Question about Kitchen Ranges
B&Q Value Oven , Type-B11 Model EC6000 WU/2 instruction manual
Either looking for an instruction manual or if someone can tell me how to change the bulb in the oven I'd be most grateful. Cannot get the bulb cover off for love nor money!
Maytag317
  • 1136 Answers
SOURCE: can't remove bulb cover to install new light bulb. Tried turning counter clockwise - no luck.
Hi, If there are no metal fasteners on or around the bulb to holld it in, it will need to be twisted. Try and put a towel on the lens to help you get a better grip.
It sometimes take a great amount of force to turn the lens.
Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
bigg t
  • 640 Answers
SOURCE: broken glass light cover...
you should be able to use the unit without a problem,in between the panels where the light is theres insulation.you can try northernparts.com they may have a replacement cover for your unit.
Posted on Dec 26, 2007
  • 38 Answers
SOURCE: I have a Whirlpool oven
depending on the age of your oven you can still get a manual in english direct from whirlpool. You can download them for free. Just type in whirlpool.com, get onto their site, then type your model number in and click the literature download. If it's unavailable then you can go to parts direct.com and they have the actual manuals on most models. I hope this helps.
Posted on Sep 11, 2008
SOURCE: changing oven light bulb
The manual states to turn the cover counter clockwise. I was able to turn it about an inch and then it stopped turning. You really have to apply pressure, but it will turn more. It is similar to a tight light fixture. I was worried about breaking it, but it did finally loosen. I believe the replacement bulb is a 40 watt mini oven bulb also...
Hope this helps!
Posted on Nov 29, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Posted on Jan 24, 2009
Self cleaning oven model #wfc150moewo how to set
Hello, Diane -
Are you asking about the Whirlpool model WFC150m0ew? I do not find information on any model with the number WFC150moewo.
If you mean the Whirlpool model WFC150m0ew and you do not have the owner's manual to read about the self-cleaning settings, I have located the owner's manual for that model on the Whirlpool website.
See:
https://www.whirlpool.com/results.html?term=WFC150M0EW&showTab=modelContent
Look for the 2 links to download the Use & Care guide. The self-cleaning instructions are on Page 11 of version of the Use & Care guide - whichever one you choose to download and save.
By the way, when you download and then save the Use & Care guide, so you can print it for easy reference, be sure to give the file a name you can find easily in your Documents folder - something like: Whirlpool Oven Manual.
Best wishes.
Jan 16, 2018 | Ovens
Aikae instructions for oven
LOOK UP ON LINE TYPE IN AIKAE OPERATING INSTRUCTIONS. TO SEE IF THERE IS A MANUAL FOR IT THAT WILL TELL YOU HOW TO OPERATE. OR GO TO WHERE YOU BOUGHT IT TO ASK.
Feb 02, 2015 | Ovens
I cannot locate my owners manual for my Imperial upright commercial freezer. I need to know how to defrost it
Hi the following should tell you all the info about the controller
Directions for Accessing and Setting G3 Series Digital Controllers
Changing the Temperature
Instructions for changing the desired temperature
1) First, press set for 1 second
The current set value will begin flashing after a few moments
2) Second, increase or decrease the temperature value by using the up or down icons
3) Lastly, press set to confirm the new value
Manually Setting Defrost
Instructions for manually setting automatic defrost
1) Press down the snowflake icon for more than three seconds
note that defrost will only begin if the temperature inside is equal to or less than 45
degree F.
2) Defrost will last about 25 minutes and then return to normal cooling or freezing
cycles.
Using Flash Cooling or Freezing
Instructions for Using the Flash Cooling or Freezing command
1) First, press the up and down icons together for more than 3 seconds
2) The refrigeration unit will immediately begin cycling to quickly reach the desired
temperature set point.
3) ** Flash Cooling/Freezing Option must be first set on the Configuration Parameters
Menu: Go to CC (continuous cycle duration) and enter a value. The value entered will
be the amount of time (in hours) the Compressor will run continuously to pull the
temperature down. Note: Flash Cooling may go below the temperature set point.
Eg. CC = 2 = 2 hours of Flash Cooling/Freezing.
Accessing & Setting Configuration Parameters
Instructions for Accessing & Setting Configuration Parameters
1) First, press set for 3 seconds, the display will show PS, then press set again.
2) Next, enter the password #22 to go the menu, press set.
3) You can scroll within the menu by pressing the up or down icon.
4) Go to the Carel controller detailed menu chart for specific controller settings. Click
Here.
5) To change the values, go to the menu listings ( C0, C1, D0, D1, F0, F1 etc), press
Set, the up or down icon, then Set again to complete the changes.
6) Finally, to Save all the changes made in the Menu, press and hold Set for 3 seconds.
Note: One of the parameter menu listings must be accessed to Save properly by
pressing set for 3 seconds. Saving by pressing Set for 3 seconds outside of the
parameter menu listings (ie, CO, C1, DO, D1, etc) will not save the changes.
7) If you do not want to Save the changes made, do not press the buttons for 60 secs
Regards
Gordon
Apr 22, 2011 | Migali Imperial Series Aluminum Reach In...
I have St. George Imperial Fan Forced Oven with Griller (Wall Oven) SGW FO need measurements and specs also model number ?? Can someone please help me have been looking on net for ages...Getting...
you should find the model number between the bottom of the griller door & the liner .. silly place really to get at... as you cannot remove the grill door as you can the oven door.
we have just rebuilt one from two we acquired ... best oven ever .... there will be a few different models as these were produced & cosmetically changed over a 20 yrs period. Ours now looks like a brand new oven as they are REAL baked enamel ... you can clean with caustic based product without any harm.
I am searching for a manual if anyone has one mine is 67/wdl.v.81.fo I presume the 81 in the number denotes 1981 manufacture.
Don't be fooled if you find the oven does not heat at some stage & everything else works ... this is usually after a cleaning & the auto on & off timer has been activated ...just a matter of setting back to manual mode.
Hope this helps although you have probably solved by now having posted in April 11.
Anyone have a manual for this model would be appreciated .
Apr 16, 2011 | Ovens
Hi I am in Toronto Canada and have a model 337-b11
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
Most likely a power supply component has aged and thus changed value and/or failed. Take it to a reputable repair person
Mar 13, 2010 | Olevia LT37HVS 37 in. LCD HDTV
No gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Oct 01, 2009 | Wolf Range WKGD-2 Gas Double Oven
How do i set the delay start option on my oven?
We need the model number to find the right manual. You could try looking it up yourself here: http://www.managemyhome.com/mmh/
On the right-hand side of the page, under "Owners Manuals", type in the info. If you don't find it there, then please tell us the model number and we can look some more.
Mar 16, 2009 | Ovens
How do you change a kitchenaid oven light
Go to this web sit and type in your model #. then go to the user care manual at the bottom and it will tell you how to change it. Or you can post the model # here and I will post the instructions here for you.
http://www.kitchenaid.com/catalog/product.jsp?src=Built-In+Ovens&cat=124&prod=1327
Dec 15, 2008 | KitchenAid Kitchen Ranges
Samsung HCP4752W
You can not change a value in 480p or 1080i unless that is the incomming signal type. Unless you really understand these setting I would be careful of changing any.
Apr 13, 2007 | Samsung HC-P4752W 47" Rear Projection...
Kitchen Ranges Logo
362 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
