Lg Flatron LCD monitor L1910S (L1910SM-AL,AU**R)
  • 173 Answers
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Posted on Jun 13, 2009
oldrogers
  • 53 Answers
SOURCE: why does my LG flatron 1953T LCD monitor (19') goes white
Because the fuse on scaler PCB is blown. Open the monitor, open metal cover, disconnect all cables coming between display and boards, take the chassis off the display.
On back side of display you will see metal cover, mounted with tiny screws, take them off. Unscrew the board also and carefully tilt it up. Observe tiny chip fuse (referenced F1 or FU1 or something with "F") somewhere nearby the connector, ring it, replace it with solder drop.
Take everything back together.
Posted on Sep 11, 2009
bhagyavichar
  • 414 Answers
SOURCE: i am using the LG Flatron L1715S 17
The FLATRON L1715S color LCD monitor with auto-synchronous support, plus it is PC and MAC compatible, has features like simple one button auto setup and is VESA DDC2B, DDC1, Plug and Play compatible.
use the 'Auto' adjust button on ur lcd..
howevr, if u want to configure using win xp/vista..right click on ur desktop->properties->settings->increase the 'screen resolution' to minimum: 640x350 or standard: 1152x864 or maximum: 1280x1024 @ 75Hz..
best is to seek professional advice of ur system admin/vendor....
Posted on Nov 05, 2009
budmrtn
  • 11361 Answers
SOURCE: i have lg lcd flatron l173os monitor,it has a
First place to check will be the caps in the power supply section, but please read below and look at my pictures so you will understand and know what to look for inside the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 08, 2010
lyonzy1
  • 208 Answers
SOURCE: Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
Posted on May 20, 2010
Same power supply board LG L1910s and L1510s ?
just look the amper rating in the power supply if they are the same.
Sep 20, 2012 | LG Flatron L1951S 19" LCD Flat Panel...
How to open lg lcd flatron L1552S
help what open monitor flatron l1552s ? for fix
Apr 11, 2012 | LG 22" FLATRON LCD Monitor
Tengo problemas con la resolucion del monitor, me da 640 por 480 y 4 bits de calidad de color sin posibiladades de cambiarla, he formateado desde entonces salio el problema, me falta un driver pero no...
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | LG Flatron 575LM (White) 15.1 in. Flat...
Lg FLATRON LCD L1730S (L1730SSNTM-AL**E power
Here are the service manuals, please look through them. Please note that if the power supply is not made by LG, it will not show the information in the service manuals.
http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L1730&kategoria=&kat2=schematics
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 19, 2011 | LG L1730SF 17" LCD Monitor
May 18, 2010 | LG Flatron L1919S LCD Monitor
Ho w can i get driver for my flatron touchscreen lcd monitor to activate his features
LG Flatron L 1510S LCD Monitor Drivers : Download from this website:
http://driverscollection.com/?H=L1510S&By=LG
open directly link and download from website, then install in your PC. Your problem will be solved
Jan 29, 2010 | LG Flatron L1510S 15" LCD Monitor
Monitor LG l1910 S that does not function
hello, maybe you supplier is damaged, and this iss the problem
you can solve it with a simple check by multimeter if the supplier gives you more then 9v his ok.
thank you, ron
Mar 17, 2009 | LG L1910S (Silver) 19" LCD Monitor
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
