Question about Sony KP-53S65 53" Rear Projection Television
Trying to identify a capacitor on the power supply board
I have a Sony KP-53S65 rear projection TV.
A small 2KV Capacitor (High voltage) near the High voltage tower on the power supply board (Location C514 looking at the face of the board) has burned badly and I cannot read it it could be a 1K but I am not sure...
  • Anonymous Mar 10, 2009
    we heard a loud pop and then the screen went into a small circle and then disappeared.
  • BobinMI May 16, 2009
    Identical problem as this post. G BOARD part #A-1316-365-A
    Note! the number 379 is stamp above the 368 in ink above the number
    365 in the G BOARD part # Also when installing is there current flow direction to be maintained?
    Problem Solver:
  • 11 Answers
IF you have the G BOARD part #A-1316-367-A it's:
1-162-133-00 CERAMIC 390PF 10% 2KV
IF you have the G BOARD part #A-1316-422-A it's:
1-161-754-00 CERAMIC 0.001MF 10% 2KV
Posted on Jan 04, 2009
My kp 53xbr45 will not turn on, the stand by light only flashes
Ck Blue capacitor next to hori out out transistor 2Kv high voltage cap. then where your STK ICs they are big black ics will have part number on them most of the time one of them is bad and will shut tv off always replace both ics and CK all pico fuses around ICs they look like resistors but are fuses they are Green or yellow.
Aug 07, 2009 | Sony KP-53XBR45 53" Rear Projection...
Tv wont turn on.. :-<
It is the capacitor. Look in other forum for part number. I had exact same problem. Was a $2.00 part.
Feb 01, 2009 | Sony KP-53S65 53" Rear Projection...
What is the root cause of capacitor C514 to fail?
I would first suspect the Flyback unit on the D board of causing this (this regulates the power the the other boards and the rest of the TV!
I think that is where to look!
Please rate my response
Thank You!
Jan 17, 2009 | Sony KP-53S65 53" Rear Projection...
Sony kp-48s35 projection
STKs can also shut set off BIG black ics,also check pico fuses.
Jun 13, 2008 | Sony KP-48S35 48" Rear Projection...
Sony kp-53s65 rear projection
C514 is a ceramic capacitor its ratings are 390PF 2KV @10% tolerance
Jun 07, 2008 | Sony KP-53S65 53" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP 53S65 Rear Projection TV
I don't know if this will help you but I just experienced a similiar problem with a sony kp-53s35.
It turns out that a fluid leaked out of a rubber boot on one of the guns( I have no idea what the fluid is or why it is corrosive), down to a circuit board and started to desolve a jumper wire. when it had eaten away enough of the wire, the residue or solution1.gif was conductive enough to cause an arc to a ground bus bar that ran along the circuit board. The TV still worked but would crack and pop like firecrackers inside.
I was able to increase the distance to the ground source by bending the bar away. Then I scraped and scrubbed the board with contact cleaner to remove residue and replaced jumper wire.
Has worked fine since.
Mar 18, 2007 | Sony KP-53S65 53" Rear Projection...
Standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Dec 11, 2006 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
1,001 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
