Question about Schwinn Cycling
Pedals turn hard on my schwinn airdyne
The pedals wont turn.
2 Suggested Answers
SOURCE: older schwinn airdyne manuel
figured it out
Posted on Feb 04, 2010
What kind of batteries does the schwinn Airdyne take its about 22 yrs old?
Most computer console batteries for Airdynes are AA, you'll have to open up the console/meter housing in the back to replace them. I will be attaching a link to a diagram of the housing. Hope this helps, sincerely SportSmith..
http://www.sportsmith.net/images/product_support/schwinn/service_manuals/Airdyne%20Evolution%20electronic%20trouble%20shooting.pdf
May 21, 2015 | Schwinn Cycling
Tip
How to replace a chain with master link on a Schwinn Airdyne
Airdyne Chain Replacement with Master link
This video will demonstrate how to replace the chain with master link on a Schwinn Airdyne.
  • First remove the cotter pin and clevis pin from the user's right handlebar. Then lower the connecting arm and handlebar.
Caution: be sure to hold the handlebar as it will come loose after removal of the above parts.
  • Remove the connecting arm and pedal and crank arm by removing the wedge pin. To simplify this process loosen the nut and tap on it with a small hammer until the pin is loosened.
  • Remove the nut, wedge pin, crank arm and connecting arm.
  • Next remove the chain guard; there are three screws attaching it as shown in the video.
  • Remove the chain by locating the master link. Remove the lock pin and the cover, and then disconnect the chain.
  • Place the new chain on the sprockets as shown in the video.
  • Install the master link, cover and lock.
  • Re-install the chain guard and attaching screws.
  • Re-assemble the connecting arm to the handlebar and eccentric.
  • Be sure the brass bushing is installed in the front inner side of the connecting arm before installing the clevis pin and cotter pin.
  • Install the crank arm with pedal.
Be sure when completing this step that the crank arm is installed in the opposite position as the users left side crank arm.
  • Install the nut onto the wedge pin and tighten.
  • This completes the procedure.
Replacing Schwinn Airdyne Chain with Master Link
on May 23, 2016 | Schwinn Airdyne Exercise Bike
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
User Guide/Manual for Schwinn Airdyne AD3
Schwinn Fitness has many of their manuals here: http://www.schwinnfitness.com/schwinn_fitness_us/customerservice/manualsen.jsp . The direct link to the owner's manual for all Airdyne exercise bikes is available here: http://download.nautilus.com/supportdocs/OM/Schwinn/SCH_Airdyne_Evolution_OM_web.pdf . If you need the assembly directions, see the Airdyne AD4 guide: http://download.nautilus.com/supportdocs/AM/Schwinn/SCH.Airdyne.AD4.AM.EN.pdf . The AD3 and AD4 are very similar.
I hope this helps.
Apr 08, 2015 | Schwinn Cycling
Squeaking belt on airdyne bike
I love my Schwinn Evo Comp AirDyne. After 2 years it suddenly developed a bad squeak and about .5" of increased play in the pedals (ie the pedal could rotate back and forth about .5" before turning the fan). Both these symptoms were caused by a broken spring in the chain tensioner. (Schwinn pn 13000371. See part 80 in blowup 5 of http://www.fitnessrepairparts.com/diagram/114 ~$9).
To replace this:
  1. disconnect the right hand (as you sit on it) connecting arm (ie the piece that connects the pedal to the big handle) from the lever arm (ie the big handle you pull back and forth) by removing the connecting bolt with an Allen head wrench and an adjustable wrench. Note the order of the three internal washers as you remove the connecting bolt. Rotate the connecting arm towards the back of the bike to get it out of the way.
  2. remove the four phillips head bolts that hold down large right hand plastic cover. With the connecting arm out of the way this cover can be pulled far enough out to gain access to the chain tensioner.
  3. remove the broken spring and replace it. I fashioned a similar spring with less tension which seems to work as a kluge. The original spring broke at the outermost loop, so I might have been able to reuse it by just bending down another loop.
  4. could lube the chain while you are in there, but you can also lube it anytime from the other side
  5. put it all back together
Jan 21, 2014 | Schwinn Airdyne Evolution Comp
Pedal / Chain shaft(?) problem
Sounds like you will need new bearings,check manufactures website for parts and instructions.shouldnt be a hard fix.
Nov 29, 2013 | Schwinn Airdyne Evo Comp Upright Bike
Schwinn airdyne computer battery
it may need to be calibrated. Call schwinn or Treadmill Doctor at 800-750-4766 to walk you thru the calibration.
Jul 11, 2012 | Schwinn Airdyne Ad4 Upright Bike
My Father has a schwinn Airdyne. the pedal was loose, I bought a new piece that fits through the pedal, replaced it but it is still loose. I think the medal in the crank wheel is worn...... Because the...
There is a metal shim needed in the bike/pedal that has to be tapped in to keep the pedal tight. If you dad has used the bike for several hundred miles and/or his feet might actually bend the pedals over time (weight), it is possible the metal piece that the pedal attaches to could become bent slightly, and I have seen a few bikes, that need to be taken to the bike repair store (call a large bicycle/itness store) that has a good repair shop and they often can repair these, but rarely less than $125 for an Airdyne repair/tuneup.
Feb 18, 2011 | Schwinn Original Airdyne
I need assembly picture or diagram for original airdyne.
Here is the diagram for the original Schwinn Airdyne. Only the computer is different.
Aug 25, 2010 | Schwinn Original Airdyne
Cycling Logo
98 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
