Question about Maytag Washing Machines
Tell me how to replace shocks on a Maytrag MAH5500BWW
Tell me the proceedure to replace the rear shocks
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Here is the service manual for that unit.
Posted on Nov 01, 2012
Washer rocks violently, how can I identify bad shock absorbers?
A washing machine with shock absorbers? Is this a front or top loader? Top loaders you pull the machine forward by grabbing the top of the back. This adjusts the self adjusters. Thanks
May 03, 2016 | Maytag MAH5500BWW Neptune Washer Boot...
Tip
When should I replace my shocks and or struts When a vehicle is brought into an...
When a vehicle is brought into an auto repair shop for routine vehicle maintenance, the auto technician may suggest that the vehicle shocks or struts need to be replaced. Learn the function of a car or trucks shocks and struts. Find out why the shocks and struts need to be replaced and how someone can tell if they’re bad.
The Purpose or Function of a Cars Shocks and Struts
Shocks and struts serve the same purpose. They’re main function is to keep the vehicle from bouncing. A vehicle has front and rear springs to cushion the vehicle over rough road conditions. If there were no shocks or struts the vehicle would continue to bounce excessively. The shocks and struts prevent the car from bouncing by damping the springs.
What’s the Difference Between Shocks and Struts?
Shocks are usually used to dampen leaf springs, where as a strut is used to dampen coil springs. Shocks are usually a single cylinder in the open where as a strut is normally surrounded by the coil spring and are more massive and complicated.
That’s why struts normally cost a lot more to replace than a shock. On a car the front suspension usually has struts and the rear usually has shocks. Some trucks have shocks on the front and rear. Other than those distinctions, shocks and struts serve exactly the same purpose.
Why Should the Cars Shocks or Struts be replaced?
Keeping in mind that the purpose of shocks and struts is to keep the vehicle from bouncing, the following is some of the reasons why they should be replaced.
* An excessively bouncing car can be an uncomfortable driving experience.
* The vehicle can be harder to control leading to an unsafe condition.
* Excessive strain can be put on other vehicle components causing premature failure.
* Bad shocks or struts will cause the tires to bounce and create spotty or choppy wear on the vehicles tires.
How to Tell if a Cars Shocks or Struts are Bad
1. Shocks and struts can be oil or air filled. If they are leaking oil or air they need to be replaced. Consumer beware, some dishonest auto repair shops will squirt oil on the shocks, show the customer the leaky shocks and tell them they need to be replaced.
2. Another method is the bounce test. Put all your weight on the front or rear of the vehicle and push down on the vehicle. Let go of the vehicle and stand back to see of it bounces. If the vehicle comes back up without bouncing, the shocks are probably in good shape. If the vehicle bounces a few times, chances are the shocks or struts need to be replaced.
Shocks and struts are wear items, not maintenance items. There’s no set mileage or time limit when they should be replaced. If the tires seem to have a choppy wear pattern or the vehicle bounces excessively over bumps, the shocks need to be checked.
Look at the struts or shocks and see if they’re leaking. Perform the bounce test and see if the vehicle bounces. Replacing the vehicle shocks and struts when they’re bad will create a safer and more comfortable driving experience, not to mention saving money in the long run.
on Dec 14, 2009 | Honda Accord Cars & Trucks
Replace rear struts how to replace
Remove front panel, lay washer on side opposite the strut you are replacing, remove old strut, replace with new one.
Oct 03, 2014 | Maytag Neptune MAH5500B Front Load Washer
Replace rear shocks
why?
this is just regular every day old fashion shocks.
a bolt on the bottom and a nut on top.
put car on stands, and remove them , no side effects. they are passive to suspension not struts. add on's
if all that is greek, login to alldata.com and read it there
it has a blow by blow steps. every step.
but will not tell you direction of threads, its RHT. (normal)
Jul 07, 2014 | 2004 Nissan Quest
Front shock replacement proceedure
Have yo perormed the work yet? I can tell you what to do if the work has not been done yet.
Sep 18, 2010 | 1994 Jeep Grand Cherokee
How easy is it to rebuild a shock on a honda
My honest opinion is that you leave it to the experts. You need some heavy duty spring compression stands and spring retainers. Sure you can source them but how often will you be rebuilding rear shocks. If you need work done on yours I would suggest going out and buying a reputable after market shock, e.g Ohlins etc.
Mar 06, 2010 | 1999 Honda CBR 900 RR Fireblade
How do i tell if rear air shocks need replacement?
CHECK AND MAKE SURE THAT THEY ARE FULL OF AIR AND THEN CHECK THEY FOR THE NEXT FEW DAYS TO SEE IF THEY GO DOWN, AND IF THEY DO THEY ARE LEAKING AND NEED TO BE REPLACED
Nov 21, 2009 | 2001 Cadillac DeVille
Shocks/struts on 94 mustang gt
no, just replaced mine, springs are independent of shocks and struts
Jun 17, 2008 | 1994 Ford Mustang
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
