Question about Candy Washing Machines
Replacing door seal on candy Cm1 146 80 washing machine
SOURCE: Replacement door seal/gasket
Replace a tub seal for a frigiduare front loader
Posted on Apr 08, 2007
SOURCE: washing machine replacement door seal
It is held on by a spring that stretches around the outside of the seal. The seal simply hooks on to a small lip so all you need to do is start in one spot and push it down and away. Then just work it around like removing a bike tire until it is fully removed. Be careful of the spring. It is hooked together so it may unhook once some of the tension is removed and snap around.
Posted on Nov 17, 2007
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
  • 1462 Answers
SOURCE: fitting door seal
this is general for fittying door boots.
on cabinet, door boot is usuallyn held by a wire ring tensioned by a small spring. prise it out with a screwdriver.
on tub, door boot is held usually by a giant hose clip for want of a better description. unscrew the tensioning screw and remove.
door boot will then pull off - just pull it off in one place then go round the circle.
to refit.
lubricate the groove in the door boot that fits on the tub with washing up liquid. insert groove on tub at any convenient place and force into position by running thumbs round it in opposite directions. this is a knack i have to say.
when on, replace the giant hose clip and tighten.
slip the outer part of the door boot on the cabinet - this is usually easy. replace the holding clip.
put onto rinse cycle to test for leaks
good luck
Posted on Jun 24, 2008
  • 135 Answers
SOURCE: Zanussi washing machine door seal removal
This is quite tricky, first take off the retaining ring on the front door port, remove the seal from this rim. The back of the seal is held by a spring band. the best way to remove it is to get a good grip on the seal at the top then lift and pull (thats the easy bit), to put the new one on i always lubricate the recess on the seal with washing-up liquid and feed the seal on from the bottom with one hand whilst following it around with the other hand to stop it coming off. Once it is fully on it can then be rotated easily into the correct position. Getting the spring back on will require an extra pair of hands for obvious reasons.
Good luck with it and keep the swear box handy lol.
Thank you for using fixya
Posted on Nov 26, 2008
How do i fix a door lock on a candy washing machine
go too you tube
type in your candy model and door lock replace etc string get some video help you would be amazed i found over 50 models covered and in great detail
Dec 19, 2014 | Candy Washing Machines
How do i change a candy washing machine front door seal?
you can use some very strong string
much like putting in a windscreen to an old car
its called paracord try ebay for a couple of meters
Oct 01, 2014 | Candy Washing Machines
Replacing Door Seal on AQW130 Candy Washer Dryer
JUST THE SEAL IS ALL THAT IS REQUIRED AND A GOOD SET OF TOOLS AND MECHANICAL SKILLS, i AM IN THE USA SO CAN'T RECOMMEND ANY PLACE TO BUY IN UK
Jul 28, 2010 | Candy AQW130 Front Load Washer / Dryer
Renew washing machine front door seal
ye sthey sell those local maytag store ok slips in and round
Feb 03, 2008 | Candy CNW136 Front Load Washer/Dryer
Candy washing machine
door seal replacement can be done with a little skill and a bit of common sense, 1st thing to do is buy a replacement quoting make model etc, then you will see how the seal is shaped to fit, unplug the machine and work from the front, open the door and remove the thin wire clamp from round the edge of the door seal, remove from the lip of the cabinet and that will enable you to see inside the casing, there is a wire spring or an adjuster on the drum end of the door seal, remove that and the seal will pull off with a gentle pull, refit as removed, take note how you removed wire etc, check for leaks and state of fit before leaving machine unattended and running difficult job hard to describe in writing, but not too hard with a little thought
Sep 17, 2007 | Washing Machines
Smelly washing machine
I had that. Eventually found a dead mouse in the door seal. Sorry but it's true.
Sep 14, 2006 | Candy AQW130 Front Load Washer / Dryer
Washing Machines Logo
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
