Question about M-Audio Music
Power switch no working
It use to turn on when I fiddled with it now it doesn't come on at all.
  • Bahbeau Nov 02, 2012
    It's a M-Audio Ozone Midi keyboard, power flickers on and off when I push power botton.
    Master:
  • 444 Answers
Power bottom has to be replaced,
Posted on Nov 02, 2012
  • Bahbeau Nov 04, 2012
    Where can I get that from.
Marshall MG30FX loud tapping sound in time with delay even when no guitar plugged in and effects turned off
Hi J Wade. I'm Dave P. I'm not a guitar amp expert or technician but I've been using amps and effects for 35 years and there are a couple things I can suggest.
That kind of periodic noise/switch noise can be a symptom of having the polarity of the amp reversed. If your amp has a 3-position OFF/ground switch, try reversing the ground. If it doesn't, take the plug and turn it around. Just don't get near a microphone unless you're sure your amp is grounded the same as the P.A. It could fry your lips off.
Dirty switches to that too. You said the noise is in time with the delay's tap time which is set by a foot switch. If tapping that switch the first time generates a pop, the delay may have catch it and is repeating it. Turn off the amp, remove the delay foot switch and turn it back on. Still noisy? If not, give the foot switch a good cleaning.
When you turn the EFFECTS knob up, is it scratchy? Might need the potentiometer cleaned. What happens when you specifically turn the DELAY level down all the way while using the other effects? Noise still there?
That's all I've got. Hopefully, it was helpful. Don't wrack your brain over this too much. There could very well be an internal problem with your amp that will require a trip to the shop. You don't want to open it up yourself. Rock on but be safe.
Dave P.
Aug 22, 2012 | Marshall Amplification Marshall MG30FX...
I got my KM60 in Singapore where they use 240V. I moved back to the states and now when I turn it on the amp buzzes for a few seconds and then it has a faint static while it is on. This static...
The only change you need to make for the 120 operation should be to change the fuse to a 2 amp fuse. Faint static is typical of the electronic noise of amps... as long as it it is faint. The power supply will act differently on 120 than 240... probably takes a brief more time to get the system stable, hence the initial buzzing. As long as it performs don't worry about it.
Aug 11, 2011 | Hartke KM60 1x10 Keyboard Amplifier
Just installed my new bridge with piezo pickup and my 1/4 inch jack lead will not go into the jack mount on my fiddle. After about a cm in it just stops and wont go any further! Would appreciate any...
I hate to say it but you probablly need a bigger hammer... grip the jack, not the fiddle, and put more force on the plug... they can initially be tight... I do NOT like carpenter jacks myself. They are too heavy. At the 1 cm point is where the plug has to displace the contact. Expect to put 1 to 2 pounds of force to get the plug in... SUPPORT the jack so the force doesn't go on the fiddle. Make sure to use a high impedance cord and preferably short, say 3 feet cord. The capacitance of a guitar cord heavily loads a piezo pickup reducing the high frequency component of the fiddle sound and distorting the waveform. The impedance of the piezo's are around 1 to 2 megohms. Looking on an oscilloscope I found that a guitar cable and amp input made the normal sawtooth violin waveform into peak like mountains. We are now using a short cord (2.5 feet) into a Line6 X2 wireless digital body pack. The link transmits the wave undistorted.
Jul 14, 2011 | L R Baggs Violin Pickup W/ Carpenter Jack...
Having just purchased a new 3amp MicroCrush on ebay I am disappointed that it is impossible to get a 'clean' sound. I have tried every combination of switch settings on the amp and my Gretsch 5122...
You are using a Gretsch with this? This is a tiny amp useful for ONLY low levels as a practice amp. If you turn up the gain the unit will distort as the tiny speaker just can't handle high levels. An appropriate level would be if *********** could tolerate sitting alongside it. For the hum situation... does it hum with NOTHING plugged in? If so, probably the wrong adapter is being used. If it doesn't, then your guitar is probably picking up magnetic interference... major source of that type interference is "wall warts" power adapters. The only solution is to keep distance from the source to your guitar. Poor quality guitar cables can let in hum as well.
Jul 14, 2011 | Orange Amps Orange Micro Crush Mini...
My amps won't turn on. There are 8 amps plugged into individual boxes but they are controlled by one switch on the sacr
Not uncommon for a switch to fail... especially the weak types they use on these strips. The inrush current when turning on the amps makes quick work of these switches. Replace the switch and get spares for the next time it fails.
Jul 08, 2011 | Atlas Translator Atlas SACR191 6Channel...
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
I havn't used my UM300 in only two days, last time it was working pretty well ... better than ever, today morning i woke up and tried to use it, but all im getting from the amp is a buzz in a very low...
Dead battery or disconnected power adapter. Leaving cables connected discharges battery in a day as this is what switches the battery on. (The input cable)
May 24, 2011 | Behringer Um300 Heavy Metal Distortion...
I have two Behringer Eurolive B415DSP speaker, one of them stopped working out of no where. To my best knowledge, the problem is that it doesn't turn on. I had the Fuse check already and thats not the...
This is alimentation fault of the amplifier inside the box. Dismount the amplifier block and take a look first if there are some burned pieces. If it seems all ok, better bring it to a electronics/ tv service center.
May 18, 2011 | Behringer Eurolive B415dsp 600w 15" PA...
The guitar is not amplifying
faulty lead? when the lead is plugged in turn the amp distortion on (may be called 'gain') and when you tap the end that goes into the guitar with your finger you should hear a buzz. try another lead if not, and if it still doesn't work make sure that volume is up on the amp and the guitar. there may also be a knob in the back of the amp, turn that up too (but not all the way or when you do get it working you'll blow the speakers out).
Apr 19, 2011 | Marshall Amplification Marshall MG Guitar...
Music Logo
115 people viewed this question
Top M-Audio Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a M-Audio Music Expert? Answer questions, earn points and help others
