Question about Sport & Outdoor - Others
2004 115 yamaha outboard motor spitting and sputtering at idle hard to crank have to choke it
Fame_Guru
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
  • 86 Answers
SOURCE: My mercury 35 hp outboard motor idle's fine but won't run
While at the river try to adjust the fuel air mixture. When you are on the water it puts the engine under a load and if that dont work then dont be afraid to bump up the idle stop screw slightly.
Posted on Aug 06, 2009
  • 86 Answers
SOURCE: Motor spits and sputters
If it is old enough to have points then I would check them and make shure they are clean and gapped at .020. if that is noth the problem then it sounds like a fuel issue. Either a weak pump or a dirty carb.
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Apr 13, 2016 | Motorcycles
Why my 2006 tohatsu 5 h.p outboard will not idle down to trolling speed without spitting sputtering then dieing.
Remove the carburetor and thoroughly clean all of passages by compressed air you probably have blocked passage for fuel on the low idle side
Nov 09, 2014 | Seloc Mercury Outboard Engine Repair...
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
Outboard engine hard to start.
Press the key inwards to activate the Choke. Also, you only pump the bulb when the tank runs dry. Pumping after a successful run, shutdown, pump and restart can flood the engine.
If that doesn't work, claim under the warranty.
specs
Yamaha F20LEHA Outboard Motor Portable
manual, which oddly, doesn't mention a choke feature.
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-17_1378.pdf
Apr 19, 2017 | Boating
2003 yamaha yzf600r carbureted, When I twist the throttle (fast or slow) it sputters for a second then revs up and just sits at 4000 rpms, even if i just poke the throttle at idle it will rise up to 4...
Hi, Striker_1011 and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZF600R Forums View topic Weird idle surge issue
YZF600R Idle Problem Rev Problem
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
May 02, 2011 | 2003 Yamaha YZF 600 R thunder cat
It will crank but will not idle after it warms up runs rich spits and sputters it made me pick a model it is not correct it is a 1996 yamaha xt 350
Carb needs cleaning. Pay special attention to the pilot jet and idle mixture circuits. Use carb cleaner to clean out these circuits, not wire.
Nov 02, 2010 | Yamaha XT 600 E Motorcycles
Aug 02, 2009 | Light Outboard Motor Boat Bass Fishing...
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
Apr 27, 2009 | Boating
Sport & Outdoor - Others Logo
95 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
