Question about General Electric GE GSHL6PHX (25.9 cu. ft.) Side by Side Refrigerator
Broken ice bin
Ice bin has come detach
    Top Expert:
  • General Elec... Master
  • 9,472 Answers
Replace the ice bin. Here it the part to order.
Posted on Nov 01, 2012
  • William Thomas Nov 03, 2012
    Richard, Thank you for your support with this matter. My problem is now fix- What a quick respones.
I am getting a message saying the Curtain Open and I can't get my ice machine to come on?
I didn't think their smaller units had a curtain, but it is referring to the plastic shield that hangs in front of the ice making grid or evaporator. This must be closed for the unit to run and there is a magnetic reed switch located on the bottom right hand corner of the curtain to prove that it is closed. Actually the magnet is in the curtain and the reed switch is snapped into the side of the grid. Make sure the curtain is in place and the magnet has not broken off. If that is in tact look to see if the reed switch is in tight. IF YOU DO NOT HAVE A CURTAIN... some units had a small plastic flapper at the bottom of the grid that was activated whenever ice dropped. Same system though with a magnet and reed switch. The magnets on some of these curtains and flappers were just surface mounted with some kind of adhesive and others have it captured inside of a plastic pocket made into the curtain. So if you don't see a magnet look for a spot where it used to be. If you want to prove this is the problem just get a magnet and hold it up to that spot for about 10 seconds and see if the unit cycles on. You will then have to order a new curtain or flapper or attach a magnet to the broken spot somehow.
Mar 07, 2015 | Manitowoc QY-0214A Self Contained Ice...
Ice maker keeps making ice, does not stop when bin is full
the ice maker should have what is called a bail arm that is what measures the ice in bin if there is one it should only move up and down if it moves any other direction the bail arm post could be broken
Oct 30, 2012 | U-Line Uline Origins Series...
GE Model GSH22JFTACC Refrigerator. Will not operate with the ice ejecting blade hitting the fill cup and not permitting the mechanism to rotate. It is the blade that is located at the discharge channel...
Sounds like you have a broken ice auger or ice bin. Take the bin out. Look inside the bin to see if you see any cracks in auger or bin. hope this helps.
Aug 23, 2011 | Refrigerators
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Ice guide seems to be broken, how can i remove the cover to access on mod. ed22tqxfnoo.. what will it take to replace it ?? t
I have a Whirlpool side-side freezer-refrigerator model ED22TQXFNOO. When I try to use the ice dispenser in the door. nothing happens. No noise as if the motor is turning the spiral gear to push the ice to the end of the storage bin so the ice will drop in the shute to be dispensed. I cleaned out the storage bin for any build up of frozen chucks of ice. The storage bin is all the way in. There's plenty of ice, but it won't dispense.
(1) Is there a Micro switch in the lever I push to signal the motor to turn?
(2) What inergizes the switch in the back that lifts the bar to let the ice fall into the ice dispenser?
Nov 29, 2010 | Whirlpool Refrigerators
ICE MAKER WILL NOT MAKE ICE
Check for power supplied to unit.
Check that the bin stat has not been broken and has no ice sitting on it. If the bin stat is clean and doesn't appear to be broken, you can attempt to jump out the bin stat and see if the machine comes on.
If the machine comes on, replace the bin stat. If the machine does not come on and you have shut the machine off and back on, then you will need to call for service.
The check valve is a common issue with the Hoshi line-up. If you know where this is, take it apart, clean it, and re-install it.
Jan 08, 2010 | Hoshizaki Freezer Commercial Ice Machines...
The ice will only come out crushed
You may be able to fix this by dumping all ice out of the bin and rinsing the shred/cube outlet in the bin out with warm water until all ice is gone. Do this monthly to maintain a clear bin.
If this does not work there is a broken part in the ice bin and you will need to replace the bin.
Let me know how this works.
Phil
Apr 10, 2009 | Refrigerators
Frost build up on the ice bin
the ice door is not closing or not sealing .. maybe a broken spring or lever...you will need to replace that broken part..
Sep 13, 2008 | GE GSS20IEM Side by Side Refrigerator
General Electric GE GSHL6PHX (25.9 cu. ft.) Side by Side Refrigerator Logo
80 people viewed this question
Top General Electric Refrigerators Experts
Dan Webster
Dan Webster
Darrell
Day Coker
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
