Question about Samsung Televison & Video
My samsung thunder Tv not power on. when I press sw on/off many time some time TV is on but some time not on.
Samsung thunder television
    Sergeant:
  • 214 Answers
I would check to see if there are any capacitors that are bulged or failing and replace them.
Posted on Nov 02, 2012
5 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: Samsung TXN2726 TV Does not turn on
This denotes a power supply problem. The trouble could be in the low voltage or the high voltage supply. You will need a schematic and at least a multimeter to even beging to troubleshoot this problem. If you do not have a background in electronics. I would suggest taking the set to a TV repair shop.
Posted on Sep 22, 2007
  • 12 Answers
SOURCE: SAMSUNG STANDARD TV SET
maybe you have a blown fuse,try to have a look first inside,if you have a blown fuse then replace it with the same rating,if it blows again replace your power regulator
Posted on Jan 13, 2009
snakehead
  • 1074 Answers
SOURCE: samsung tv wont turn back on
you have a majoe problem.you have blown out a component in the power supply.have a tech repair your set.good luck.to make sure plug out the tv and let it stand for about 10- mins plug it in back there after and see what it does if it does not comes on then it is time to call in the repair man.
Posted on Mar 01, 2010
SOURCE: my samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Posted on Nov 30, 2010
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Feb 05, 2016 | Samsung 50 in. Plasma TV
LN55C750R2FXZA Samsung LCD
What your describing is symptoms of a power surge, Many LCD Tv's are sensative to Slight fluctuation in power during rain, thunder and lightning storms, i myself was happily watching Tv through such a storm at one time, and when i went to bed the TV would not respond remotely or manually, i also disconnected the power from the wall waited for the ready light to disolve and try to turn on, unfortunatley the damage was done, a Tv Repair was nessecary and since then i now use a belkin power surge protector board for my TV and appliances......one question to you is i would guarantee you do not use a surge protection my friend......and your set will need a Tv Repair, it is not major as what is neccesary is a firmware dump on the internal memory and replace the BIOS Battery as well.
Aug 17, 2014 | Samsung UN55B8000 55 in. LCD HDTV
My Thunder tv is completely blocked
sony 36 inch tv re light appears in standby the tv turns on then turn off.
Sep 22, 2009 | Samsung Televison & Video
I can hear u but i cant see u....samsung 42 plasma
either bad Y buffers and y board or also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost about $1 each
Jul 26, 2009 | Samsung PPM42M8HB Plasma TV
Problem with tv
look for reset sw. under unit.
Aug 02, 2008 | Insignia Televison & Video
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung hcn653w power surge
If the set went dead during a storm and will not power up at all, first try unplugging the set and waiting an hour or so, and then plug it back in to a working outlet and try turning it on. If the set still will not respond, your power supply has stopped working and should be serviced by a qualified tech familiar with Samsung projection sets.
Aug 24, 2007 | Samsung HCN653W 65" Rear Projection...
My samsung model- HCN4226W T.V will not turn on
You should always have all expensive electronics on a surge protector. It sounds like for this set the power regulators blown out as I know this set very well and seen it a hundred times!! its a power regulator IC that cant handle a power surge at all. and if thats your only problem, it shouldnt cost more then 175.00 to 250.00 to repair. Now with a surge though there could be other problems as well but from what you stated Im guessing alls ok except what i stated. Now Please do not attempt to repair yoursels, as these sets have alot of Hi voltage inside them even when they are unplugged.. Good Luck
Jun 28, 2006 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
124 people viewed this question
Henry  Thomas
Henry Thomas
