Question about Kenwood MX270 Patissier Food Processor
My KENWOOD MX270 patissier is only giving me 1 speed across all speed settings.Can you tell me what i need to do to get inside the machine and have a look to see what is wrong.Many thanks
It used to work fine & now just goes really fast whatever speed setting I select.
    New Friend:
Hi Ashley, I have the same problem as you. did you fix it? is there a triac in this device? how did you disassemble?
Posted on Sep 12, 2013
2 Suggested Answers
SOURCE: I need a service manual for the MX270. Don't know
How far have you come? There are covers in plastic that cover the screw heads.
Have you got any other information, I have an electrical problem. Need help with electric troubleshooting.
Posted on Nov 27, 2011
No turning of motor in my Kenwood MX270 Patissier
Follow the power, start looking wherever the power stops. Sometimes it can help to reverse phase & neutral to track where the power stops from the other side too. You are only doing this for testing purposes and need to put it back as it should be when you're done.
Dec 08, 2014 | Kenwood MX270 Patissier Food Processor
My Kenwood MX270 patissier doesn't work anymore. I've opened it and checked the brushes (still enough length) ; micro switch also is working. Which component on one of the two prints are suspicious?
Brushes are long enough but it there enough pressure on them to press against the armature? What about the armature? Did you use a meter to check the windings?
Dec 07, 2014 | Kenwood MX270 Patissier Food Processor
Moter is working but dooh hook not working
hi if you still have problems email me and i will try and talk you through,
it may be the belt (teeth worn out) or the pulley (same problem).
the info given in your post is very vague.
if its the teeth on either the belt or pulley there is a simple fix.
remove bottom of base with screwdriver there should be screws under the feet of machine. use a bike valve screwdriver to remove the two remaining screws(depending on make and model)
remove belt, put RUBBER BAND
Jan 24, 2013 | Kenwood MX270 Patissier Food Processor
Kenwood KM336 no power to beater or slow speed outlet
Hi. You have a broken gear in the gearbox either the first motion gear is loose on its shaft or less likely the vertical big gear is loose on its shaft. independent spares for the gearbox are available or complete gearbox
Aug 02, 2012 | Kenwood KM336 Chef Food Processor
I have an old model Kenwood food processor deluxe - model A530 and am distraught that i cannot find where to purchase attachment replacements - mine have all become brittle with age and falling...
As another South African citizen I can sympathize with you when it comes to finding service & after care support.
Kenwood S.A.'s website tells you to take it back to the store where you purchased it. Great help that is?
They do however give a JHB number where you can contact them:
011 474-0153
Let me know if you have no joy from this number.
Best wishes,
Graemevm
Mar 24, 2011 | Kenwood Food Processors
I need a service manual for the MX270. Don't know how to open the machine.
Jan 03, 2011 | Kenwood MX270 Patissier Food Processor
Kenwood a710a mixer suddenly lacks power
sounds like the motor armature is burn. Dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the ehd of the armature. They should be bright copper colour. I the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor.
Feb 04, 2010 | Food Processors
Kenwood MX270 Patissier Food Processor Logo
365 people viewed this question
Top Kenwood Food Processors Experts
Ross Keen
Mitch Vass
Mitch Vass
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
