Question about Crosley Kitchen Ranges
E1 & F1 codes showing up on clock/time screen. Clock & timer don't work
Crosley/conservator electric range Model # CES366HQ
fridgetech
  • 473 Answers
SOURCE: What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Posted on Oct 06, 2007
SOURCE: clock,timer and oven does not work on Kenmore gas Range
I was turning the timer and clock knobs on my oven and now it won't work. I don't know what position they are supposed to be in ... any ideas?
Posted on Mar 11, 2008
SOURCE: Gas range makes buzzing sound which goes away when disconnected from electrical outlet.
Call the manufacturer. Chances are it's a common problem and they already know about it.
Ben C.
BensDiscountSupply
Posted on Nov 04, 2008
duby1990
  • 370 Answers
SOURCE: Kenmore Select Clean Self-Cleaning Electric Range Model 6659580
This means you hace a problem with your clock. Take the back off the stove and then pull the ribbon connector off the clock and clean the terminals. If that doesnt fix it replacing the clock should fix it.
Posted on Nov 18, 2008
  • 1214 Answers
SOURCE: KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Posted on Jan 29, 2009
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Error e1 f1
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 27, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
F1 e1 on display (owen, clock, timer doesn't work)
Feb 13, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
Crosley electric stove about 14yrs old
Both indicate replacing the ERC touch pad/ Clock prices vary depending on where you look
Feb 11, 2009 | Crosley CE35100AA Electric Kitchen Range
Range GLP 85800 toop cook ok, flashing E1 -F1- and a few segments
Jan 26, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Display
This is an error code, the error E1-F1 indicates that the Electronic Range Control/Clock has been blown. You have to get it replaced.
Sgt 48
Jun 04, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Crosley Range
Here are the fault codes for Crosley ovens:
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Oct 27, 2007 | Crosley CE35100AA Electric Kitchen Range
Sep 24, 2007 | Crosley CE35111AA Electric Kitchen Range
E1 and F1 flash, with beeps at 15 sec. intervals, & oven not working
crys, the tech sheet for your model states that you need to replace the electronic control (clock) when this error is flashing. Catriver..post back.
Oct 12, 2006 | Roper FGP300 Gas Kitchen Range
Kitchen Ranges Logo
78 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
