, 2011 | Samsung Spinpoint M7E HM161GI 160GB 5400...
XP will not install "Setup
That is because it was designed for Vista not the obsolete XP. There are no hard drive drivers suitable in XP.
Re install Vista or install Win7.
Hope that helps.
Jan 22, 2011 | Computers & Internet
Toshiba Satellite M45-S331 notebook, os xp. Change hard drive couldn't use recovery disk, put in each driver from recovery disk after installing os. Blue screen states the bios in this system is not fully...
The thing is that windows xp ..usually does not have the drivers for teh acpi or achi mode and you need to get into bios and disable teh mode and let the hard disk to run in IDE compatible or sata as ide..
the function can be disabled in the same screen where teh hard disk and other sata and ide devices are presented..
After you disable the achi mode..it will work ..remember that you have to save changes with F10 before exit bios..
another way to make this work ..is install the windows xp in this mode..after you are done ..just install all drivers for it ..including raid and ahci drivers..and change it back from bios..It may work ..if it sees the drivers..
or ..you need to install the drivers when you get to teh press F6 to install 3rd party drivers....and you have to find a way to get them ...cause this operation is done usually b yusing a floppy diskette so ..to have a chance to do it .. you need to try to install them from a usb or install windows from usb and use the disk with drivers in the optical drive ..
If I would be in your place I would not complicate myself and just go to bios and change the bus mode for the hard disk ..save changes and reinstall operation system if needed..or go on from where it was..It will see the hard disk and no longer give you the blue screen
Sep 08, 2010 | Toshiba Satellite M45-S331 Notebook
How to configure bios to read sata hard disk
To configure your bios to read sata hard disk follow this Steps:
1. Power on the computer
2. Keep pressing the delete keys until bios utility will show
3. Go to the advance settings
4. Find the Sata Mode and then change it to IDE:
5. Save changes and Exit
Hope this could help.
Sep 27, 2009 | MSI K8MM-V Motherboard
Laptop does not boot up and recovery from cd gives d2d32 type mismatch error
A couple of things to try in the bios:
1. try changing the SATA mode to IDE for the restore and then back to AHCI mode after it was complete
2. Enable disk to disk recovery mode: To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this
value to Enabled.
Jul 11, 2009 | Acer Aspire 5920 AS5920 Notebook
Cant detect hard drives during the process of loading xp
Just pres F2 key on startup. Go into bios. In bios find HDD and press enter next to mode. Select IDE mode and press f10 to save changes and exit. You can install XP now. Alternatively you can use USB floppy drive to load SATA drivers.
Let me know if you need assistance on that
May 26, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Alun Cox
