Question about Ricoh Aficio SP C311N Color Laser Printer
How to clear ricoh SP C311N Sc 542 error code
How to clear SC 542 error code
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
ricohmaster
  • 10 Answers
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
Posted on Sep 19, 2009
micromatikal
  • 2777 Answers
SOURCE: I need the reset procedure
This is how you reset that error:
press the yellow "C" button
enter 107
press the red "C" button and keep it hold till the display changes
turn the power off with the big red switch on the unit
turn power on again
Thanks much - if somehow that doesnt work please reply.
Tim
Posted on Oct 25, 2010
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press 1 , 0 , 7
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press 1 , 0 , 7
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
What does the error message C8 mean?
press the helpful button
found this on fixya by J Mcallister
Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
Ricoh Aficio SP 100SU User Manual Error And Status Indicate On The Control...
Jan 27, 2016 | Ricoh SP 112SU 3in1 Laser Printer
SC542 error
Thats a fuser error. Thermistors needs to be replaced. Alternatively you can try clearing the code in sp mode push yellow button 107 and hold red button. Select 1 and the 5 (mode) then clear scs.
Jul 03, 2014 | Ricoh Aficio AP3800C Laser Printer
How to restart Ricoh SP C231n?
hi there, try to do the following:
- make a program mode (SP 107)
if you dont know SP mode, press clear/resume button then 1, 0, 7 then clear/stop button for atleast 5seconds.
*the monitor should appear 1.system 2.copy 3.
then press 1, then press 7,8,0,7 then #
*the monitor should appear COUNTER RESET then press 1 to start, let it finished then turn off and on your machine.,
*the SC-542 should disappear
note: if this will not fixed the problem, there maybe a problem with your FUSING UNIT, check it!
Nov 29, 2012 | Ricoh Aficio SP C232DN Laser Printer
I have ricoh aficio mp1600 & this machine is error occoured Sc:542 how to solve this problem?
Dec 03, 2010 | Ricoh Aficio MP1600SPF Copier
Sc 542 error code
May 22, 2009 | Ricoh Aficio CL7200 Laser Printer
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio SP C311N Color Laser Printer Logo
111 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
