Question about Lenovo Computers & Internet
Hi i am unable to update preinstalled version of windows 7 home basic on my lenovo g480. everytime when i shut down, it installs updates and when i restart it tries to configure but then there comes a failure message and the process rolls back. what to do. my mail id is tnsuresh1@gmail.com
  • Lenovo Master
  • 2,878 Answers
Make sure the account you are logged in as has Admin privileges, and manage updates yourself. Choose and only install those updates pertaining to you. Like not installing languages updates and so on.
Posted on Nov 01, 2012
  • 274 Answers
SOURCE: Computer shut down message after installing Encore upgrade.
I'm not a Mac expert but I did find your Mac went through 4 design changes.  What is the model number of your Mac?  This is important because not all models are upgradeable per another website.
  Quote:
Is the CPU on the Power Macintosh G4 upgradable? How is it mounted?
Officially, Apple does not specify that the processor on the Power Macintosh G4 series is upgradable, since Apple has no plans to offer upgrade cards for the machines. However, PCI-based Power Macintosh G4 models have the processor mounted on a ZIF, and AGP-based Power Macintosh G4 models have the processor mounted on a daughtercard with a 300-pin connector.
To determine whether your Power Macintosh G4 is PCI-based or AGP-based please refer to the specifications for the particular model of interest, and to the Technical & Performance Q & A section of this Q & A.
Also in my research I found references that the "firmware" may also need updating.  But that may apply to a different situation.
Posted on Oct 17, 2007
Cryptonteki
  • 97 Answers
SOURCE: hallo sir..
You will find the drivers on the motherboard CD that came with the MSI motherboard if you have no CD you will need to search the NET for you motherboard type and the Video chip it has then download the driver
Posted on Feb 21, 2008
Kindofcheap
  • 241 Answers
SOURCE: PC shuts dowm
It sounds like your computer is running to Hot>
You can check the temp. in tour Bios if you just want to see how hot it is running
I usually will run the computer for awhile and the reboot
and and before then press F4 or sometimes F2 to then go to setup
From there you bios will be there and you can see if your fans and the cpu temp and your Video cards temp..Which could be also getting too Hot and if you tweak it or if the Fans on the boards are covered in dust this will cause it to heat up. That goes same for the Cpu Fan too.
Note Please do not make any changes to your BIOS and don't Save anything
Thank You
Posted on Aug 28, 2008
  • 69 Answers
SOURCE: Error Code
All you can do is Reinstall windows. You should get the Windows Vista Installation CD with your laptop and all you have to do is put it in and restart your computer and when the message that says "Press any key to boot from CD" press a key.
If it doesn't show up, you may have to press a key like DEL or F12 to get the boot sequencer. When you first turn on the computer you should see the Compaq logo. At the bottom of the screen you should see some buttons to press to do things like BIOS and Boot Sequence. You want Boot Sequence. Once in boot sequence, select the CD-DVD and press any key when it says to.
Once in follow instructions or oyu can reply and i will tell you how to install.
Posted on Oct 10, 2008
  • 106 Answers
SOURCE: Resource hog DIAG
Try to repair your OS.. ^^
Posted on Jan 29, 2009
Hi All....please help me in this. Two years back, I bought Lenovo Ideapad Y460 with windows 7 preinstalled. In these two years, Couple of times I have successfully used One Key Recovery Process and made...
Download Win7 (same version as your original) from Microsoft.
Re-install Windows using your original key.
If re installing from USB goto the bios and change the Boot order to USB 1st - You will need to re-install all other software.
Having an ethernet cable plugged directly into your router is usually enough to get all the Win Updates required to get you going again.
The Lenovo site is a good resource for up to date drivers.
Sep 05, 2013 | Lenovo IdeaPad Y460 Notebook
Lenovo G480 cant adjust screen brightness! please help
On AC or Battery? As I'm sure you know, your Laptop will dim the Display on Battery to save power. In Windows 7, Open the Control Panel, select Power Options, select High Performance, select Change Plan settings, set Display time, set Sleep and Hibernate to Never, select Change Advanced Power settings, scroll through each one by one and adjust. OR right click a open spot on the Desktop, select Personalize, left bottom select Display. adjust to your preference.
Apr 16, 2013 | Lenovo G480 218422U Dark Brown 3rd...
I got a message in my desktop saying that "Windows 7 Build 7600 This windows is not genuine". I have Lenovo G460 laptop. It comes with Win 7 driver. How can i solve this issue....
If the Windows 7 label on the laptop has the Windows 7 installation code then you can contact Microsoft and get this problem fixed.
Nov 19, 2012 | Lenovo G560 067999U Notebook
Can we undo window 7 anytime upgrade
no once you have upgraded, it cannot be degraded to the previous version. and do you think this will solve the issue? you had the same problem even before with windows 7 home basic genuine version,then how could you think about this problem.let me tell you that genuine or piracy version of windows does not harm the machine but it is *********** board which is creating problem.this symptom "sudden shutdown" suggests that you need to change *********** board if it is not repairable.
Apr 07, 2012 | Lenovo Computers & Internet
I have my eovo y410 with preinstalled vista home basic.but i wat to change it to windows 7.is there any problem ..................please solve my problem.................
You can.
You can install to another partition and at the time installation don't select update .
If you need more information, reply me soon.
Thanks
Feb 25, 2011 | Computers & Internet
Hi Team - I own a Lenovo G560 notebook. This has Windows 7 home edition 64 bit in it preinstalled. I need to format and do partition of my hard disk. How can I reinstall the windows 7 that originally came...
Hi!
Lenovo does not provide recovery discs for their systems. You would have to call Lenovo to request for one. They also have Lenovo Care, a fee-based software support if you need help reinstalling Windows 7.
You can try to call 1-877-737-1082
Jan 04, 2011 | Lenovo G560 06793JU Notebook
My web cam stopped working after installing vista home basic
Shut down and restart the system.  Also go online and look for updated drivers web cam drivers that work on Vista.  Stick with XP, because there are less compatibility issues with peripherals.  Vista sucks a.s and is truly the bastard child of Bill Gates.  Windows 7 looks promising, but only time will tell.
Nov 15, 2009 | Lenovo 3000 Y410 (59012354) PC Notebook
I have a 64 bit HP pavilion with vista home premium. When the latest automatic update occured, it shut down Internet Explorer. In order to access the web I did a system recovery and shut off the automatic...
Remove the update the caused the problem in add remove programs, then update manually, or turn off auto update. You can also install and use firefox instead of IE or try doing a repair to IE. Usually IE updates to version 8 and it has problems - version 7 works fine. Uninstalling 8 changes it back to 7. Version 8 will not download properly on a lot of sites - they changed it so U have to use Windows explorer instead to download from FTP sites, and it will not connect to some sites due to all of the security they installed. You could try using default settings on security and turn off filters to see if that works. When windows updates IE it automatically changes to high security.
Oct 02, 2009 | HP KQ495AA Pavilion A6500F Desktop PC
Device shows : STK7700D.
http://consumersupport.lenovo.com/lenovo/drivers/list.aspx?CategoryID=134&page=2
Here is the lenovo site for the drivers for you pc. Only download and install the xp driver versions...after which you should be able to update the drivers for the devices that have the yellow color and should not have any problems installing.
You can also check the windows update site...do a custom update and search for drivers...sometimes new driver versions can be downloaded that way.
Hope this helps
Mar 30, 2008 | Computers & Internet
Computers & Internet Logo
81 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
