Question about Baumatic Dishwashers
My Dishwasher causes a power cut in my house when it is on.
What is the problem causing the shortage and how can it be fixed?
4 Suggested Answers
  • 177 Answers
SOURCE: I have a Whirlpool Dishwasher GU2300XTVTO, this
If your machine has a fuse or electronic boards in it may have blew the fuse or something on a board.
Good luck
Posted on Dec 23, 2010
bigg t
  • 640 Answers
SOURCE: Dishwasher is shorting out power supply when on hot cycle
The wash tank heater is likely the issue.Remove the 2 wires on the heater and tape them up and run a cycle,let me know.
Posted on Apr 27, 2009
  • 10865 Answers
SOURCE: Burnt wiring insulation dishwasher & aluminum house wire
your problem is most likely the aluminum wiring. Begin by running a copper line to your dishwasher eliminating the aluminum. use Romex Building Wire, NM-B 12/2 with ground and a 20 Amp circuit breaker
Posted on Oct 25, 2009
Computer cuts out when i connect my pentax optio e80
Take care you are to using a USB cable, with a shortage, or a defective connector on the Pentax or in the computer. Be aware if a shortage occurs on an USB port, the voltage dip, caused by the shortage can cause the computer to shut down.
Till you found what is causing the problem, I would not connect the HP, with the same cable to the same USB port.
Oct 25, 2014 | HP Computers & Internet
Flood switch 920 model
Not sure what the actual model number is but usually the F1 error with Fisher and Paykel dishwasher means water has entered the flood switch located at the base. This could be due to leaky hoses or water leaking through the door or lid seal. Wait for a day or two until the water evaporates and try again. Otherwise you will have to dry out the flood switch and then try again. Location of flood switch will depend on your model. For double drawer dishwasher you will have to take the bottom drawer out from the housing and the switch is on the floor of housing. But make sure you take the mains power chord out before touching the insides of dishwasher. Will also need to find the cause of the leak. Other reason for F1 could be loss of power to top dishdrawer if you have double drawer. But in that case the top drawer will have no lights on. The power board is located on the base of housing under bottom drawer. Once again do not touch inside of dishwasher without shutting off mains power.
Jan 27, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have 1999 mercury sable. My power locks, windows and shifting gear stop working after my cigarette lighter melting wires and burning out
By stating what you have found in the cigarette lighter is like you wanted to put fire on your car. BE VERY CAREFUL in future, you cause in your ignorance a strong shortage that's why you had melted and smelly wires. You need a good electrician to rewire and check all the relays and fuses which surely are blown due to this shortage.
Aug 19, 2012 | 1999 Mercury Sable
Hi, the Council shut the water off to our house then when the water was turned back on I put the Whirlpool dishwasher on and now every time I try to use the dishwasher it cuts the power to the house. Will...
Hello - Probably, but someone with basic electrical skills can check the wires in the power connection box under the unit. If these wires look good, the problem is best left to a pro. Some part of the circuit is grounding, causing breaker to trip. Finding out where is an on-site job. Let me know if this info helps- have more if needed. -Thanks- Ed
Mar 11, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Machine flashes f1 and won't turn off
I believe this error code is due to flood switch at the base of the dishwasher housing getting activated. You will have to look behind the bottom drawer after pulling it out as far out as possible. if water is visible then after turning off the power, try to dry the base of the housing with towels and hair dryer. Make sure the power supply is turned off.
There are many causes of the water collecting -ranging from cracked hoses, broken actuater arm or too much foam due to incorrect dishwasher detergent (tablets can cause this). Need to fix the cause.
Nov 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Oct 25, 2009 | Dishwashers
Apr 27, 2009 | Dishwashers
Power failure during washing cycle.
If you are sure there is power to the unit at all times then the fix is replacing the control board , it is the only part that can cause this to happen. Please let me know if you have any other questions.
Phil
Jan 28, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Sylvania 32 in lcd
IF YOU HAD THE TV ON AND PS3 AND PLUGED IN A HDMI CABLE THIS MAY HAVE CAUSED A SHORT AS HDMI CABLES CARRY POWER. YOU WILL HAVE TO GET A REPAIR MAN TO FIX THIS.
Jun 26, 2008 | Sylvania LC370SL8 37 in. LCD Television
Dishwashers Logo
56 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
