Question about Toshiba Satellite Computers & Internet
Toshiba satellite CD door will not open
DVD door tries to open but can't. Paperclip in the emergency hole does not work
  • Toshiba Master
  • 5,660 Answers
Http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Posted on Nov 01, 2012
4 Suggested Answers
Teis
  • 340 Answers
SOURCE: I cannot open my Toshiba Satellite 2805 S301 DVD-ROM drive.
Hi Packman,
right click the DVD drive, an choose "push it open" -> direct translated from Danish :-)
. but I´m sure you´ll find it.
regards
/Teis
Posted on Dec 16, 2008
  • 6771 Answers
SOURCE: how to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
Posted on Apr 15, 2012
Davethesnake
  • 689 Answers
SOURCE: i have a toshiba satellite pro U400 my cd/ dvd tray cannot open ive tryed opening it with the paperclip solution but still it is not opening
this really is a bad situation,pc's in general are very flimsy in this area in construction ,,you can easily break the internal mechanisms of the drive if you force it the only other option would be to dismantle it completly and see where it is stuck,,release it then re-assemble--good luck---Davey
Posted on Jun 20, 2012
How to open cd
Get a paperclip and straighten it out. Look for a small pinhole on the door of your disc player. They all have one for emergency jams and such. Push the paperclip straight into the hole, about a half to an inch should do it. When it stops on something, push a tiny bit further until the door pops open.
Mar 29, 2014 | E-Machines eMachines Desktop PC
I can't get the cd disc to open on my toshiba and i have a cd in it any suggestions?
Go find a small paperclip - straighten it out and make it as smooth as possible - next look at the CD drive and find the two small holes - place the clip into the left hole until it stops give it a slight push like pushing a thumbtack into cork the drive should pop open if it does not try the hole on the right. If that does not work go tot the control panel open up the CD drive and click the button that has an arrow facing up with a line under it
Jan 13, 2013 | Toshiba Satellite A100-S8111TD Notebook
My CD is stuck in my Toshiba Satellite A505D laptop slot, with no hole near the Eject button.
Look on the cover on the tray near the eject button. Should be a tiny hole.
Get something like a straightened out paperclip and insert it in to the hole and push firmly but carefuly. It's an emergency eject for a stuck tray.
Feb 07, 2012 | Computers & Internet
Toshiba Satellite a135-s2386 won't bootup and CD/DVD drive won't open. The power button, plug button and battery button all come on. I tried taking out the RAM and switching the 2 RAM sticks. I also took...
I assume there is a specific reason that you mentioned the DVD drive won't open. Is it because there is a disk in it that you are trying to remove, and you can't because the laptop won't boot? You can open the DVD drive with a pin or paperclip. There is a little hole in the drive near the eject or open button. Insert a small pin or paperclip straight into that hole and push. It should pop open.
May 01, 2011 | Toshiba Satellite A135-S2386 Notebook
We have a Satellite A500. Somehow I lost the DVD I was working on. How do I get it out?
some pc have an emergency "hole" to extract cd's when the system fails look carefully on the side of your pc and have a paperclip handy so you can just gently press the straightened end into the hole (if you have one)
Oct 19, 2010 | Toshiba Satellite A45-S150 Notebook
My matSHITa dvd-ram uj880es drive wont work.
There is a small hole in the drawer to poke a paperclip, or toothpick into and open it manually. Have you tried to see if there is a cd or something jammed in it? Or try to update the driver in the control panel system.
May 17, 2010 | Computers & Internet
Dell Studio - I can't get the DVD out of the drive. I can read the DVD but cannot remove it.
There is a small hole near the button you would push to eject the CD. Take a paper clip, and unwind it a bit. Stick it in that hole, and the CD should eject. Please let me know if you need further help.
Thanks
Mar 12, 2010 | Computers & Internet
Dvd player door will not open. When I press to open it blinks yellow and stays closed..I have a Toshiba
Hi
Thank you for your query
There are 2 ways to try to get the drive open
1) Click on My Computer
2) Right Click on the CD drive and then click left click on Eject
If this fails there is a manual way
Get yourself a thin metal pin or paperclip, on the drive itself there will be a small hole, insert the pin/paperclip into there and give it a hard push
This will manually force the draw open
I hope this helps
Mar 01, 2010 | Toshiba Satellite A105 Notebook
Will not open anymore, door is broken
There should be a very small hole in the front of the face plate. Insert a paperclip and gently press the emergency release. The door should come open. Try this with the machine powered down.
I hope this helps
Thanks for your interest in FixYa.com
Please vote
thanks
Dec 15, 2009 | Toshiba SD R1102 CD-RW/DVD-ROM Burner
My toshiba computer optical disk drive wont open but it keeps flashing i dont know what to do! help me please
Hi there.
There are a couple of ways to open the CD/DVD tray.
Firstly you can right click on the CD/DVD icon in my computer/computer and select eject from the sub menu, or if you look very close at the CD/DVD drive near the eject button for a very small hole, if you see one get a paperclip, straighten it out and push one end in the hole until the tray ejects.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Toshiba Satellite A135-S2386 Notebook
Computers & Internet Logo
327 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
