Question about Canon MVX40I Mini DV Digital Camcorder
After market Lip stick camera "Not showing image"
I have a Canon MVX40i Mini DV Camcorder. I have just purchased an aftermarket lip stick camera, with its own 9Volt power supply and two female RCA connecter leads. As per the instruction booklet that came with the lipstick camera, when I plug the camera into the RCA leads that i would use to playpack some recorded vision on my TV, i get nothing. I am only getting the image seen through the camera lense and not the lipstick camera. I have plugged the camera directly into the TV/AV input and it works perfectly so i can only assume its a setting on the camera i need to change, but without the manual i just dont know what to do next. Any ideas...
  • 435 Answers
SOURCE: Cannot transfer from camcorder to computer.
make sure you are using 4 pin to 4pin firewire which looks like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
After connecting,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
Posted on Mar 10, 2009
  • 63 Answers
SOURCE: connecting camcorder to computer
if this doesnt have USB interface, you need a USB Audio and Video Combo Adapter. something like this http://www.computercablestore.com/USB_Audio_and_Video_Combo_PID1600.aspx for optimum video performace, use S video connector. let me know if you have question.
Posted on Apr 05, 2009
SOURCE: want to tranfer video from camcorder canon mini dv zr850 to compu
laptop is not accepting USB
Posted on Jul 25, 2009
old marine
  • 2237 Answers
SOURCE: FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
Posted on Aug 21, 2009
tbreeze47
  • 3083 Answers
SOURCE: Canon ZR200 mini DV Digital camcorder power is not coming.
First thing, clean your battery contacts, both on the battery, and on the camcorder. Make sure the battery is charged fully (measure it if you have a voltmeter). Make sure your power adapter is putting out voltage (again, measure it if you can) Try a spare battery, if you have one, to make sure the first one isn't just dead. Other than those things, you could have a faulty or broken power switch on the unit. That's about all I can think of offhand.
Posted on Apr 12, 2010
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
When I turned on my my camera it's shown no image in the screen .
A common problem with these units is a bad CCD (image sensor). Contact Canon support:
http://usa.canon.com/cusa/consumer?pageKeyCode=repairLanding
They may be able to repair this for free under some sort of an extended warranty, since it is such a pervasive problem-- or if not, you are probably out of luck and will need to purchase a new camcorder, as the repair cost would likely exceed the value of a new unit.
Mar 07, 2011 | Canon ZR85 Mini DV Digital Camcorder
My canon zr85 mini dv camcorder the screen is black when on record even if the side screen is close the eye unit is also black.
It is known problem of ccd imager chip failure in Canon ZR85 camera and ccd imager chip will be replaced to fix the issue.
Local camera repair shop will help you to replace ccd imager chip because solder work is involve.
Thanks.
Jul 21, 2010 | Canon ZR85 Mini DV Digital Camcorder
Screen sometimes won't show what you are wanting to record.
Its known problem of CCD imager sensor in Canon ZR60 and CCD imager needs to be replaced.
Canon will repair ZR60 free of cost as per announced CCD imager support scheme.
Click Canon CCD Advisory for details.
Good luck.
Jan 13, 2009 | Canon ZR60 Mini DV Digital Camcorder
Transfering from a hard drive camcorder to a mini dv
Yes. Using a DV or firewire cable and the right software you can record to DV tape. I know Pinnacle Studio software is capable of doing this and will even control the recording of the taping as well through the sofware.
Nov 20, 2008 | Canon ZR70MC Mini DV Digital Camcorder
No image on viewfinder
There is a short in the wiring were the hinge is at. You can take into a camera store or Best Buy and see what it would cost to replace the wiring in there.
Nov 19, 2008 | Canon DV-MV830i Mini DV Digital Camcorder
Canon MV5i MC Mini DV Digital Camcorder Problem
Its sounds like the ccd unit has gone bad.  You should take into a camera shop and see what your options are.
Oct 23, 2008 | Canon MV5i MC Mini DV Digital Camcorder
Cant detect camera on dv video recording transfers.
Hi, I hope the camera you are talking about is ZR200 Mini DV.
As per its specifications. It has a firewire/DV port.
Therefore, follow these steps. I assume you are using this cable. http://cdn.overstock.com/images/products/L10726964.jpg
I am not sure how you used the firewire cable before.
So, try this. Connect one end of the cable to computer and other to the camera. Switch on the camera and keep it in play/ edit mode (not in shooting mode).
When you connect the other end to the computer,  There should be a popup asking you what to do.
If there is no popup,  Open Windows Movie maker and import video from device. You should see the camera in it.
Hope it works.
Sep 24, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR70MC Mini DV Digital Camcorder just stops
Hello, Sorry to hear that your Canon ZR70MC is not functioning. It would be our pleasure to assist you in being able to capture your once in a lifetime memories again. What is the estimated purchase date of the camcorder? If it is still under warranty the repair will most likely not cost you anything. Camcorder Repair http://www.precisioncamera.com/
Sep 08, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Canon MVX40I Mini DV Digital Camcorder Logo
46 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
