Question about Kenmore Refrigerators
Clear oderless drops of oil under refrigerator door started slow now getting worse two or three drops a day
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
3 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: white hard material is forming in freezer and top
This could be frost or possible insulation but most likely not insulation. Any time you have a seal around the door leak or if there is a problem with defrost or the time of defrost, strange things begin to happen. I have a service manual and the Technical Specs also.
If to know this is not ice I would like a photo of the problem as you mentioned. If you would like the service manual and my assistance please let me know. Thanks Sea Breeze
Posted on Jul 09, 2009
heatman101
  • 43501 Answers
SOURCE: frigidaire gallery series model GHSC39JPB
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 10, 2010
97 c1500 starting problem, battery or starter or electrical problem?
The solenoid on the starter may need to be replaced.
Jul 05, 2012 | 1997 Chevrolet C1500
Samsung refrigerator rf26v ice maker
Check the condenser is clean and clear. Remove all fluff, dust or dirt from under and behind the unit
Apr 23, 2012 | Samsung RF26VAB (25.5 cu. ft.)...
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
The freezer on this stupid thing keeps cycling off for days at a time, completely ruining any frozen food I have in it. Yes, my kitchen gets below 55 degrees in the winter, so I guess that's why--but the...
As the temperature rises the odors will get worse, once the temperature drops below freezing again the odors will get better.
The fluid can collect under the lower panel in the freezer, you will have to take the doors off the refrigerator then remove the rail off that is between the frig and freezer then remove the lower panel. It is very time consuming but that is where you may find the source of the odor.
Apr 12, 2010 | Frigidaire FRT21H8 Top Freezer...
A sheet of ice forms on the bottom left side of the refrigerator section under the Optibin crisper. It has to remover every 3 or 4 days
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 03, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Side by side doors uneven at top
Hi Carol,
Interestingly enough, I answered a similar question just the other day. Maybe there's an outbreak of lazy factory technicians who "forget" to tighten the hinge brackets? Hmmmm. Makes on wonder...
Anyway, it's easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
SG
(pssst!... don't forget to rate me, will ya? C'mon, throw me some love.)
May 29, 2009 | Frigidaire FRS26F4C Side by Side...
Water/freezing to ice at the bottom of the freezer MZD2766ge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all that ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youll melt everything) or by pouring hot water down the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 17, 2008 | Maytag MZD2766GES Side by Side...
Hotpoint side by side noise
Have you made sure that the ice tray/box is inserted correctly? By lifting up and inserting the box until it goes in all the way. Also, check the ice chute from the inside and look for any obstruction such as ice formed/melted causing the blockage. Once you correctly insert the ice tray back in, try the ice button to reset the paddle drive. Also, these icemakers are slow to deliver when the ice bin is low in ice. FYI, if you stack too much frozen goods underneath the area below the ice tray, the paddle drive mechanism will sometimes come into contact with the food packaging. The wrapping from the packages can get caught under the paddle drive and creat a problem by slowing it down. Check and clear it. Be sure to unplug the refrigerator before you do this. Let me know if this helped.
Oct 28, 2008 | Hotpoint HSS25GFP Side by Side...
Water dispenser does not work
the problem is in the freezer door insulation, or lack of, get your model number and serial number handy call 800-386-1215 and see if your machine is under the door replacement program
Worth the try
Apr 10, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
