Question about Whirlpool Refrigerators
Side by Side water dispenser would not stop
Model # ED2CHQXVB01, water dispenser would not stop running.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You will need to replace the switch. Here is the part to order.
To replace the switch:
Here are the basic instructions: " 1. Unplug the refrigerator power cord. 2. Remove the overflow grille from the housing. 3. Unsnap front cover at the bottom of the housing. (You'll need to insert the tip of a flat blade tool into the slots molded into the bottom edge of the facade and twist or pry out,you may want to use some type of pad to eliminate damage to the door panel). 4. Disconnect the front cover switch harness connector and set the cover aside. 5. Disconnect the power wire harness connector (BL/BK and W wires) 6. Disconnect the flapper door heater wire harness connector (if one is present). 7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart."
Posted on Nov 01, 2012
ghappliances
  • 126 Answers
SOURCE: kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Posted on Sep 12, 2008
tech master
  • 120 Answers
SOURCE: kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Posted on Nov 03, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
  • 3 Answers
SOURCE: water stopped running in the dispenser
I had a simular problem! I tried multiple things to make it work!
- bought new filter
- open back of the fridge... (dual outlet water valve)
Finally, I went to a different forum and found a unique idea.
First at the very bottom of the fridge theres a cover remove the cover and you should see the water hose running to the door from the back. In the middle of the hose there a coupler where the hose was spliced by the manufactuer. Now this valve once you separate it will not work correctly, unless you buy a new coupler (4$)... I'm el cheapo, I bought teflon tape for 50 cents (from previous project)... Wrapped around about half dozen times and made sure it wasnt leaking...
Secondly, when you disconnect the coupler no water should shoot out, until you press the water dispenser arm. If water shoots out of the hose on the bottom then you problem is really, really, really easy. You have simplely ice/ or another item blocking water hose to the actual dispenser.
I turned off the frezzer left the door open for an hour or so. I also used my wife's blow dryer on hot, and put it where the ice comes out of the ice maker. I would press the arm peridocially to see if the ice blockage melted yet. REMEMBER: door must be closed for pressure to push on the ice blockage. Thinking back, I might have been finished sooner... I was thinking the water dispenser would work with the door open.
If this doesnt work, then you have other problems... Bad water dispenser selonoid (you can hear this little motor turning even without water), dual water outlet valve maybe broken... Going outside my knowldege level at this point.... But i guess you computer board maybe going bad. Not sure if this computer has anything to do with water dispensing....
Hope this helps! My wife left me alone for about a day or two while she enjoyed the water dispenser...And she broke the vaccum.
Posted on Mar 17, 2009
Sea Breeze
  • 4655 Answers
SOURCE: My Maytag side by side refrigerator's water dispenser won't stop
Below is a picture of the fountain parts. I believe the controls inside the fountain are defective and will need replaced. Temporarily disconnect the control valve to the Fountain control plug this will allow the ice maker to continue to work. Let me know if you need more help and assistance to solve this problem. Below is a link to my site, email and a photo of the parts. Thank You, Sea Breeze appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://www.servicematters.com/maytag_library/docs/16010154.pdf
Posted on May 31, 2009
I used the water dispenser and when done it wouldn't shut off. This is an inside of the unit dispenser. How do you fix this?
Your unit has a inlet valve that the supply of water flows to..This valve splits between allowing water to either the dispenser or the icemaker..This valve may be sticking open allowing water to keep flowing to dispenser..Google Model # w/problem to find location and part#..or call your local appliance repair company
Jan 04, 2018 | Samsung RF266AEPN Refrigeration :...
The water from the dispenser is running and i can't stop it how do you turn of???
The cause of the problem you describe could be ether water inlet valve or the water lever dispenser switch.Locate the water valve at the back of the refrigerator, open the water and take off both plugs from the valve. If the water flow want stop replace the water valve. If it will, replace the water lever switch.
Mar 24, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
GE Refig. water does't dispense
adjust tempt of fresh food side it may be to cold and freezing veg/ and water line .. **** ..
Jan 19, 2010 | GE GSH25KGMWW Side by Side Refrigerator
Water works the ice is not
Your water valve is stuck open. Is it for the ice maker or the water dispenser? It could be the switch in the door calling for water instead of the valve. Does it stop when you unplug the refrigerator?
Sep 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser won't stop. It started automatically and water keeps being dispensed even though we tried pushing the ice button and the lock button. It stopped when I opened the freezer door but would...
I take it this is a G E refrig ? Model number would have helped . If you still hear a hum with door closed , the microswitch behind the dispensor board is bad . Not a computer problem but a simple fix .
Aug 12, 2009 | GE Profile¿ Arctica® Energy...
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Water dispenser
This sounds like the microswitch that is activated by the paddle is sticking . If all the other functions appear to work ok ?? Does this particular model have an ice and water dispenser ?? Does the ice behave in the same way ? if not then i would suggest that the water valve is not closing and needs replacing instead of the microswitch
Sep 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water stopped running in the dispenser
i ihave a side by side samsung rsh1dbbp with ice and water dispenser but the water has stopped working i was wondering if you could tell me how to get the front panel off to check the switches
Mar 16, 2008 | GE GSL25JFPBS Side by Side Refrigerator
WATER RUNS OUT OF THE WATER DISPENSER ON THE DOOR OF THE SIDE BY SIDE
THe problem may be in the water valve for the water despenser,
you could try disconnecting the 2 wires on top of the water despenser side of the valve and see if that will stop it. IF not the valve may need replaceing, may be leaking thu water vavle when closed
Oct 18, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
