Question about JVC KD-G310 CD Player
Connecting an Ipod to a JVC KD-G310
This particular cd player doesn't have an auxilliary input and I want to connect my ipod on a direct line and stay away from fm transmitters.  I have been trying to find the right connector and really haven't had any luck. Any suggestions?
  • Anonymous Feb 04, 2009
    how can i put the option ext in on the radio
Try this, you can connect thru CD Changer Input, that called J-Link. There is cables, that goes from J-Link to 3.5 mm jack.
So you need to buy on the ebay "JVC J-Link to 3.5 mm".
Best regards, Zhenya.
Posted on Jun 02, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 38 Answers
TRY A WIRELESS MP3 FM IPOD CONNECTER '09'
Posted on Jan 04, 2009
    President:
  • 1,990 Answers
Have you Tried www.Crutchfield.com ?
  • 15,935 Answers
It is impossible. There are no component inputs or 3.5mm inputs. FM Modulator is the only way to go. If you are worried about interference, there are mudules that plug directly into your antenna.
  • felix_hernai
    felix_hernai Jan 13, 2014
    Look at e-Bay for a KS-U58 cable. It is design to connect an external 3.5mm to your radio, and use it with an Ipod, cellphone or any device with the standard 3.5 mm jack (Earphone type). Once you plug it, do the following setup:
  • felix_hernai
    Press and hold down the volume knob - press the track forward button until the display shows EXT IN - using the volume knob, you can toggle between two options: CD Changer and EXT IN. set it to EXT IN. - press and hold the volume button again. when you switch sources again, EXT IN should be there.
How to set clock on jvc k d g310
Check the page 8 for JVC KD-G310 CD Player user manual.
Hope this helps.
Jun 29, 2011 | JVC KD-G310 CD Player
My JVC KD-G310 won't switch to EXT IN after plugging in a KS-U58 cable (j-link to 3.5mm connector) into the external component port. How do I get this set right?
did you ever figure this out? i just replaced a broken KS-U58 cable on my JVC KD-G310 and now i can't get it to switch to EXT. everything else on my stereo (CD, radio) works fine.
Jun 10, 2011 | JVC KD-G310 CD Player
How do I switch the bluetooth on, on my jvc kd-bt11 car stereo
How do I sinc my iPhone to the cd player or how do I sinc cd player to my phone
Mar 02, 2011 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Dec 08, 2009 | JVC Car Audio & Video
I have a jvc kd-g720 stereo in my car and when I plug my iPod into the usb port it says "do not disconnect" and even though i have about 2,000 songs on my iPod the stereo will only play the same 49 ones in...
if you are plugging your ipod into the usb port of the kd-g720 it won't play all your songs because this particular radio only plays mp3s through the usb port. ipods play both mp3s and mp4s. so those 49 songs you're hearing are the mp3s on your ipod. in order to play all the songs on your ipod you must buy the cord that plugs in the back of the radio that will connect to your ipod. sorry for the bad news man. i had the same thing happen to me.
Sep 01, 2009 | JVC KD-G720 CD Player
Connecting iPod to JVC KD-LH810!?!
Hi, KD-LH810 has no option for external input. Refer to the picture attached. It is only front and rear line outputs. Don't get disappointed. Buy the accessory cable KS-U100 and you are set. This info is from the installation manual.
Mar 16, 2009 | JVC KD-LH810 CD Player
Help
Hi, Normally, your JVC Car Stereo will not allow direct connection to an Apple iPod. However, there are several aftermarket interface adaptor that will allow you to do so: 1. Connect the iPod to a JVC KS-PD100 which in turn is connected to the CD changer jack of the KD-G720 (rear of the unit). Set the stereo to CD changer external input setting and you're ready to go; 2. Connect the iPod to an FM Transmitter such as the Griffin iTrip (w/ Dock connector) which in turn will broadcast the IPod music as an FM signal. Operating the KD-G720 on FM radio setting will receive the IPod's broadcast music. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Aug 01, 2007 | JVC KD-G720 CD Player
JVC KD-G310 CD Player Logo
1,830 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
