Question about Xerox Phaser 6128MFP/N Multifunction Color Laser Printer Fax Machine, 6128-MFP/N, 6128-MFPN
Ctd sensor cleaning - Xerox Phaser 6128MFP/N Multifunction Color Laser Printer Fax Machine, 6128-MFP/N, 6128-MFPN
Message ctd sensor dirty clean 092-310
Anonymous,
You can click the link below and download the online User Guide. The User Guide will provide information on cleaning your CTD Sensor.
Dell 1350cnw Printer
http://dell.to/1EZ8hL2
Thank You
Dell-Jesse L
Dell Social Media and Communities
Mar 16, 2015 | Dell 1350cnw Laser Printer
Phaser 6128 mfp error sensor ctd
Open up the side panel that houses the toner cartridges. One by one pull out the toner cartridges, with a clean dry cloth clean off the injection port(?) on the cartridge and the injection port on the printer(this will be just inside the where the cartridge locks in. Sometimes these ports get clogged with toner and need a good cleaning, causing a CTD sensor error. Our 6128mfp does this error all the time and we have not had to purchase the new parts to fix the error.
Aug 07, 2012 | Xerox Phaser 6128MFP AllInOne Laser...
CT sensor error Error code 092-310 error code 00002000 restart printer. please note will not restart also unpluged still no respond
The CTD Unit is a Sensor on or near the Transfer Belt Unit on your Dell Laser Printer. This error is advising that the sensor is dirty and may need cleaned.
If you receive one of these errors please clean the CTD Sensor on the Printer.
  1. CBR Tech Solutions orhttp://www.cbrtechsolutions.com
Apr 10, 2011 | Office Equipment & Supplies
I have an orange error light.
If it's not blinking it one of: The PHD (Print Head Device), or belt unit, life is coming to an end. Clean the CTD sensor. Try to clean the CTD sensor with a dry cotton swab. The sensor is located on the front cover (inside).
Mar 23, 2010 | Dell 1320c Laser Printer
Dell 5100cn has error message: Clean CTS Sensor -
I've included a link below to the manual for your printer. Please follow the instructions listed under "Cleaning the Automatic Density Control (CTD) Sensor".
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
Jan 19, 2010 | Dell Office Equipment & Supplies
What is the ctd sensor? it says it needs to be cleaned
Hi!
The CTD is the Automatic Density Sensor. Below is a step by step on how to perform nearly all maintenance procedures for the 5100 series (Including how to clean the CTD sensor)
Should be just what you're looking for.
Hope this helps!
Dec 06, 2009 | Dell 5110cn Laser Printer
I had a 'clean the ctd sensor' error. Cleaned it now it prints half the page in watercolors.
I had a clean the ctd sensor problem as well, as a problem with toner that I had ordered. The problem for me was that with Dell, when I called for support, the young lady on the other end of the phone although nice, was difficult to understand, and did not clearly define how you get to the ctd sensor.
After much prayer, (seriously!) I finally figured out how to get to the area I needed. With Dells instructions, I took the fuser out, thinking it was the transfer roller. The fuser is NOT the transfer roller, the transfer roller in the item that you see when you open the front entirely and look straight down. The difference is that the fuser is the first item out and has lift up blue tabs, while the transfer roller has blue tabs on each side that must click into place to hold and position the transfer roller properly. Once you get this out the ctd sensor is easily accessible, and can be cleaned. After, getting the ctd cleaned, and then replacing the bad toner cartridge, my machine once again worked.
Sherry McGregor Timberwood Mountain Realty,
Jul 09, 2009 | Dell 5110cn Laser Printer
Xerox Phaser 6128MFP/N Multifunction Color Laser Printer Fax Machine, 6128-MFP/N, 6128-MFPN Logo
83 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
