Question about Blomberg Dishwashers
Need diagram of blomberg 36141 door
Spring door defective
My back door will not unlock. The push button acts like a normal locked door. Same button spring motion
You will need to remove the door card and inspect the door latch it may be defective.
May 23, 2016 | Jeep 2009 Wrangler Unlimited Sahara
Noise of tromnel de dryer
probably a balancer spring came off, or belt defective
Jan 31, 2016 | Blomberg DV17542 DV17542 24" Front-Load...
The machine shows E07 error upon entering the service menu.
Door latching or lock error
·Door not detected closed
·Check door is closed
·Check door catch and latch
·Check door lock wiring
Check door lock
Dec 11, 2015 | Blomberg Washing Machines
Why is door locked and won't open?
Hello. The door lock switch part number is 34001011 in case yours is defective. Usually, just unplug the unit, wait a few minutes, then plug it back in. The main board will unlock the door. On a front load washer, the easiest way to replace a defective door switch is by removing the spring clamp that holds the bellow onto the front of the unit, pulling the bellow aside nearest the lock and swapping it out. HOWEVER, putting that clamp *back on* can be a real headache--I'm able to replace the clamp by hand on the clamps with the smallest springs. The larger ones will require a threaded clamp spreader tool, available at better(larger) appliance parts dealers. If you are hesitant about attempting this, definitely call for service--if the bellow is re-attached incorrectly, it will leak or can be torn because of wrong positioning which can result in it rubbing against the spinning basket. I hope I helped you!
Aug 09, 2015 | Maytag MAH2400A Front Load Washer
Why does the machine not spin the clothes automatically blomberg WNF 9422 AC
Bad door switch or bad water senser.
On older models it's usually the transmission
coupler.
Oct 17, 2013 | Blomberg WM67121 24" Front-Load Washer...
Renault master side door shows opened
This is likely caused by a defective door ajar switch inside the door on the door latch. I do not have any specific info because this make is not sold here in the USA and that is where Fixya is located.
Jul 13, 2012 | Cars & Trucks
Dishwashers Logo
43 people viewed this question
Top Blomberg Dishwashers Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Blomberg Dishwasher Expert? Answer questions, earn points and help others
