Question about Intermec CK31 Barcode Scanner
Unable to configure wlan on intermec ck31 802.11
Need to configure wlan - radio 802.11
How to change host on mc9090
Wireless Local Area Networks (WLANs) allow mobile computers to communicate wirelessly and send captured data to a host device in real time. Before using the mobile computer on a WLAN, the facility must be set up with the required hardware to run the wireless LAN and the mobile computer must be configured. Refer to the documentation provided with the access points (APs) for instructions on setting up the hardware. To configure the mobile computer, a set of wireless applications provide the tools to configure and test the wireless radio in the mobile computer. The Wireless Application menu on the task tray provides the following wireless applications: • Wireless Status • Wireless Diagnostics • Find WLANs • Manage Profiles • Options • Enable/Disable Radio • Log On/Off Tap the Signal Strength icon to display the Wireless Applications menu
pg 1-13,
Download manual
Apr 07, 2015 | Symbol Motorola MC9090 Mobile Computer
Hidden Files in Intermec CK3A1 File Explorer?
If you have access to the dock/data cable and have ActiveSync on your PC, you should be able to connect to the device and browse the file system from your PC. Instructions on connecting the device to the PC are here:
http://epsfiles.intermec.com/eps_files/eps_man/935-016.pdf
Alternatively, depending on the version of WinCE or PocketPC you have, you may be able to turn on "show all files" by opening File Explorer, scrolling to the blank area at the bottom of the window, and tap/holding to bring up the context menu. That menu should show you the option to Show all Files.
Dec 16, 2013 | Intermec Ck3, Num Keypad, 520 Mhz,...
What is the intermec 2100 wireless access point used for?
Yes.
Get a spec sheet from here
http://www.barcoding.com/prodpages/Intermec/mlanap2100.pdf
Intermec's MobileLAN access 2100 offers the best in performance and range for Access Point technology. The 2100 is built to handle the demands of challenging industrial wireless networking while managing all your wireless LAN needs. Intermec's MobileLANaccess 2100 supports IEEE 802.11b High Rate WLI-F 2.4 GHz OpenAir 900 MHz Falcon and S-UHF radios. Long-range radio options and patented dual radio support help protect your investment for future migrations. Electronic software distribution simplifies system management. The 2100 offers HP OpenView WWWbrowser Telnet FTP DHCP(Client and Server) BootP and SNMP management options. Simplified software download capabilities. With the 2100 you have a wide selection of external antenna options least cost routing (maximizing bandwidth) and priority queues for superior overall performance in wireless access for your enterprise. The MobileLANaccess 2100 offers advanced network filtering and flooding features. Design the optimal network with Echo diagnostic protocol Client ARP transition for associated nodes and station parameter registration. Utilize the flexibility of broadcast-unicast flooding static and dynamic filtering and much more
Jul 15, 2010 | Intermec (2100D511704704) 802.11b Wireless...
Unable to connect wlan
flash the routers firmware to the latest version and re configure the router
Dec 05, 2009 | Computers & Internet
Intermec 4400 printer fault. Ribbon fault. Looking for a service manual for this printer.
Ribbon fault when using Direct Thermal paper?? This one got me, too. Easy to correct, but issue was with driver & software from Intermec! To reset, go to OFFLINE READY, press MENU, Up/Down to OFFLINE CONFIGURATION, press SELECT, Up/Down to LABEL MEDIA TYPE, then SELECT, Up/Down to MEDIA TYPE DIRECT THERMAL, SELECT, ENTER and MENU out. To be sure, cycle power - and it works again.....
Oct 17, 2009 | Intermec EasyCoder 4400 Thermal Printer
Fail to conncet neternet on my blackberry 9000
  1. In BlackBerry Manager, click BlackBerry Domain.
  2. On the Global tab, click Edit Properties.
  3. Click WLAN Configuration.
  4. In the WLAN Configuration Administration section, double-click WLAN Configuration Sets. Note: WLAN Configuration Sets allow system administrators to push different WLAN profiles to BlackBerry smartphones and associate virtual private network (VPN) profiles to WLAN profiles.
  5. Click New.
  6. Double-click Name.
  7. Type a name for the new WLAN profile.
  8. Click WLAN Settings.
  9. Double-click a WLAN setting.
  10. Select of specify a value for the WLAN setting.
  11. Repeat the preceding two steps for each additional WLAN setting.
  12. Click Apply to configure a WLAN profile.
Please follow the above given steps and hope that this helps you.
Aug 02, 2009 | RIM BlackBerry 8700c Cellular Phone
I am unable to connect through wirelss
You may need to go in, and configure the wireless part of the router.
From a wired computer, try going to http://192.168.0.1
This will allow you to configure the wireless portion.  The manual that came with your router will have your default admin username and password, as well as the instructions on how to configure the wireless part of the network.
Mar 19, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Keep getting error Cannot execute btcc.exe
If your device is registered at Intermec.com you should be able to dowload a firmware flash for the device. Follow the instructions and reflash the device. If this does not work the bluetooth radio could have malfunctioned.
Feb 11, 2009 | Intermec Computers & Internet
Intermec 751B problem after clean boot with iconnect
I had same problem with my Intermec CN3e after updating firmware OS. I also have updated the SSPB version (see it on intermec web site) and problem has been solved.
Nov 18, 2008 | Intermec 751 Barcode Scanner
Intermec CK31 handheld - Configure to read bracket symbol
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Mar 10, 2008 | Intermec CK31 Portable Terminal
Intermec CK31 Barcode Scanner Logo
73 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
