Question about EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Intel core 2 Quad Q6600 compatible with ECS P4M800PRO-M2
ECS P4M800PRO-M2 mobo - is it compatible with Intel Cpu Core 2 Quad Q6600 2.4Ghz Fsb1066Mhz 8M Lga775 Tray Thanks!
    Sergeant:
  • 238 Answers
According to their website, no. The core 2 duo is supported, but not quad core. http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=674&CategoryID=1&MenuID=16&LanID=0
Look under the cpu tab.
Posted on Oct 31, 2012
No signal
Posted on May 11, 2013
SOURCE: asus p5qc-se motherboard,intel q6600
what i would start with is this. check all the connection first to the motherboard. cables to hard drives cd/dvd players power connectors. once u have dun this and still wont work, trace back the steps b4 it started to do this. remove 1 component at a time continuously restarting the computer. once the u isolate the component replace
usually and a no-boot bios condition 3 things need to be present first. keyboard, mouse and monitor.
also. another thing i would try is this.. if u installed multiples of memory remove then to a single stick and see if it boots.
nothing worse than 1 stick of bad memory to crash every thing
Posted on Apr 26, 2009
Ryan5443
  • 336 Answers
SOURCE: Will this CPU be compatible with this MOBO?
Okay your Processor is not supported by your System Board. I will take some time and look to see what would be a good upgrade, but it may take a few days.
Ryan Frame
Creative Energy Associates Technical Center
Posted on Apr 27, 2009
  • 156 Answers
SOURCE: Is a Intel D915GAG Socket lGA775 Motherboard
no it cannot take in a core2quad processor it has only the following compatibility
click here
Posted on Dec 05, 2009
  • 60 Answers
SOURCE: Can I upgrade my processor with my current motherboard
No, this board is not compatible with the Q8300 chips. You can view a list of compatible ships at: http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20775&model=45CMX&cputype=Intel
Posted on Jan 03, 2010
  • 961 Answers
SOURCE: hello, i got maximus formula
This is your board by the numbers you supplied:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131199
You have Via P4M900 and VT8237 chipsets and Realtek ALC662(sound)
This is Asus's link for your board:
http://www.asus.com/Motherboards/Intel_Socket_775/P5VD2VM_SE/#download
It's supported to Windows Vista so, it may or may not work with Windows 7.
You can try your sound here, if necessary:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
and, this is Via's link:
http://www.via.com.tw/en/support/drivers.jsp
It appears your board has the support for Windows 7, if that is what you are running so these should be all you need. Let me know if I can help you further.
Dave
Posted on Jul 17, 2011
How Is a Q6600 core 2 quad cpu compatible with a foxconn g41 mxe-v motherboard?
Yes it's compatible. The type of motherboard can be any board that uses "Socket 775".
Aug 07, 2014 | Intel Computers & Internet
Intel E6750 compatible?
Motherboard supports the following processor upgrades:
  • Intel Core 2 Quad (Y) Q9xxxx
  • Intel Core 2 Duo (W) E8xxx
  • Intel Core 2 Quad (K) up to Q6600
  • Core 2 Duo E6x00 (C) up to E6700
  • Core 2 Duo E4x00 (C) up to E4400
May 13, 2014 | HP Pavilion a6838f Desktop PC
Intel Core 2 Quad 8200 with a 945GCT-M3? Will it work?
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=719&DetailName=Feature&MenuID=1&LanID=0
Here you can see the supported cpu list.
The quad core cpu will not run on this mainboard.
Here is info about the quad cpu:
http://ark.intel.com/products/36547/Intel-Core2-Quad-Processor-Q8200-4M-Cache-2_33-GHz-1333-MHz-FSB
But you can add a Intel Core 2 Extreme LGA775
This should give a noteable difference compares to the old single core cpu.
Remember also to buy a bigger cpu cooling element.
Here is no upgrade for the bios.
Good luck
Nov 18, 2012 | Computers & Internet
Dell inspiron 530 mobo problem
Yes - both MOBO are same form factor.
You will need to remove the backplate (that is the part that surrounds the ports) from the case.
You will need to insert the backplate for the new MOBO in the case.
The CPU and RAM should be direct swap.
Dec 27, 2011 | Dell Inspiron 530 Desktop Computer...
What is the fastest cpu chip you can put in the mother board
Your motherboard supports the following processor upgrades:
Oct 08, 2010 | HEWLETT-PACKARD 461068001 Motherboard
Dell Motherboard/ OWG 855, what would be the fastest cpu that i could use
Intel Core 2 Quad Q6600 @ 2.4 GHz is compatible.
Good Luck
Mark
Dec 07, 2009 | Dell (2336V) Motherboard
Ryan Frame
Apr 27, 2009 | Intel D945GCZ Motherboard
E8400 or Q6600
personally i have the q6600 which is a quad core processor, all the others you listed were dual core, personally i use alot of programs all at once which is good if you have a quad core, but just for general music, data, and streaming, the e8400 is probably better for you, its a 3ghz processor.
Mar 20, 2009 | Intel Core 2 Duo E8400 LGA775 3.00GHz 6MB...
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to : it_mid@yahoo.com
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2889&ProductName=GA-G31M-ES2L
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
EliteGroup P4M800PRO-M2 (V2.0) Motherboard Logo
646 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
