Question about Sony PlayStation 2 (PS2) Console
My joysticks don't work
Hi i have a problem.... none joystick works on mi console... is odd beacuse my joysticks work in a friends console but not in mine and his joys don't work in my console... i don't know what to do... my console is thin model... y ran out of options... by the way, i don't know if it's important but when i press the analog button the red light of my joy turns on... i apreciate a answer... tanks hola tengo un problema... ning?n joystick funciona en mi ps2... ni los mios ni los de mis amigos... es como que no los reconoce... pero cuando apreto el boton "analog" se prende la luz roja de ljoystick as? que es como que tienen alimentaci?n simplemente no los reconoce o algo as?.... no se mucho de esto... as? que capaz que estoy diciendo cualquier cosa... pero ese es el problema.... agradecer?a si alguien me puede explicar como arreglarlo... no importa cuan complicado sea... i can do it :P gracias!
  • 34 Answers
HI YOUR PS2 JOY PAD PORTS PICTURE BELOW ARE DEAD YOU NEED TO REPLACE THIS TO GET YOUR PS2 BACK TO WORKING CONDITION ..... IF YOU NEED THESE PARTS PLEASE CONTACT ME I CAN POST TO YOU VISIT MY WEBSITE WWW.CONSOLEREPAIRANDPLAY.CO.UK
Posted on May 31, 2007
Surely the connectors is the main problem, try to check that. Seguro son los contactos de la play, mandala a que la revisen
Posted on May 27, 2007
I don't know how to open the case? It has a side panel clear blue led lights
you will need a rubber replacement for your R1 button, if you or a friend have a defective joystick consider that a replacement. if you can't find a defective joystick you can buy a ps2 rubber kit online. below are reference pics.
1. Remove 5 screws with a philip screw at the back of the joystick.
2. Split the two covers with caution.
3. Carefully remove the rubber beneath the R1 button and replace it with a new one.
4. Put together the front and back part of the joystick.
5. Test the replaced part and screw if you're satisfied.
Hopefully this information helps.
thank you for using Fixya..
Jul 26, 2011 | iCute 408Black w/Side Window LED 400W Case...
Joystick problem
HI,
You will have to get this repaired from local Atari Authorized Dealer
I will let you know the contact details
Oct 12, 2008 | Atari 2600 Console
Hi, I have logitech wingman 3d joystick , but it went out of calibration , I mean when I try to turn to right it response normally but when I turn it to left It's not accurate... I know the problem...
In windows, go to your control panel in settings. In there, there should be a link for 'game controllers' or similar. Make sure your joystick is plugged in. When the settings start, you should see the joystick mentioned. Click this and then calibrate it from there.
Don't forget to save before leaving.
Dec 20, 2017 | Logitech WingMan Force 3D Joystick
When i insert the PS 2 joystick in the PS, it is not working.. joystick was used for just 10 days!!!
go to a friends house user there ps2 to see if it works on there's if it don't then the joystick is busted if it does then you need to get a joystick for ps1
Mar 17, 2010 | Sony PlayStation 2 8MB Memory Card - Black
Both my joystick are not working
Try Other Games... If That Still Doesn't Work Loan An Additional Joystick Just To Check If It's Joysticks Fault, If The Additional Joystick Doesn't Work Then It Must Be A Broken Port Or Something...
Nov 21, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 not responded to my joystick my joystick is work what happen my ps2
The Cable could have a break in it, check to make sure none of the pins in the Controller port are bent and if all else fails you will need to buy a new controller port, but try a different controller before you buy a new controller port
Nov 03, 2009 | Sony PlayStation 2 (PS2) Console
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Sep 16, 2009 | Microsoft SideWinder Precision Pro 2.0...
Hi there, I got a Logitech Force 3D Pro F3D Joystick, It's working great with Windows Vista. I just got a older Logitech Attack 3 Joystick without any software from a friend, can I use my software of the...
Hi, Yes the software is common for all logitech gaming devices, it's called LGS ( logitech gaming software ) So you can use it for both devices. Thanks and have a nice day J -
Aug 10, 2009 | Logitech Force 3D Pro (963352) Joystick
Joystick problems
The only way this can happen is if you have damaged the joystick function area.You have to change the joystick and put another one.
Jul 22, 2009 | Sony PlayStation Portable (PSP) Console
New psp anolgstick won't work
try to clean where the copper makes contact. then tighten up the screws and connections.
Jun 14, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation 2 (PS2) Console Logo
143 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
