Question about NEC Computers & Internet
Nec cd rom slave master - NEC Computers & Internet
3 Suggested Answers
pincer
  • 377 Answers
SOURCE: Using master, slave or cable select jumper
89c8602.gif SETTINGS:
A - Cable Select Mode
B - Slave Drive Mode
C - Mater Drive Mode
Enjoy!
Posted on Mar 01, 2008
stormblade00
  • 161 Answers
SOURCE: LG CD-ROM not ejecting the tray
you need a pin..ir a small object...
do you see the small hole in the front of the cd rom??/you need to hit it so that it will open...
try it first...
hope i've help you.. rate me,..
Posted on Feb 06, 2010
How to set NEC NR 7800A as the master
the First thing you need to do is make sure the jumpers on the back of the drives are set ,one to slave and one to master. there will be a mark either on the case by the jumpers or on a label on the drive. On systems I build
I set the top one to master and bottom one to slave. It makes it easier to hook up the cable to them. The end of the cable goes to the top one and
the other one to the slave.
May 15, 2010 | NEC NR 7800A CD-RW Burner
Need the switch setting for connection as slave
The first selection is for "master" the second will be for slave, and the third is an automatic selection done by the motherboard.
Mar 20, 2010 | NEC ND 1100 (50022667) DVD+RW Burner
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
Reinstalling the original cd rom that came in the computer. do i need to change the jumper settings. it is a samsung sc-148
That depends upon the IDE cable you are attaching the CD ROM to.
There are two IDE cables attached to the motherboard, on IDE 1 connector/cable will be your boot hard drive (C drive) and this will be jumpered to Master and you can attach the CD ROM drive to this cable and set the jumper on the CD drive as Slave.
On IDE 2 connector/cable if there are no drives attached to this cable then the CD ROM drive can be jumpered as Master or Slave..
If there is another drive on the same IDE 2 cable then look at the jumper on that drive, if it is jumpered to Master then the CD drive needs to be jumpered to Slave. If the existing drive is jumpered as Slave then the CD drive needs to be jumpered as Master.
Both drives on the same IDE cable cannot be jumpered with the same setting.
Nov 30, 2009 | Computers & Internet
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
AW-Q170A-B@ Sony DVD RW Atapi CD/DVD ROM drive
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 21, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Enjoy!
Mar 01, 2008 | Lite On (LTN486S) Internal 48x CD-ROM...
DVD writer read but doesn't burn
You are going to have to use the ‘rule-out’ method to begin; remove your DVD-ROM and only install your DVD-RW drive as master; see if that solves the problem (a side-note; burners should be set to master and the other drive should be slave).
NEC/OPTIARC FAQ: http://club.cdfreaks.com/f86/nec-optiarc-f-q-updated-07-10-2006-a-120934/
It will help you if you need the latest FIRMWARE for your drive.
Nov 12, 2007 | Computers & Internet
NEC-3520A Suddenly stop to burn correctly, but reads OK
Have you tried lowering the burn/erase speed? To begin, simply do what you need to do on the lowest speed, and then keep increasing until it gives the error again. This will most likely work. I had this problem and I burn now CDs at 16x.
Jun 11, 2007 | NEC (ND-3520A-KIT-BLU) Burner
Computers & Internet Logo
19 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
