Question about Camco Hott Rod RV/Camper 6 Gallon Water Heater Converter HR6 Atwood Suburban
Newly installed Hott Rod in 6 gal RV water heater only heats to lukewarm. Has been on for 12 hours. Outside temperature is 60 degrees
  • Camco Master
  • 5,245 Answers
Hott rod is 120Volt AC.
Check voltage supply for undervoltage, or reversed polarity, or tripped breaker.
Check that electric thermostat is set to 120 degrees.
Rotate thermostat temperature adjustment back and forth and see if you can hear water heater working.
Thermostats can be bad, or stick.
Check the ECO red reset button is not tripped out.
If tank was not full of water before power was applied, the element will instantly burn out.
Use continuity tester across bare element screws to see if element is good. Or use multimeter and test across bare element screws shows 29 ohm for 6 gallon, 18 ohms for 10 gallon.
More resources at Hott Rod, for troubleshoot and contact.
http://www.hottrod.net/hott_rod_troubleshooting.asp
Posted on Nov 01, 2012
My atwood rv water hearter is not working right
Model # please? Does it spark outside when first turned on?
Jan 25, 2014 | RTO Atwood Water Heater - 6 Gal LP
Pilot light will not stay lit. already replaced thermal coupler. 6 gallon
A thermocouple makes 30MV power by a temperature differential across the end of the thermocouple, many times people set the entire end inthe flame heating the entire end thus dropping out the power, you cannot bake them into working there must be a temperature differential from the base to tip about a 1.5 inch section. It wil not work correctly if the entire end is hot.
Otherwise the gas valve is bad.
Nov 06, 2013 | Atwood 10 Gal LP Gas /Elect. WATER HEATER
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
No hot water
test the thermostat and the heating elements --also there are resets that can pop push and make sure they have reset
May 17, 2017 | Water Heaters
I have an Atwood G6A-BE model )or possibly G6A-B8) hot water heater. When I throw the starter swith on from inside the RV nothing happens at all. No spark. Nothing. Their is a light next to the switch that...
First of all, regarding propane side not lighting. Try shutting switch off, and go outside and remove the connection(s) from the circuit board, and re-install them a few times to see if it's just a bad connection (corrosion) that will correct itself by removing and re-installing the connector(s). If they appear dirty, use an eraser on end of a pencil to clean the contacts on the circuit board, and perhaps some WD-40 or electrical cleaner on connector, and try it to see if that helps. Keep in mind that the propane part needs 12 volts DC (battery or converter) in order to work. The light at the switch tells me you did have it at one time anyway. Try shutting it off and retry, as well as check for any fuses that may have blown.
One the electric side, I'm going to guess it's a "hot rod" or similar. Obviously you need the circuit breaker on that powers that. (hydro) You should also find a thermostat, probably by looking at rear of tank from inside RV, that will probably have a red reset button in the middle of it. Be sure to shut breaker off before you go poking around that thermostat, so you don't get a shock, seeing how we have no idea exactly who or how it was installed. If you determine that the hydro is getting to the hot rod, but still no hot water, then the element, or rod itself has probably burned out. Personally I'm not a fan of those, but if it serves the purpose, that's up to you. Just be sure to pay attention to any plugs and wiring in the circuit, and watch for signs of them getting too hot, such as discolored connectors, or melting wires or even signs of overheating if it's just plugged in to a receptacle.
Feb 16, 2011 | RTO Atwood Water Heater - 6 Gal LP
Just installed hott rod to camper and it keeps blowing fuses what's wrong
A six gallon universal style hott rod, is supposed to draw only 4 amps when heating. What you need to do is double check any other items running on that same circuit. Not uncommon for people to plug it in to outside GFI and then find out that GFI protected receptacle near sink inside is on same circuit, and they are using that for coffee maker, or hot plate etc, which will in most cases overload the circuit.
Shut that circuit breaker off, and see what else isn't working then do an amperage draw calculation to see if you may be overloading it. If no chance of overload, then you may want to re-check how you wired it in case of a short, or loose connection. If all that checks out good, then I'd look at the hott rod itself as the culprit.
Dec 11, 2010 | Element Hott Rod Water Heater - For 6...
My Atwood 6 gal. water heaters pressure relief valve starts dripping shortly after (8 or 10 min.) heat is called for, and dripping gets stronger until a full flow. I have checked all four hi-limits and...
If the water seems hotter than normal, then a faulty thermostat would be a good bet.
If water doesn't seem any hotter than normal, then check incoming water pressure.
usually 2 things cause that, too much pressure coming in, or thermostat faulty and not cutting out when normal temperature reached, thus higher temperature, and pressure. If both them check out, replace valve.
Oct 30, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a new Atwood 6-gal propane water heater (still under warranty). It works fine except that when warm water is flowing, the burner will start heating only after the water gets quite lukewarm. Can one...
If it's manual light, then only dial or lever on gas control is adjustable, and you can try turning it up a little at a time. It will increase water temperature so be careful, but that should also make it kick back in sooner as well. If it's electronic ignition, there is 2 or 3 heat settings available in thermostats ( little disc behind foam cover under pressure relief valve) . Obviously on those, if you choose higher temperature, it cuts back in sooner as well. If you have electric element, they have a thermostat on rear of water heater as well, behind electrical connection box. If your not 100% sure what I'm saying here, get back with model number of heater inside cover and I'll tell you your options. Please remember to be careful of scalding when you turn up the temperature.
Oct 20, 2010 | RTO Atwood Water Heater - 6 Gal LP
6 gal LP spark ignition... the thermostat controls the temperature very high... can the problem be fixed by changing the fixed temperature control thermostat???
THE T-STAT IS FIXED AT THE FACTORY AND DOESN'T "CONTROL" THE TEMP. IT SIMPLY PREVENTS THE TEMP. FROM EXCEEDING A CERTAIN TEMP. REMOVE THE T-STAT AND THERE SHOULD BE A STAMP MARK EMBEDDED IN THE CASING INDICATING THE TEMP. YOU CAN PURCHASE ANOTHER T-STAT OF A LOWER TEMP. AT A RV DEALER. THERE ARE KITS AVAILABLE THAT YOU CAN INSTALL SO YOU CAN ADJUST THE TEMP.
Dec 23, 2009 | RTO Atwood Water Heater - 6 Gal LP
Water heater working fine but very little hot water coming out
alot of time those small units do not have a fast recovery rate so if they are on for a min or more they might start to lose temperature. if it's on demand especially in cooler climates it might not have enough power to heat it up and keep up with your demand
Jul 29, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Camco Hott Rod RV/Camper 6 Gallon Water Heater Converter HR6 Atwood Suburban Logo
241 people viewed this question
Top Camco Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Camco Water Heater Expert? Answer questions, earn points and help others
