Question about Microwave Ovens
Rational oven error code e12
Beeping and error code
3 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: On a Jenn-Air Microwave Oven
E12 normally indicates a door switch problem. It can be a bad switch or switch mount.
Sometimes it's bogus and you can clear the code by unplugging the oven for a few minutes then resetting the clock.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
espressonist
  • 1711 Answers
SOURCE: ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Posted on Nov 04, 2010
I'm getting error 40 on wolf warming drawer, with beeping...buttons don't work...rest breaker few times...doesnt work...
Not knowing the make and model number of the microwave doesn't give me much information to work with. Try to google the make and model number, along with the phrase "unit beeps and error 40 on warming drawer", and see if something comes up. There are sites with error codes, which might help.
Also, refer to any literature that came with the unit, to see if they have the error codes listed, and what they refer to.
You can often go to the manufacturer's site and find useful information about various problems, and what needs to be done.
Wish I could be more specific, but will try to check back to see if you can include the make and model number, and then we will go from there.
Oct 31, 2010 | Microwave Ovens
My samsung microwave model SMH718 keeps showing an error code -SE- and keeps beeping in 4 beep intervals. How can I correct this?
I had the same problem, I changed the daylight savings time on mine and it worked untill summer, then it happend again. Finally mine quit working altogether. P.S. when this first happend samsung didn't even know what the error coded meant. It is an engineering code, meaning service engineer I believe. If it is beyond the year warranty your hosed, it would cost so much to try and fix your better off buying a new one.
Oct 25, 2010 | Samsung Microwave Ovens
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave model JES1334WD01. Last week it gave me an error code of F3. The owners manual does not cover this code. Now, when it's plugged in, it beeps incessantly.
Go to this link about error codes for GE microwaves. Just copy and paste into your browser.
http://www.geappliances.com/search/fast/infobase/10009792.htm
Hope this helps. If I can help you with anything else please let me know.
JimmyC
Sep 29, 2009 | GE Microwave Ovens
Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Sep 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Ge microwave jvm 1430 error code F3
Jul 17, 2009 | GE JVM1430 Microwave Oven
Galanz (french for ''****'') microwave is sporadically beeping
maybe, just maybe, there is an error code showing....and, most microwaves beep when a button is pushed too...LIVE WITH IT!
Jul 06, 2009 | Microwave Ovens
GE xl 1800 beep
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jul 10, 2008 | GE JVM1660 Microwave Oven
Kitchenaid microwave oven KBMC140HSO
I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
1,152 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
