Question about Craftsman 4 Cycle Blower/Vac
Blowing oil on an 8HP craftsman snowblower
I had a carb problem that cantaminated the oil with gas which caused the oil to blow out a tube on the carb side. I drained all the oil out and refilled it with 5W 30 oil to the proper amount. It started first pull but the new oil is blowing out this same tube. Checking the filler rod the new oil has air bubbles in it. Where does this tube attach because I can't see where it would attach to anything or is it a breather hose that just hangs down? Will I damage the engine if I run it?
  • bmckay516 Jan 04, 2009
    Thank you for your help. The tube is attached to the valve cover. Is it purging excess air and stop when this air clears?
  • chicob Jan 31, 2009
    i have the same problem with an 8 hp tecumseh thought there might be water in oil so i changed it but still blows it out the breather tube any other sugestions?
    Scholar:
  • 76 Answers
That is a breather tube, I can't picture the motor off the top of my head but that tube is either connected to the valve cover or if the tube seems to go up over the motor then that tube goes down into the motor. If it's the one thats connected to the valve cover then it's possible there is to much oil in the valve box. If it's the one that seems to go up over the top and in then if your just alittle to much over full you'll get oil out of that tube cause that tube sits alittle above the oil level.If your oil level is right on the line then I would run it for a bit then check the oil level. If the level is still good then you should be ok but keep an eye on it if it continues to blow oil out I would take it in to get looked at futher.
Posted on Jan 04, 2009
  • Mark Tripp
    Mark Tripp Jan 04, 2009
    Your welcome and antime.
    Yes and on some engines they atach the breather to the top of thecarb. to assist the carb. in fuel delivery kinda like a fuel pump or diaphram.
Snow blower dying out?
Its the carburetor. Needs to be cleaned. But try this first. On the bottom of carb is a round bowl with a bolt holding it on .If snowblower has gas in it clamp fuel line to stop fuel leakage. Remove bolt and pull bowl down slowly. Look in bowl to see if there is water at bottom under gas.To be sure dump out fuel and clean out bowl with clean rag and some air. Next place a small piece of tube in bottom of carb that you took bolt out to hold bowl on. Blow air in to remove any dirt and reassemble carefully and refuel carb and start engine. Good luck.
Feb 17, 2014 | Craftsman 21" 179cc* Single Stage...
Ran perfect last yr , gas was stale drained carb bowl and replaced gas it started up right away then cuople mins later it started blowing oil out of the oil over flow tube
Sounds like the Needle valve in the carburetor is stuck 'down' letting gas continually run from gas tank into carb. When the valve can't go up (Close) gas will run past the carburetor and into the crank case I bet your oil is full of gas. Check oil level see if it is overfull
Jan 22, 2014 | Tecumseh Snowblower Snow Blower Starter...
Had stale gas in carb drained used new gas it started right up but now oil blows out of the oil over flow tube never did that b4
I think I answered this is the Snowblower section.. See if oil is over full. If yes than gas is getting past the Needle valve in the carb. Stale gas = possible stuck needle valve. Take bowl off carb and make sure Float moves up and down freely.
10% Ethanol gas is BAD for carburetors . tell congress to stop forcing this stuff
Jan 22, 2014 | Garden
My craftsman lawn tractor smokes when I start it and it is blowing oil out. What is causing this?
check the oil and see if it smells like gas the needle valves int he carb have had alot of problems seating and gas over flows into the crank case change the needle and seat and change the oil
Jun 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 8hp snowblower starts but will not stay running.craftsman 8hp electric start dual stage modle 536881800 snow thrower
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
Dec 19, 2009 | Garden
Kolher 17hp motor blowing oil/gas mix out of breather tube
I had the same problem! I found that the needle valve in the carb was not shutting off the fuel flow when not running. Either replace needle valve or put a shut off valve in the fule line. Should take care of the problem
Apr 03, 2009 | Craftsman Garden
Oil blow by
A little blow by is normal. Make sure the oil level is correct. If there is excessive blow by, then check the reed valve under the valve cover. It may be damaged or loose.
Jan 31, 2009 | Craftsman 16" High Garden Tractor Snow and...
Craftsman 4 Cycle Blower/Vac Logo
1,031 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
