Question about Maytag Washing Machines
How to replace rear shocks on a Maytag MAH5500BWW washer
Machine walks in spin cycle and is unbalanced
  • 3 more comments
  • Donald Saber Nov 01, 2012
    Thanks for trying, but the diagramsin this manual show 4 completely different shocks than what our washer has. Mine only has two in the rear and they bolt through the floor of the washer not through bolts.
  • Richard Roth
    Richard Roth Nov 01, 2012
    What is the model number listed on the unit?
    MAH5500BWW Ser. B6093706R
  • Richard Roth
    Look at page 7-8 of this manual. IS this more like it? http://dl.dropbox.com/u/33507267/Maytag%...
    The part in the exploded view looks like it, not page 7&* however. I know the part number is 22001988. My main question is how do you reach the top nuts of the shocks? Do you have to remove the innet tub to reach them. I put new front and rear bearings 2 weeks ago solved that problem wish I had replaced the shocks at the same time.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Here is the complete service manual for that unit.
Posted on Nov 01, 2012
3 Suggested Answers
SOURCE: maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Posted on Dec 19, 2009
SOURCE: MAYTAG NEPTUNE FRONT LOAD WASHER MAH5500BWW
Central bearing and seal are damaged. Very expensive repair and very expensive parts. Maytag does not sell bearings separately, they're only available with the outer tub, which is $400-$500; Repair itself is another 2-3 hours of hard work. Do the math...
Posted on Nov 02, 2010
Spin cycle is going on balance
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
Nov 11, 2016 | Washing Machines
Frigidaire affinity walks all over the floor in high spin.
machine not level
tub supports faulty
unbalanced in the spin cycle
Dec 14, 2015 | Frigidaire Washing Machines
Maytag fabric matic washer started walking across floor on spin cycle?
Usually an unbalanced load, but check if rubber feet are worn through.
Jan 03, 2015 | Maytag Washing Machines
Repeat rinse/spin cycle- walking machine
Looks like a programming fault, but try the machine empty if it works correctly Then it was your loading
Oct 05, 2017 | GE Energy Star WCVH6260F Front Load Washer
Washer walks across floor on spin cycle and my level says its level
If the level is registering the machine as level, then you probably have an unbalanced load that is causing it to "walk." When it starts walking, lift the lid, wait until the spinning stops and redistribute the articles in the basket. I hope this helps. If you're satisfied with my solution, please rate my solution on Fixya.
Nov 19, 2010 | Amana Washing Machines
Maytag pav2300 spin cycle spins unbalanced and walks
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Unbalanced washing machine
there may be shipping bolts that you have to remove.read your instructions 2 see
Jan 02, 2009 | Maytag Performa PAV2200
Fwt449gfs1 unbalanced in spin cycle
there is a three post bracket bolted to the back of the inside drum. on ours two of the three spokes are broken. looks like you have to buy whole new drum assembly. around 300 bucks
May 21, 2008 | Frigidaire FWT449
My PAVT920AWW won't spin hard enough to get all the water out
I have had teh same problem. I calledin the Maytag service and they did replace something out of goodwill but the technician told me that the load balance sensor is sensitive. If your load is unbalanced then the machine will spin slowly so it does not walk across the floor. With larger loads the wieght will make the machine bang against the sides and walk.
The solution is quite simple. Make sure the load is balanced. The agitator has a way of unbalancing a load from time to time so you need to do this manually. It is a very rare occurance and it is best to make sure your load goes into the machine balanced first.
Dec 19, 2007 | Maytag Performa PAV2200
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
96 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
