Question about Brother Sewing Machines
My foot came off
How do I place the foot back on?
Well, you're going to need a lot of duct tape and maybe some glue.
Posted on Oct 31, 2012
The sewing foot of brother sewing machine has dislodged, how do I fix it back?
There is a lever on the back side of the presser foot shaft. Align the foot with the shaft and press the lever. It should snap into place.
Jul 02, 2017 | Brother Sewing Machines
My threader piece popped off
If you are referring to the needle threader, there is a screw on right side to loosen when inserting needle. Tighten it back.
If you are referring to the needle foot, there should be a little flipping switch that releases foot. Place foot in place, lower needle arm and if aligned properly, foot will snap back on/into position.
Aug 28, 2013 | Brother CE8080PRW Limited Edition Project...
How do I change the presser foot on an elna mini sewing machine?
I dodn't know your model really well but it will be one of the following:
a clip on foot that you just pull down on to remove,
a clip on foot with a button at the back of the pressure foot holder - press the button to release the foot
a clip on foot with a little lever at the back of the pressure foot holder - lift the lever to release the foot
If it is a clip on foot, then you just need to raise the pressure foot lever, put your fingers onto the pressure foot and press downwards, it should unclip.
To put one on, place the pressure foot onto the needle plate under the pressure foot bar and lower the pressure foot bar down onto the foot, lining up the base of the foot holder with the little bar on the foot, it should click into place.
Oct 10, 2011 | Elna 2007 Mechanical Sewing Machine
Don't know how to do button holes
Slide the back of the buttonhole foot "R" open, place your button in the cradle and slide the fott together so it holds the button.
Snap on the buttonhole foot on the machine. Pull down the buttonhole lever. It has a small white plastic paddle on the end and is located up and to the left of the needle bar. Pull the lever all the way down. Turn the pattern selector to Buttonhole. Place the tension on 3. Place the stitch width control on 5 or 6. Place the stitch length control a little below 1. Make sure that you have some stabilizer between the layers of fabric. Use freezer paper in a pinch. Lower the foot on your fabric making sure that the foot is not pulled forward or backward. Make a test buttonhole. AFTER EACH BUTTONHOLE YOU MUST TURN THE PATTERN SELECTOR OFF BUTTONHOLE AND BACK ON IN ORDER TO RESET THE MECHANISM. Make several test buttonholes, adjusting the width and length if needed.
Jun 02, 2011 | Janome D'cor Excel 5018
I purchased an Elna 7000 on E-Bay.Wonderful machine. I also purchased a 492000-20 walking foot for it. I can not find instructions on how to attach the walking foot to the machine.
I'm assuming that this is a generic style walking foot for low shank machines and it will fit your Elna?
To attach it, you will see a long lever arm at the front of the foot and the little curved bracket at the back of the foot.
Remove your usual foot and the clip on foot holder by undoing the thumb screw. Now fit the walking foot on instead by putting the lever arm around the needle bar and the curved bracket around the pressure bar and then putting the thumb screw back into place and screw up tight to hold the foot in place. Now lower the pressure foot and manually wind your machine forward a few stitches. As the needle bar goes up and down, it should move the long lever arm too which works the walking foot teeth gripping the top layer of fabric with each stitch.
Trust this helps.
Mar 24, 2011 | Elna 8007
How to sew buttonholes
First thing you'll need to do is switch the presser foot.
Your machine should have come with a specific button hole foot.
(might have an R on the bottom)
To snap off:
Raise the needle and presser foot.
Press the red button on the back of the foot holder
and the foot will drop.
To snap on:
Place the presser foot so the pin on the foot lies just
under the groove of the foot holder.
Lower the foot holder to lock the foot in place.
Select which buttonhole style you would like to stitch.
This can be done by selecting a mode (buttonholes are 06-08)
and then adjusting to the desired length and width.
After you do this, lower the presser foot and hold the foot pedal down.
The machine will automatically sew the buttonhole and stop when it is finished
All you'll need to do is just cut the thread after.
Hope you found this information helpful.
Mar 17, 2011 | Janome DC3050 Computerized Sewing Machine
I have a Janome DC 2010. The machine has started to continue to sew even when my foot is off the foot control. I turn the machine off and then back on and it goes to error message fc....then goes to...
my book show the FC stands for Foot Control
have you tryed repluging the foot control into the machine to see if that stops the problem
if you have & it didn't stop the problem
then I agree you need a new foot control
Sep 27, 2010 | Janome 2049LX Mechanical Sewing Machine
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
Machine foot will not work
Have you taken the foot control apart yet? What have you got to lose. Possibly something came loose that you can put back in place? There are small carbon contacts that may be put back in place. Just remember to put it back togeather the same way you took it apart. Or keep an eye on eBay and ask questions. Mostlikely a generic footcontrol will work. Good luck. Rick
Aug 20, 2007 | PfaFF Tiptronic 2040
Sewing Machines Logo
16 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
