Question about D-Link DIR-615 Wireless Router
Access thru 192.,168.0.1
I fly on line with FSX and host sessions on Local Network. Other players can not access my session. Is there a button \i can push to allow them in? Thank you
  • 2,878 Answers
That IP is internal only, and has no effect on anybody but you and your router. Local Network means same internal network, and not connecting via the cloud (out there in the internet).
Instead, set up virtual server session under advance settings in the routers web interface. This will allow access through the routers firewall.
You will have to do some fine tuning since I am not familiar with the games LAN access requirements.
Posted on Nov 01, 2012
  • Leo Wisted Nov 03, 2012
    I have working on it,but I have been ill. Also my friends whom I fly on line with have been ill as well.I realy appreiatey your help!
    When I get chance To try it I'll report my findings Thank you. Leo
2 Suggested Answers
LASITHA-VEGA
  • 428 Answers
SOURCE: Dlink DIR-655 not accessable after 24 hours
U have to tell me whether u have to unplug machines or the router
If that's the case dhcp for ur router is assigned from some other place. Weird. U have to enable dhcp of ur router. Don't allow running another dhcp from ur local systems only if it is a must. WHEN U CONFIGURE THE ROUTER'S DHCP, MAKE SURE TO SET THE LEASE TO A MAXIMUM VALUE SO THAT IT WANT CHANGE THE IP ADDRESSES FOR MACHINES.
If u assign static ips u have assign the dns and also the default gateway
Type ipconfig /all in a comand prompt and check the settings and set appropriately
Remember, don't allow any other source to assign dhcp for the router.
If this solution works for U please rate the answer
Thanks
Best of Luck
Posted on Jun 24, 2009
I a 16 user L230. my problem is that the terminals freezes. At logon, they are fine but they start to freeze after about 20mins after i switch the system on. its not particular stations athat freezes but...
The terminals never actually freeze as they are getting desktop sessions from the host. What can happen is the desktop session can lock up and thus any corresponding user input doesn't happen due to the session being locked up. Next time this happens, see if the server/host is responsive. Assuming it is, launch Performance Monitor(Provided as part of the Windows OS) by going to Start ' Run ' Perfmon. Monitor your CPU performance. See what's taking all the CPU resources. It's not uncommon to see unncessary programs running, i.e. jusched.exe (Java Scheduler update), qttask.exe (Quick Time updater), etc. All these programs and other unnecessary programs run at startup and run for EVERY single user so in your case, the jusched.exe runs 16 times and can take valuable system resources. Disable these by going to Start ' Run ' msconfig, press enter, the farthest tab on the right labled STARTUP is where you can disable these programs. After deselecting the ones you don't need, reboot the host and tell the dialog box to NEVER tell you again so that it doesn't alarm you're users that you've messed with the startup config. Lastly, don't overlook that fact that you need 1GB NIC and backbone to the server, each device can take up to 15MB/s of network bandwidth.
Jul 05, 2011 | NComputing L230 Network Terminal
Tip
Virtual Server / Port Forwarding does not work from within the Local Network
When you use port forwarding in Virtual Servers and try to test it from within the local network, it may fail. When for example, port 80 is forwarded to a web server in the local network, you may get the router's home page instead of the web server's one or you may get nothing at all. When you try to use the server from outside the local network it will work fine though.
This can happen when you try to access the router's WAN IP address from within the local network. In order for port forwarding to work from within the local network, the router needs to support a feature called NAT loopback. This is not a part of the specification of Belkin routers and modem-routers, so most of them will not have the feature, and if a router does have it, it is not supported.
In order to use the server from within the LAN, you can address it by its internal LAN IP address (e.g. 192.168.2.101).
If the WAN IP address has a DNS host name associated with it, such as www.example.com, and you need to use that name to connect to the server, you can do so by associating the name to the local IP address in the hosts file (a file called hosts with no extension). This file lists IP addresses and host names and is used before actual DNS lookups are done. You can add lines to the hosts file using a text editor like Notepad on Windows. The lines look like:
192.168.2.101 www.example.com www.otherdomain.com # comment
The lines contain an IP address and one or more host names separated by white space. Anything that follows a hash sign is a comment and will be ignored. You will need to change the hosts file on all machines in the LAN that need access to the server.
On Windows, the hosts file can be found in C:\Windows\System32\Drivers\Etc on Windows XP, Vista and Windows 7, in C:\WinNT\System32\Drivers\Etc on Windows 2000, and in C:\Windows on Windows 98 and ME. You need to have administrator rights to edit the file; on Windows Vista and Windows 7 you need to run Notepad as administrator.
on May 05, 2010 | Computers & Internet
Screen freezes and the session falls
I would check my network connections between the terminal and host computer. Make sure you are not experiencing large amount of collisions or loose connections. I would also check the logs on the host computer to make sure some event doesn't correspond to the times you are loosing your session. If there is, might give you a road to track down your problem.
Apr 10, 2010 | NComputing L230 Network Terminal
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Fsx Icon will not save on my desktop
You need to go the FSX directory, find FSX.exe, right-click this icon and drag it to the desktop, release the mouse button and choose "create shortcut here" from the fly-out menu. This will create a proper icon for you.
Jan 18, 2010 | Microsoft Flight Simulator X for Windows
Trendnet 633-GR won't connect to the internet
Well I think that the internet is down from your ISP side
Did you try to call the internet service provider ? Your ISP must be DSL .
with the message " ue Mar 09 13:06:51 2004 PPP network down [INFO] Tue Mar 09 13:06:51 2004 WAN interface is down [INFO] "
It seems that the internet is down on the modem.
Click Here for more info about networking
Oct 07, 2009 | Trendware Computers & Internet
How to i get to play two players on the Nintendo ds lite
You can play multiplayer games with a Nintendo DS Lite even if you don’t possess a copy of the game. If one of your friends has a multiplayer game card, they can use their Nintendo DS Lite as a host for the game session and you can join the multiplayer game.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Things You'll Need:
  • Nintendo DS Lite
    Using One Card to Host the Game
  1. Step 1 Look on the game’s packaging for the "Multiplayer" icon. If the game requires only one player to have a copy of the game, the icon will show two DS Lites: a DS Lite with a black screen transmitting waves to a DS Lite with a white screen. Below the two DS Lites is a range of numbers which indicates how many players the game can support.
  2. Step 2 Put the game card in the Nintendo DS Lite that is acting as the host for the multiplayer game session and start it up.
  3. Step 3 Have the other players turn on their systems. They will use the main menu screen to access the "DS Download Play" icon. They need to tap the icon to begin downloading the game information from the host DS Lite.
  4. Step 4 Begin playing when all of the systems have finished downloading the game information from the host.
  5. Multiple Cards for Multiple Players
  6. Step 1 Look at the "Multiplayer" icon. If every player in the game session needs a copy of the game in order to play, the icon will show two DS Lites, both with black screens, transmitting waves toward each other. A range of numbers is under this graphic and indicates how many people can play at one time.
  7. Step 2 Read the game's instruction manual on how to set up the game session. The steps required vary by company and sometimes by title within the same company.
*reposted from ehow.com
Jun 21, 2009 | Nintendo DS Lite Console
Too many sessions
5200 series can handle 1,000,000 concurrent sessions. Please find the details below link.
http://www.juniper.net/us/en/products-services/security/netscreen/ns5200/
Apr 23, 2009 | Juniper Networks 5200 Firewall
Logout script with session management in php5
just create a logout.php script with the following
<?php
session_start();
session_destroy();
header("Location: index.php");
Have your logout button/link/whatever just open that page which connects to the session with session_start. Session destroy does exactly what it sounds like... it unsets all session data and tells the server to end the session. The header request then just re-directs the user to whatever page you want after (just change out index.php)
Dec 30, 2008 | The PHP Group PHP
D-Link DIR-615 Wireless Router Logo
356 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
