RCA PSAPP1R My new RCA PSAPP1R surge protector has started beeping randomly, but constantly once it starts. The unit began intermittently beeping on the second day it was installed. It is now about two weeks old and it has been going off about 24 hours now. It tends to beep three times and then pauses for a few minutes... sometimes it beeps only 2 times and then pauses. The red LED indicating power is lit, as is the green LED indicating protection. I have an analog meter, and it seems to be getting good power. I am showing 120 vac hot to neutral and about 117 vac hot to ground. One other item - the house has a Leviton 51120-1 whole house surge protector installed. Yes, I realize this sounds redundant, but I installed the unit on a 170-bottle wine refrigerator because the first one had a circuit board go out and was a major hassle to get repaired. My question is this... there does not seem to be any type of RESET button on the unit, so how do you perform a reset? I have tried unplugging the unit for 15-mins or so and then plugging it back in, but no dice. ????????????
4 Suggested Answers
davecon
  • 85 Answers
SOURCE: It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Posted on Apr 22, 2008
Democritus
  • 120 Answers
SOURCE: 6 beeps on start up, no video
Without knowing what yo have for a BIOS, it is difficult to diagnose. The below link is a list of beep error codes for different BIOS types. Check your BIOS to see if it is one on the list and see what it means:
http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=guide_beep_codes
Posted on Dec 12, 2008
leecom72
  • 4806 Answers
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
Posted on Dec 14, 2008
Continous whine sound on APC Surge Protector 600
Hello Glen,
Yes, The batteries in UPS systems have a 2.5 to 3 year life span so your unit does need new batteries. The whine is usually caused by the charge circuit trying to push the charge to the damaged cells in the battery. You should be able to get replacement batteries from your local battery dealer, no need to order "special" UPS batteries. Open your UPS cover and remove the old battery and bring it to the dealer and they will match it to their stock.
Jul 19, 2012 | Computers & Internet
Tv tries to come on and the Vizio Logo lights but is very dim. It will go from amber to white, go off and repeat. I pressed and held the on button on the side and it began clicking and came on for about 45...
Lightning definitely sounds like the issue.We had our computer plugged into a surge protector last year but our computer got fried.We purchased a Belkin surge protector which is much better.The smallest one they sell I believe is 6 outlets for $50 BUT they back that with a $50,000 guarantee.If something fails due to their product,they will reimburse you for up to $50K,and I already called just in case,you do not need receipts.They make up to 12 outlets and that has a $300K guarantee.We live in the lightning capital of the country,Tampa area,and so far no problems.Also,it's not really good to hold down the button to force it to come on because the clicking probably means it's trying to save itself,but at this point it doesn't much matter.The TV will need to be looked at.I wish I could help more but the TV makers won't let me as a consumer,find any parts prices or diagrams.Sorry , but good luck!
Aug 05, 2010 | Vizio VF550M 55 in. LCD HDTV
I need help with a Sola s41500trm Battery Back-Up system. it makes a beeping constant beeping noise. i think it may need new batterys. i found the batterys on apexbattery.com, but their $80 each. is there...
No, This is a old emerson designed 1500VA/1050W unit from the pic in the sola tech pdf so, it needs a battery to start it, you could put in a new small battery that would work. it is a older high quality unit worth keeping, it takes ( i think) 4 x 12V 7Ahr blocs
Hope this helps
Thanks for using FixYa
Dec 05, 2009 | Computers & Internet
Beeping noise
I've had the Dell 1720dn at my desk for years. Worked flawlessly. Moved it to a different workstation and it began beeping immediately while printing. Another site said to plug it directly into the wall, instead of a battery backup. I unplugged it from the battery backup outlet, and plugged into a surge protector only outlet on the same battery backup unit.... NO MORE BEEPING. Hope this helps someone else.
Apr 01, 2008 | Dell 1720dn Laser Printer
Reset Surge Protector
You can fix it by doing this. but first you need to make sure you leave your house for at least 4 hours so you don't have to be hearing that frigging noise, IT CAN BE DONE! i fixed it.
my unit would start beeping as soon as I plug it in wall, and red light come on, the software is telling me the battery is unplugged
this is what i did in order.
1. unplug all cords, connected to the unit, and power cord to the wall.
2. hold the power button
3. still holding the power button, Connect it to wall. (red light would be on but no beep)
4. I watched TV for 6 hours, red light still flashing
5. disconnect from wall
6 connect back to wall
I heard the unit click one time and green light came on, is charging now....
Jan 27, 2008 | Computers & Internet
CyberPower 325SL backup system
How old is the unit and have you ever replaced the batteries?
Sep 14, 2007 | CyberPower 325SL (CPS325SL) UPS System
CyberPower 325SL won't work...
NEVER mix surge protectors and UPS!!!. Doing so overloads whoever of the two gets connected to the wall. This equipment is built to be plugged DIRECTLY to the wall. Your unit just crossed it's inner battery. Take it to a recycling center, then stop on your favorite electronis shop and buy a new one.
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
