Question about HID Corporation Home Security
Want to program a gate opener card that uses an HID card plain white, to a mercedes homelink
Currently use a plain white card that wave in front of gate pad to enter. Need to program that card to the mercedes homelink
    New Friend:
Thanks Joseph for your solution. I'm going to convert my gate openers. Hope it'll work.
Posted on Nov 21, 2012
  • 244 Answers
SOURCE: liftmaster MJ5011 jackshaft opener
look for learn button. push for 1 sec. type in code and hit enter. should work
Posted on Jan 15, 2009
Door Tech
  • 98 Answers
SOURCE: remote/homelink and touchpad problem
Your keypad is not the same "generation" as your remotes. You operator will work with your security plus remotes or your old keypad but not both. Yor cheapest solution is to replace your keypad.
Posted on Feb 07, 2009
  • 3197 Answers
SOURCE: 2006 Honda Accord Garage door Homelink Program with Chamberlain
useful info.
Posted on Sep 14, 2009
  • 3197 Answers
SOURCE: We have Craftsman 139.53684 gargage door opener
You must have an older vehicle or the homelink has reverted to an earlier technology and you will have exactly the situation you describe. You will just have to use the remotes that came with the opener.
Posted on Nov 11, 2009
  • 3197 Answers
SOURCE: I am not able to program my Homelink (car) opener
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxilary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
If this doesn't work your car and homelink may not be compatible.
Posted on Nov 23, 2009
Commercial elite gate opener
You will need a remote that works the gate already.... Hold the working remote 3 to 5 inches away from the home link buttons push and hold the remote button and the button on the home link you want to program after a while the home link light will change it flashing patern .... done this will not work with some rolling code type remotes
Nov 02, 2013 | 2004 Volvo XC90
Is the GTO-Mighty Mule gate opener compaticle with 2012 Chevrolet Silverado Universal homelink?
Its kinda hard but if you follow the info in the owners manual for your truck it works. It is not rolling code like a gargae door this is a dip switch on or off .
Jun 07, 2012 | GTO Mighty Mule Automatic Gate Opener For...
Where is the programming button to add a Homelink equipped car?
Follow the instructions on homelink's website for programming a garage door opener with a learn button. The learn button on the miracle one is inside the control box. After you remove the cover, you'll see the radio receiver on the left side near the bottom of the control box. The learn button is near the front edge of the receiver.
Dec 28, 2010 | Chamberlain Elite Miracle One Swing Gate...
I don't have the owner's manual for my 2002 GMC Yukon XL Denali. Do you know how to program the garage door opener?
I hope this helps.
Programming the HomeLink Transmitter
Do not use the HomeLink Transmitter with any garage
door opener that does not have the stop and reverse
feature. This includes any garage door opener model
manufactured before April 1, 1982.
Be sure that people and objects are clear of the garage
door you are programming.
It is recommended that a new battery be installed in
your hand-held transmitter for quicker and more
accurate transmission of the radio frequency.
Your vehicle's engine should be turned off while
programming the transmitter. Follow these steps to
program up to three channels:
1. Decide which one of the three channels (one of the
HomeLink buttons) you want to program.
2. Press and hold the desired button on HomeLink
through Step 3.
3. When the HomeLink indicator light begins to blink
slowly (this may take up to 30 seconds), hold the
hand-held transmitter about 1 to 3 inches (3 to 8 cm)
away from HomeLink and then press and hold the
transmit button on the hand-held transmitter.
Continue to hold both buttons until the indicator
light on HomeLink begins to flash rapidly (this may
take up to 90 seconds).
If you have trouble programming HomeLink, make
sure that you have followed the directions exactly as
described and that the battery in the hand-held
transmitter is not weak. If you still cannot program it,
move the hand-held transmitter to the left or right or
forward or backward or flip it upside down. HomeLink
may not work with older garage door openers that do
not meet current Federal Consumer Safety Standards.
If you cannot program the transmitter after repeated
attempts, refer to "Training a Garage Door Opener with
Rolling Codes" later in this section or contact the
manufacturer of HomeLink at 1-800-355-3515,
or on the internet at www.homelink.com.
Be sure to keep the original hand-held transmitter in
case you need to erase and reprogram HomeLink.
Training a Garage Door Opener with a
"Rolling Code" Feature (If Equipped)
If you have not previously programmed the hand-held
transmitter to HomeLink, see "Programming the
HomeLink Transmitter" listed previously. If you have
completed this programming already, you now need to
train the garage door opener motor head unit to
recognize HomeLink.
1. Find the "Learn" or "Smartbutton" on the garage
door opener motor head unit. The exact location and
color will vary by garage door opener brand. If you
have difficulty finding the Learn or Smart button,
refer to your garage door opener owner's manual or
contact the manufacturer of HomeLink at
1-800-355-3515, or on the internet at
www.homelink.com.
Because of the steps involved, it may be helpful
to have another person assist in programming
the transmitter.
2. Press the Learn or Smart button on the garage
door opener motor head unit. An indicator light will
begin to flash when the motor head unit enters the
training mode.
Following this step, you have 30 seconds to
start Step 3.
3. Return to HomeLink in your vehicle and firmly
press and release the programmed HomeLink button
three times.
The rolling-code garage door opener should now
recognize HomeLink. You may either use HomeLink
or the hand-held transmitter to open the garage door.
If after following these instructions, you still have
problems training the garage door opener, contact the
www.gmcextendedwarranty.com
Dec 19, 2010 | GMC Yukon XL Cars & Trucks
PROGRAM PRIUS GARAGE DOOR HOW DO I PROGRAM THE BUTTONS ON THE PRIUS' REAR VIEW MIRROR TO OPEN THE GARAGE DOOR
There was a minor change for mine to work.. see below..
- you must park your Prius close to the gate opener, leaving it running (obviously not in the way of the gate closing)
- Hold the button the the mirror and then push your garage door remote button and hold until the light on the mirror starts to flasyh fast. THIS programs the button on the mirror, but not the garage opener - yet (this was key for me)
- locate the "learning button" on the opener itself
- press the "learning button" on your gate opener and then get back into the Prius within 30 seconds (more time than it sounds) and press the SAME Homelink button you just programmed above. I don't recall how long I held the pre-programmed button, but the light will flash as I recall.
- Then, when working the garage door, you may need to hold the mirror button for a good second for it to work - but I had tried for months to get mine to work, and finally after reading many posts, the above sequence worked on my 2008 Prius with my Lift Master, Security + rolling codes garage opener.
Just - program the button on the mirror with your remote FIRST.. the garage opener will not work.. then use the Learn button on the garage opener and the SAME BUTTON you just programmed.. and it worked great for me. Not programming the mirror button first will not work. Using only the Learn button will not work. You must program the mirror first with the remote, then use the learn button and the SAME button on the mirror. Hope this helps.
Scott 2008 Prius with Lift Master Security + opener.
Oct 30, 2009 | 2007 Toyota Prius
Unable to program my new 2009 Altima Hybrid Homelink to my gate
The Learn Button is in a Silver little metal box that is in the opener housing but separate from the opener itself, pry off the case which kinda wraps around the reciever, it will say liftmaster of chamberlain the learn button will be in the reciever
Apr 05, 2009 | 2008 Nissan Altima Hybrid
I need to know the process on how to program the cars built in gurage door opener on a 2001 chrysler town & country
Hi my name is Allen!
Program a previously trained homelink button as follows... 1. Press and hold the desired pre-programmed HomeLink button for at least 20 seconds (but no longer than 30 seconds) until the indicator light begins to flash. Without releasing the HomeLink button, position the hand-held transmitter 1-3 inches away from the homeLink surface keeping the HomeLink indicator light in view. 2. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button (or press and "cycle" - as described in "Gate and Canadian programming"). DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful programming) The previous device has now been erased and the new device can be activated by pushing the HomeLink button that has just been programmed. however, it may be necessary to follow steps 5-7 of the "programming" section to complete the rolling code training. This procedure will not affect any other programmed HomeLink buttons.
Dec 20, 2008 | 2001 Chrysler Town & Country
Remote garage door opener
1-800-355-3515
www.homelink.com
1. Position vehicle within 10 feet of garage door- engine off and battery on.
2. Press/hold 2 outside buttons of Homelink transceiver until red indicator starts flashing rapidly, then release button. This should take about 20 seconds. This erases any previously learned codes.
3. Press/hold remote control and press/hold button of Homelink transceiver simultaneously. Slowly move remote control from 5" away to 1" away from Homelink transceiver. Release both buttons after red indicator starts blinking rapidly. This should take about 5 seconds. I discovered that the Homelink in my TL is a bit faulty because it took much longer to accomplish this than when programming the Homelink in my MDX. My TL's Homelink may "unlearn" it's code in the future and the needed proximity of the TL to the garage door may be much closer than desired until I get the Homelink fixed.
4. Press training button on garage door opener unit until the indicator lights illuminates- this should be immediate.
5. Within 30 seconds press/hold the Homelink button for 2-3 seconds until the red indicator starts flashing rapidly. Repeat a second time. It should now be programmed. Check it by pressing the programmed button on the Homelink receiver.
6. When programming more than 1 garage door opener unit, disconnect power from unit before programming more units. By not doing this the programmed unit could conflict with the unprogrammed units commands.
Problems:
1. The Battery in the garage door remote may be too weak to program Homelink. However, the battery may be strong enough to operate the garage door. One of my remote controls had a weak battery- my system was installed today, fresh out of the box. I had to use the second remote control for the programming of Homelink on my 2 vehicles.
2. Antenna on the garage door opener unit must be hanging down, fully extended.
Oct 11, 2008 | 2003 Acura MDX
Home Security Logo
570 people viewed this question
Top HID Corporation Home Security Experts
Lawrence Oravetz
Are you a HID Corporation Home Security Expert? Answer questions, earn points and help others
